查看: 73046|回复: 2
[Linux] A40i全编译出错(路径已确认正确)
发表于 2021-7-1 13:56:40 | 显示全部楼层 |阅读模式
平台:OKA40i-c V1.2
编译环境:OKA40i-VM_15_1_0-ubuntu18.04说明:
1.源码解码md5均验证无误
2.make menuconfig ARCH=arm修改了nfs配置
操作步骤:1.root@forlinx:~/workspace/allwinner/A40i/bsp/lichee# pwd
/root/workspace/allwinner/A40i/bsp/lichee
root@forlinx:~/workspace/allwinner/A40i/bsp/lichee# ./build.sh config
2.root@forlinx:~/workspace/allwinner/A40i/bsp/lichee# ./build.sh
build buidroot-201611...
xgnueabihf
sun8iw11p1_hf_defconfig
INFO: ----------------------------------------
INFO: build lichee ...
INFO: chip: sun8iw11p1
INFO: platform: linux
INFO: kernel: linux-3.10
INFO: board: OKA40i_C
INFO: output: out/sun8iw11p1/linux/OKA40i_C
INFO: build buildroot ...
make: Entering directory '/root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611'
>>> libglib2 2.50.1 Building
PATH="/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"  /usr/bin/make -j5  -C /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/
make[1]: Entering directory '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1'
cd . && /bin/sh /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/missing automake-1.15 --gnu Makefile
Unescaped left brace in regex is illegal here in regex; marked by <-- HERE in m/\${ <-- HERE ([^ \t=:+{}]+)}/ at /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/automake-1.15 line 3936.
Makefile:862: recipe for target 'Makefile.in' failed
make[1]: *** [Makefile.in] Error 255
make[1]: Leaving directory '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1'
package/pkg-generic.mk:216: recipe for target '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_built' failed
make: *** [/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_built] Error 2
make: Leaving directory '/root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611'
ERROR: build buildroot Failed
望帮助解答,感谢!
发表于 2021-7-1 16:48:01 | 显示全部楼层
buildroot201611源码不开源,您跳过这一部分编译就可以了,其他编译失败的信息您可以具体看一下对应文件的对应行数有什么问题
A40i/T3/T507/T527通行证RK3568通行证RK3588通行证T113i通行证D9360通行证RK3576通行证RK3562通行证RK3506通行证T536通行证
发表于 2021-7-4 22:13:16 | 显示全部楼层
/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/automake-1.15 第 3936 行
将 - $text =~ s/\${([^ \t=:+{}]+)}/substitute_ac_subst_variables_worker ($1)/ge;
修改为 - $text =~ s/\$[{]([^ \t=:+{}]+)}/substitute_ac_subst_variables_worker ($1)/ge;
试试
GMT+8, 2026-9-21 07:04
