查看: 68619|回复: 7
[Linux] OKA40i 打包失败
发表于 2021-8-14 16:16:41 | 显示全部楼层 |阅读模式
按照文档《OKA40i-C&OKT3-C-Linux-软件用户手册-V1.5-20201218》4.5节,编译内核成功,但打包失败。
  1. ./build.sh pack
错误 log 信息如下:
  1. [one2inf@one2inf-vmwarevirtualplatform lichee]$ ./build.sh pack
  2. build buidroot-201611...
  3. xgnueabihf
  4. sun8iw11p1_hf_defconfig
  5. INFO: packing firmware ...
  6. copying tools file
  7. copying configs file
  8. ./out/aultls32.fex
  9. ./out/aultools.fex
  10. ./out/boot_package.cfg
  11. ./out/boot_package.fex
  12. ./out/boot_package_nor.cfg
  13. ./out/cardscript.fex
  14. ./out/cardscript_secure.fex
  15. ./out/cardtool.fex
  16. ./out/diskfs.fex
  17. ./out/env.cfg
  18. ./out/env_burn.cfg
  19. ./out/image.cfg
  20. renamed './out/image_linux.cfg' -> './out/image.cfg'
  21. ./out/split_**x.fex
  22. ./out/sunxi.fex
  23. ./out/sys_config.fex
  24. ./out/sys_config1024x600.fex
  25. ./out/sys_config1024x600_100M.fex
  26. ./out/sys_config1024x600_pwm4.fex
  27. ./out/sys_config1024x600_v1.fex
  28. ./out/sys_config1024x600mipi-gt9xx.fex
  29. ./out/sys_config1024x600mipi.fex
  30. ./out/sys_config1024x600mipi_v1.fex
  31. ./out/sys_config1080p.fex
  32. ./out/sys_config1080p_v1.fex
  33. ./out/sys_config1280x800.fex
  34. ./out/sys_config1280x800_v1.fex
  35. ./out/sys_config800x480.fex
  36. ./out/sys_config800x480_v1.fex
  37. ./out/sys_configFCU2401.fex
  38. ./out/sys_configFCU2401_100M.fex
  39. ./out/sys_config_new_evb_lvds1024600.fex
  40. ./out/sys_partition_dump.fex
  41. renamed './out/sys_partition_linux.fex' -> './out/sys_partition.fex'
  42. ./out/sys_partition_linux_128M.fex
  43. ./out/sys_partition_linux_256M.fex
  44. ./out/sys_partition_linux_mmc.fex
  45. ./out/sys_partition_private.fex
  46. ./out/toc0.fex
  47. ./out/toc1.fex
  48. ./out/usbtool.fex
  49. ./out/usbtool_test.fex
  50. copying boot resource
  51. copying usr resource
  52. copying boot file
  53. p=soc c=product state=0
  54. p=soc c=platform state=0
  55. p=soc c=target state=0
  56. p=soc c=norflash state=0
  57. p=soc c=boot_init_gpio state=0
  58. p=soc c=power_sply state=0
  59. p=soc c=card_boot state=0
  60. p=soc c=pm_para state=0
  61. p=soc c=card0_boot_para state=0
  62. p=soc c=card2_boot_para state=0
  63. p=soc c=twi_para state=0
  64. p=soc c=uart_para state=0
  65. p=soc c=jtag_para state=0
  66. p=soc c=clock state=0
  67. p=soc c=dram state=0
  68. p=soc c=emac0 state=0
  69. p=soc c=gmac0 state=0
  70. p=soc c=can0 state=0
  71. p=soc c=can0 state=1
  72. p=soc c=twi0 state=0
  73. p=soc c=twi1 state=0
  74. p=soc c=twi2 state=0
  75. p=soc c=twi3 state=0
  76. p=soc c=twi4 state=0
  77. p=twi2 c=rx8010 state=0
  78. p=twi4 c=at24 state=0
  79. p=soc c=ir0 state=0
  80. p=soc c=uart0 state=0
  81. p=soc c=uart0 state=1
  82. p=soc c=uart1 state=0
  83. p=soc c=uart1 state=1
  84. p=soc c=uart2 state=0
  85. p=soc c=uart2 state=1
  86. p=soc c=uart3 state=0
  87. p=soc c=uart3 state=1
  88. p=soc c=uart4 state=0
  89. p=soc c=uart4 state=1
  90. p=soc c=uart5 state=0
  91. p=soc c=uart5 state=1
  92. p=soc c=uart6 state=0
  93. p=soc c=uart6 state=1
  94. p=soc c=uart7 state=0
  95. p=soc c=uart7 state=1
  96. p=soc c=spi0 state=0
  97. p=soc c=spi1 state=0
  98. p=soc c=spi2 state=0
  99. p=soc c=spi3 state=0
  100. p=soc c=rtp_para state=0
  101. p=soc c=ctp state=0
  102. p=soc c=ctp_list state=0
  103. p=soc c=tkey_para state=0
  104. p=soc c=motor_para state=0
  105. p=soc c=nand0 state=0
  106. p=soc c=sata state=0
  107. p=soc c=disp state=0
  108. p=soc c=tv0 state=0
  109. p=soc c=tv1 state=0
  110. p=soc c=tvd state=0
  111. p=soc c=tvd0 state=0
  112. p=soc c=tvd1 state=0
  113. p=soc c=tvd2 state=0
  114. p=soc c=tvd3 state=0
  115. p=soc c=lcd0 state=0
  116. p=soc c=lcd0 state=1
  117. p=soc c=pwm0 state=0
  118. p=soc c=pwm0 state=1
