查看: 69787|回复: 2
[Linux] 无法生成rootfs.ext4
发表于 2021-6-21 11:15:40 | 显示全部楼层 |阅读模式
根据手册:
rootfs.ext4生成
# cd /root/workspace/allwinner/A40i/bsp/lichee/ #根据自己的环境切换
# ./build.sh -m pack_rootfs
Rootfs 原路径: lichee/out/sun8iw11p1/linux/common/buildroot/target
Rootfs.ext4路径: lichee/out/sun8iw11p1/linux/common/rootfs.ext4
执行后提示:
build buidroot-201611...
xgnueabihf
sun8iw11p1_hf_defconfig
INFO: create ext4 rootfs ...
rm: cannot remove '/home/forlinx/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/rootfs.ext4': No such file or directory
rootdir=/home/forlinx/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/target
table='/home/forlinx/workspace/allwinner/A40i/bsp/lichee/tools/pack/common/devices/_device_table.txt'
makedevs: line 1: regular file '/home/forlinx/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/target/bin/busybox' does not exist: No such file or directory
makedevs: line 2: regular file '/home/forlinx/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/libexec/dbus-daemon-launch-helper' does not exist: No such file or directory
INFO: create ext4 rootfs OK.
并没有生成create ext4,请问这块是如何解决?
发表于 2021-6-21 15:50:42 | 显示全部楼层
生成的是rootfs.ext4,不是create ext4,另外您解压源码的时候解压文件系统了吗
LS1012A通行证A40i/T3/T507/T527通行证
发表于 2022-2-24 11:37:01 | 显示全部楼层
同问,一样的问题:(,楼主解决没?
GMT+8, 2026-9-21 06:18
