查看: 18239|回复: 2
[Linux] 请教制作底版问题
A40i/T3/T507/T527通行证i.MX6Q通行证i.MX8MM通行证i.MX8MP通行证RK3568通行证RK3399通行证AM335x通行证AM62x资料下载
发表于 2021-9-2 13:55:56 | 显示全部楼层 |阅读模式
1、EMMC核心板SPI0无法用,底版用SPI1,如何修改设备树?
2、LVDSL 我用单通道LVDSL0,  LVDSL1的管腿可以用作GPIO吗?
 楼主| 发表于 2021-9-2 17:22:05 | 显示全部楼层
SPI1的地址不知道哇!是多少?
spi0: spi@05010000 {
您可以在设备树里可以查看: OKT507-linux-sdk/kernel/linux-4.9/arch/arm64/boot/dts/sunxi/sun50iw9p1.dtsi  详情 回复 发表于 2021-9-8 08:47
发表于 2021-9-8 08:47:16 | 显示全部楼层
zhhdadu 发表于 2021-9-2 17:22
SPI1的地址不知道哇!是多少?
您可以在设备树里可以查看:
  1. 1165                 spi0: spi@05010000 {
  2. 1166                         #address-cells = <1>;
  3. 1167                         #size-cells = <0>;
  4. 1168                         compatible = "allwinner,sun50i-spi";
  5. 1169                         device_type = "spi0";
  6. 1170                         reg = <0x0 0x05010000 0x0 0x1000>;
  7. 1171                         interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>;
  8. 1172                         clocks = <&clk_pll_periph0>, <&clk_spi0>;
  9. 1173                         clock-frequency = <100000000>;
  10. 1174                         pinctrl-names = "default", "sleep";
  11. 1175                         pinctrl-0 = <&spi0_pins_a &spi0_pins_b>;
  12. 1176                         pinctrl-1 = <&spi0_pins_c>;
  13. 1177                         spi0_cs_number = <1>;
  14. 1178                         spi0_cs_bitmap = <1>;
  15. 1179                         status = "disabled";
  16. 1180                 };
  17. 1181
  18. 1182                 spi1: spi@05011000 {
  19. 1183                         #address-cells = <1>;
  20. 1184                         #size-cells = <0>;
  21. 1185                         compatible = "allwinner,sun50i-spi";
  22. 1186                         device_type = "spi1";
  23. 1187                         reg = <0x0 0x05011000 0x0 0x1000>;
  24. 1188                         interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>;
  25. 1189                         clocks = <&clk_pll_periph0>, <&clk_spi1>;
  26. 1190                         clock-frequency = <100000000>;
  27. 1191                         pinctrl-names = "default", "sleep";
  28. 1192                         pinctrl-0 = <&spi1_pins_a &spi1_pins_b>;
  29. 1193                         pinctrl-1 = <&spi1_pins_c>;
  30. 1194                         spi1_cs_number = <1>;
  31. 1195                         spi1_cs_bitmap = <1>;
  32. 1196                         status = "disabled";
  33. 1197                 };
GMT+8, 2026-10-4 13:20
