查看: 71636|回复: 2
[Linux] 编译 Linux-3.14.38报错
i.MX6Q通行证i.MX6UL通行证RK3568通行证RK3399通行证
发表于 2021-6-22 16:30:49 | 显示全部楼层 |阅读模式
在编译 Linux-3.14.38时报错,请问这个是什么原因呀?用的gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf。ubnutu18.04
  1. drivers/input/touchscreen/gt9xx.c: 在函数‘goodix_ts_probe’中:
  2. drivers/input/touchscreen/gt9xx.c:2423:59: 错误: macro "__TIME__" might prevent reproducible builds [-Werror=date-time]
  3.      GTP_INFO("GTP Driver Built@%s, %s", __TIME__, __DATE__);
  4.                                                            ^
  5. drivers/input/touchscreen/gt9xx.c:2423:1: 错误: macro "__DATE__" might prevent reproducible builds [-Werror=date-time]
  6.      GTP_INFO("GTP Driver Built@%s, %s", __TIME__, __DATE__);
  7. ^
  8. drivers/input/touchscreen/gt9xx.c: 在文件作用域:
  9. drivers/input/touchscreen/gt9xx.c:1657:11: 警告: ‘gtp_i2c_test_no_rst’ defined but not used [-Wunused-function]
  10. static s8 gtp_i2c_test_no_rst(struct i2c_client *client)
  11.            ^
  12. cc1:有些警告被当作是错误
  13. scripts/Makefile.build:308: recipe for target 'drivers/input/touchscreen/gt9xx.o' failed
  14. make[3]: *** [drivers/input/touchscreen/gt9xx.o] Error 1
  15. scripts/Makefile.build:455: recipe for target 'drivers/input/touchscreen' failed
  16. make[2]: *** [drivers/input/touchscreen] Error 2
  17. scripts/Makefile.build:455: recipe for target 'drivers/input' failed
  18. make[1]: *** [drivers/input] Error 2
  19. Makefile:843: recipe for target 'drivers' failed
  20. make: *** [drivers] Error 2
 楼主| 发表于 2021-6-22 16:31:59 | 显示全部楼层
OKMX6UL-C的板子
飞凌出厂的交叉编译器是gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12.tar.gz,没用过你说的这个。  详情 回复 发表于 2021-6-23 08:54
发表于 2021-6-23 08:54:19 | 显示全部楼层
GMT+8, 2026-10-4 15:18
