查看: 42990|回复: 1
[Linux] RK3399 tensorflow源码编译异常
发表于 2021-7-8 16:22:47 | 显示全部楼层 |阅读模式
Label_image 采用cmake.. 编译后正常,但执行make操作后,链接失败,,提示静态链接库libtensorflow-lite.a需要重新以-fPIC编译下,提示内容如下:
w-lite.a(eigen_support.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol `stderr@@GLIBC_2.17' which may bind externally can not be used when ** a shared object; recompile with -fPIC
/usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: ../3rd**/tflite/lib/libtensorflow-lite.a(eigen_support.o)(.text.unlikely+0): unresolvable R_AARCH64_ADR_PREL_PG_HI21 relocation against symbol `stderr@@GLIBC_2.17'
如下图所示:
如何解决呢?请求大佬赐教!!谢谢!!
发表于 2021-7-14 10:22:48 | 显示全部楼层
目前我们没遇到过这个问题,可以先测试一下tensorflow是不是正常。
GMT+8, 2026-10-7 15:40
