查看: 62702|回复: 3
[Linux] build buildroot Failed 编译错误,请解答
发表于 2021-8-25 17:47:53 | 显示全部楼层 |阅读模式
18.4环境下,装了path,按教程整体编译出错
>>> libglib2 2.50.1 Building
PATH="/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin:/usr/local/arm/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin"  /usr/bin/make -j5  -C /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/
make[1]: Entering directory '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1'
cd . && /bin/sh /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/missing automake-1.15 --gnu Makefile
Unescaped left brace in regex is illegal here in regex; marked by <-- HERE in m/\${ <-- HERE ([^ \t=:+{}]+)}/ at /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/automake-1.15 line 3936.
Makefile:862: recipe for target 'Makefile.in' failed
make[1]: *** [Makefile.in] Error 255
make[1]: Leaving directory '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1'
package/pkg-generic.mk:216: recipe for target '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_built' failed
make: *** [/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_built] Error 2
make: Leaving directory '/root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611'
ERROR: build buildroot Failed
root@forlinx:~/workspace/allwinner/A40i/bsp/lichee#
发表于 2021-8-26 09:49:52 | 显示全部楼层
我们buildroot源码不开源的,源码里没有这部分源码
A40i/T3/T507/T527通行证RK3568通行证RK3588通行证T113i通行证RK3576通行证RK3506通行证T536通行证
发表于 2021-9-29 17:05:40 | 显示全部楼层
如何跳过呢
发表于 2021-9-30 17:42:08 | 显示全部楼层
1、18.04整体编译,需要装上开发环境资料里的patch,安装方法可以参考资料里的pdf文件。
2、您编译的时候是用的出厂镜像还是自己做过修改,我这边用出厂镜像测过,没出现buildroot的报错。
3、另外您是为什么用全编译?如果不用buildroot,不建议全编译,只要涉及到编译内核,就单独编译内核,打包文件系统,最后pack成img就可以了,没必要全编译的
GMT+8, 2026-9-21 06:17
