查看: 35759|回复: 0
[评测] 开发板OKT507-C在电力能源控制器的简单体验
发表于 2021-6-28 21:43:11 | 显示全部楼层 |阅读模式
核心板资源如下(只列举产品需要用到的接口,像视频、HDMI等用不到的功能暂时不考虑):
CPU
T507 双核A53,主频1.5G
RAM
2G
FLASH
8G
运行温度
-40~85℃
UART
6路,2路双线,4路4线,支持RS485。需要2路485,2路232,1路UART接蓝牙模块,
SPI
2路,支持3线/4线置。一路接ESAM,一路接交采
IIC
5路,   一路接RTC,
SD卡
2路,支持SD3.0,4bit总线宽度,需要一路接SD卡扩展容量
USB
4路。1路OTG,3路HOST,需要2路,一路接调试U盘,一路接USB模组
RMII
1路,10/100M自适应
RGMII
1路,10/100/1000 Mbps 自适应   两路独立以太网,正好满足要求
PWM
6路,
ADC
4路,需要2路,检测时钟电池和充电电池或者电容。
提供的操作系统内核版本:Linuxkunos 4.9.170
双网络通信正常,eth0eth1相互独立。
FTP数据传输速度正常,上传11M/s左右,下载10M/s左右。
file:///C:/Users/cfh/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg
file:///C:/Users/cfh/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg
两路USB-HOST接口可以正常连接U盘,进行挂载后可以正常的进行文件传输。
[ 1991.274481] usb 1-1: new high-speed USBdevice number 2 using sunxi-ehci
[ 1991.426235] usb-storage 1-1:1.0: USBMass Storage device detected
[ 1991.434722] scsi host0: usb-storage1-1:1.0
[ 1992.446798] scsi 0:0:0:0:Direct-Access     Generic  Flash Disk       8.07 PQ: 0 ANSI: 4
[ 1992.458557] sd 0:0:0:0: [sda] 31457280512-byte logical blocks: (16.1 GB/15.0 GiB)
[ 1992.468417] sd 0:0:0:0: [sda] WriteProtect is off
[ 1992.473827] sd 0:0:0:0: [sda] ModeSense: 23 00 00 00
[ 1992.480819] sd 0:0:0:0: [sda] Writecache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 1992.502648]  sda: sda1
[ 1992.509690] sd 0:0:0:0: [sda] AttachedSCSI removable disk
[ 1992.770652] FAT-fs (sda1): Volume wasnot properly unmounted. Some data may be corrupt. Please run fsck.
[ 2112.002405] sunxi-ehci5200000.ehci1-controller: ehci_irq: highspeed device disconnect
[ 2112.011689] usb 1-1: USB disconnect,device number 2
[ 2125.684178] sunxi-ehci 5311000.ehci3-controller:ehci_irq: highspeed device connect
[ 2125.911159] usb 3-1: new high-speed USBdevice number 2 using sunxi-ehci
[ 2126.062850] usb-storage 3-1:1.0: USBMass Storage device detected
[ 2126.070572] scsi host1: usb-storage3-1:1.0
[ 2127.086711] scsi 1:0:0:0:Direct-Access     Generic  Flash Disk       8.07 PQ: 0 ANSI: 4
[ 2127.098857] sd 1:0:0:0: [sdb] 31457280512-byte logical blocks: (16.1 GB/15.0 GiB)
[ 2127.108580] sd 1:0:0:0: [sdb] WriteProtect is off
[ 2127.114035] sd 1:0:0:0: [sdb] ModeSense: 23 00 00 00
[ 2127.120946] sd 1:0:0:0: [sdb] Writecache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 2127.142554]  sdb: sdb1
[ 2127.149500] sd 1:0:0:0: [sdb] AttachedSCSI removable disk
[ 2127.410354] FAT-fs (sdb1): Volume was notproperly unmounted. Some data may be corrupt. Please run fsck.
[ 2134.927006] sunxi-ehci5311000.ehci3-controller: ehci_irq: highspeed device disconnect
[ 2134.936111] usb 3-1: USB disconnect,device number 2
是否支持USB接口的4G模组有待验证,目前USB接口的4G模组在使用上会比串口的方便和高效很多。
提供的虚拟机要求VM的版本过高,无法安装环境进行程序测试。
希望系统上功能再丰富一些,一些常用的指令(ldd、file等)都加上。目前设备空间很大,系统可以适当大一些。
总结:T507核心板的功能可以完全满足能源控制器类产品的接口要求,需要系统移植上,增加常用指令,增加容器的相关功能。
GMT+8, 2026-9-25 13:19
