查看: 20595|回复: 1
[Linux] 全编译时报错
发表于 2021-7-18 10:58:51 | 显示全部楼层 |阅读模式
进行全编译时,报错,请问该如何解决?
>>Generating root filesystem image rootfs.ext2
rm -f /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
rm -f /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
rm -f /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt
echo '#!/bin/sh' > /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
echo "set -e" >> /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
echo "chown -h -R 0:0 /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/target" >> /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
printf '           dbus -1 dbus -1 * /var/run/dbus - dbus DBus messagebus user\n         - - docker -1 * - - - Docker Application Container Framework\n         - - input -1 * - - - Input device group\n         sshd -1 sshd -1 * - - - SSH drop priv user\n         ftp -1 ftp -1 * /home/ftp - - Anonymous FTP User\n\n' >> /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt
PATH="/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/opt/arm/opt/ext-toolchain/bin:/usr/local/arm-gdb/bin" /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/buildroot-201611/support/scripts/mkusers /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/target >> /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
cat system/device_table.txt > /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt
printf '           /bin/busybox                     f 4755 0  0 - - - - -\n         /usr/libexec/dbus-daemon-launch-helper f 4755 0 0 - - - - -\n /dev/console c 622 0 0 5 1 - - -\n\n' >> /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt
echo "/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/makedevs -d /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/target" >> /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
printf '           PATH="/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/opt/arm/opt/ext-toolchain/bin:/usr/local/arm-gdb/bin" mke2img -d /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/target -G 4 -R 1 -B 1524000 -I 0 -l "rootfs" -o /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/images/rootfs.ext2\n' >> /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
chmod a+x /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
PATH="/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/opt/arm/opt/ext-toolchain/bin:/usr/local/arm-gdb/bin" /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/fakeroot -- /home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
fakeroot: preload library `libfakeroot.so' not found, aborting.
fs/ext2/ext2.mk:46: recipe for target '/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/images/rootfs.ext2' failed
make: *** [/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/out/sun8iw11p1/linux/common/buildroot/images/rootfs.ext2] Error 1
make: Leaving directory '/home/forlinx/workspace/allwinner/A40i/bsp/lichee0718/buildroot-201611'
ERROR: build rootfs Failed
发表于 2021-7-19 08:50:48 | 显示全部楼层
您按手册的路径存放文件,然后进行编译。
点评回复 支持 0 反对 1
GMT+8, 2026-9-21 07:03
