查看: 47606|回复: 2
[Linux] 请问如何将A40i的mmc0/sdc0,SD卡去掉,不需要SD烧录
发表于 2021-9-18 16:28:32 | 显示全部楼层 |阅读模式
如题,不需要SD卡烧录,占用6个IO引脚,想做为普通IO使用,使用OTG烧录就可以了
 楼主| 发表于 2021-9-18 19:29:28 | 显示全部楼层
  1. ;----------------------------------------------------------------------------------
  2. ;card_ctrl卡量产控制器选择0
  3. ;card_high_speed速度模式0为低速,1为高速
  4. ;card_line 4:4线卡  8:8线卡
  5. ;引脚配置
  6. ;注:此接口在底板上面,如果不使用,全部注释掉,包括配置,否则烧录镜像无法开机
  7. ;----------------------------------------------------------------------------------
  8. [card0_boot_para]
  9. ;card_ctrl       = 0
  10. ;card_high_speed = 1
  11. ;card_line       = 4
  12. ;sdc_d1          = port:PF0<2><1><2><default>
  13. ;sdc_d0          = port:PF1<2><1><2><default>
  14. ;sdc_clk         = port:PF2<2><1><2><default>
  15. ;sdc_cmd         = port:PF3<2><1><2><default>
  16. ;sdc_d3          = port:PF4<2><1><2><default>
  17. ;sdc_d2          = port:PF5<2><1><2><default>
  18. ;----------------------------------------------------------------------------------
  2. ;   SDMMC PINS MAPPING                                                          |
  3. ; ------------------------------------------------------------------------------|
  4. ;   Config Guide        |
  5. ;   sdc_used: 1-enable card, 0-disable card                                     |
  6. ;   non-removable:if you use as main memory,you should set it,for example eMMC  |
  7. ;   bus-width: card bus width, 1-1bit, 4-4bit, 8-8bit                           |
  8. ;   sunxi-power-save-mode: if use sdio card,should not set it                   |
  9. ;   vmmc:regulator for card/emmc power                                                 |
  10. ;    vqmmc:regulator for card/emmc io power                                        |
  11. ;    vdmmc:regulator for card detect pin pull up power                                |
  12. ;   other: GPIO Mapping configuration                                           |
  13. ; ------------------------------------------------------------------------------|
  14. ;   sdc0复用为io,不使用
  15. ;   sdc1复用为io,不使用
  16. ;   sdc2在核心板
  17. ;   sdc3用为TF卡
  19. [sdc0]
  20. sdc0_used          = 0
  21. bus-width                      = 4
  22. ;sdc0_d1            = port:PF00<2><1><2><default>
  23. ;sdc0_d0            = port:PF01<2><1><2><default>
  24. ;sdc0_clk           = port:PF02<2><1><2><default>
  25. ;sdc0_cmd           = port:PF03<2><1><2><default>
  26. ;sdc0_d3            = port:PF04<2><1><2><default>
  27. ;sdc0_d2            = port:PF05<2><1><2><default>
  28. ;cd-gpios           = port:PI11<0><1><2><default>
  29. ;wp-gpios          = port:PG01<0><1><2><default>
  30. ;wp-inverted       =
  31. broken-cd       =
  32. sunxi-power-save-mode =
  33. sunxi-dis-signal-vol-sw =
  34. ;mmc-ddr-1_8v      =
  35. ;mmc-hs200-1_8v    =
  36. ;mmc-hs400-1_8v    =
  37. ;max-frequency     = 150000000
  38. vmmc="vcc-sdcv-p3"
  39. vqmmc="vcc-sdcvq33-p3"
  40. vdmmc="vcc-sdcvd-p3"
  41. ;ctl-spec-caps = 0x8
将fex文件中上面关于SD部分修改,即可去掉,驱动,而且开机不受影响
 楼主| 发表于 2021-9-18 20:56:55 | 显示全部楼层
啊啊啊啊啊啊啊啊啊啊啊啊
GMT+8, 2026-9-20 13:40