  119. p=soc c=car_reverse state=0
  120. p=soc c=Transmit_fm state=0
  121. p=soc c=hdmi state=0
  122. p=soc c=ak7601 state=0
  123. p=soc c=csi0 state=0
  124. p=csi0 c=csi0_dev0 state=0
  125. p=soc c=csi1 state=0
  126. p=csi1 c=csi1_dev0 state=0
  127. p=soc c=tvout_para state=0
  128. p=soc c=tvin_para state=0
  129. p=soc c=di state=0
  130. p=soc c=sdc0 state=0
  131. p=soc c=sdc1 state=0
  132. p=soc c=sdc2 state=0
  133. p=soc c=sdc3 state=0
  134. p=soc c=smc state=0
  135. p=soc c=gpio_para state=0
  136. p=soc c=usbc0 state=0
  137. p=soc c=usbc1 state=0
  138. p=soc c=usbc2 state=0
  139. p=soc c=gsensor_para state=0
  140. p=soc c=gps_para state=0
  141. p=soc c=ril_para state=0
  142. p=soc c=wlan state=0
  143. p=soc c=bt state=0
  144. p=soc c=btlpm state=0
  145. p=soc c=gy_para state=0
  146. p=soc c=ls_para state=0
  147. p=soc c=compass_para state=0
  148. p=soc c=spdif state=0
  149. p=soc c=sndspdif state=0
  150. p=soc c=audiohdmi state=0
  151. p=soc c=sndhdmi state=0
  152. p=soc c=snddaudio0 state=0
  153. p=soc c=daudio0 state=0
  154. p=soc c=snddaudio1 state=0
  155. p=soc c=daudio1 state=0
  156. p=soc c=sndcodec state=0
  157. p=soc c=codec state=0
  158. p=soc c=pmu0 state=0
  159. p=soc c=charger0 state=0
  160. p=soc c=powerkey0 state=0
  161. p=soc c=regulator0 state=0
  162. p=soc c=axp_gpio0 state=0
  163. p=soc c=dvfs_table state=0
  164. p=soc c=Vdevice state=0
  165. p=soc c=gpu_mali400_0 state=0
  166. Conver script to dts ok.
  167. dtbpath=/home/one2inf/a40i_board/lichee/tools/pack/out/sunxi.fex
  168. update_fdt: u-boot.fex will merage sunxi.fex, generate u-boot.fex
  169. ---0xd0, 0xd
  170. update_fdt: num 844384 randto1k
  171. update_fdt: num 156080 randto1k
  172. file1_len = ce400, file2_len = 28400
  173. dtb offset ce400,size 28400
  174. update_fdt:genrate /home/one2inf/a40i_board/lichee/tools/pack/out/u-boot.fex ok
  175. pack boot package
  176. GetPrivateProfileSection read to end
  177. content_count=1
  178. packing for linux
  179. normal
  180. mbr count = 4
  181. partitation file Path=/home/one2inf/a40i_board/lichee/tools/pack/out/sys_partition.bin
  182. mbr_name file Path=/home/one2inf/a40i_board/lichee/tools/pack/out/sunxi_mbr.fex
  183. download_name file Path=/home/one2inf/a40i_board/lichee/tools/pack/out/dlinfo.fex
  184. mbr size = 16384
  185. mbr magic softw411
  186. disk name=boot-resource
  187. filename = boot-resource.fex
  188. dl_file_size = 10682 sector
  189. part_size = 28672 sector
  190. disk name=env
  191. filename = env.fex
  192. dl_file_size = 256 sector
  193. part_size = 8192 sector
  194. disk name=boot
  195. filename = boot.fex
  196. dl_file_size = 26108 sector
  197. part_size = 32768 sector
  198. disk name=rootfs
  199. filename = rootfs.fex
  200. dl_file_size = 3931054 sector
  201. part_size = 4200000 sector
  202. disk name=private
  203. disk name=usr
  204. unable to open file usr-resource.fex
  205. dl file usr-resource.fex size too large
  206. update_for_part_info -1
  207. update mbr file fail
  208. ERROR: update_mbr failed
发表于 2021-8-14 16:27:54 | 显示全部楼层
您这个打印信息没有报错啊,您怎么判断打包失败的
重新复制了,lichee/tools/pack 路径下没有 img 生成。我看论坛里另外两人和我一样的错误,但没有给出解决的办法  详情 回复 发表于 2021-8-14 17:12
 楼主| 发表于 2021-8-14 17:12:00 | 显示全部楼层
重新复制了,lichee/tools/pack 路径下没有 img 生成。没有动配置,第一次编译。我看论坛里另外两人和我一样的错误,但没有给出解决的办法
发表于 2021-8-14 17:28:27 | 显示全部楼层
您换我们的新资料吧,这个问题是旧资料的bug,换我们最新的资料不会出现
你好,请问新的资料版本日期是多少?  详情 回复 发表于 2021-8-16 10:57
我去,真的更新了,我7月份才刚下。。。,还是谢谢了 我手动修改分区后也打包成功了,应该就是分区太小了的问题。  详情 回复 发表于 2021-8-15 17:22
 楼主| 发表于 2021-8-15 17:22:30 | 显示全部楼层
A40i/T3/T507/T527通行证AM335x通行证i.MX6UL通行证
发表于 2021-8-16 10:57:54 | 显示全部楼层
你好,请问新的资料版本日期是多少?
发表于 2021-8-16 11:45:50 | 显示全部楼层
linux系统资料是2021.07.30
我用了新资料后,打包的固件无法烧录!我新建了帖子。  详情 回复 发表于 2021-8-16 16:52
 楼主| 发表于 2021-8-16 16:52:43 | 显示全部楼层
GMT+8, 2026-9-21 07:04
