查看: 28242|回复: 6
[Linux] RK3399重新烧写boot.img后系统一直重启
AM335x通行证XX18通行证
发表于 2021-10-22 10:15:55 | 显示全部楼层 |阅读模式
DDR Version 1.23 20190709
In
Channel 0: LPDDR3, 800MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=32 Size=1024MB
Channel 1: LPDDR3, 800MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x20
ch 1 ddrconfig = 0x101, ddrsize = 0x20
pmugrf_os_reg[2] = 0x3280D280, stride = 0x9
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 246
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=15028MB
FwPartOffset=2000 , 100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=7695MB
FwPartOffset=2000 , 0
StorageInit ok = 260376
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
Load uboot, ReadLba = 2000
hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xdace0
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):22b599a
NOTICE:  BL31: Built : 11:03:32, Jul 10 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1181): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-223-g45f58ab9 #165 Thu Aug 15 00:59:09 UTC 2019 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09 (Mar 10 2021 - 02:48:14 +0000)
Model: Forlinx OK3399 Evaluation Board
PreSerial: 2
DRAM:  2 GiB
Sysmem: init
Relocation Offset is: 7dbe9000
Using default environment
no mmc device at slot 1
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
Found IDB in SDcard
dwmmc@fe320000: 1 (SD), sdhci@fe330000: 0
Bootdev(atags): mmc 1
MMC1: Legacy, 50Mhz
PartType: RKPARM
boot mode: recovery (misc)
## Resetting to default environment
Writing to MMC(0)... done
switch to partitions #0, OK
mmc1 is current device
Found IDB in SDcard
Load FDT from recovery part
DTB: rk-kernel.dtb
I2c0 speed: 400000Hz
PMIC:  RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 930000 uV
In:    serial
Out:   serial
Err:   serial
Model: Forlinx OK3399 Board(Linux)
board_modify_fdt
Display force mode in dtb
Error binding driver 'fixed regulator': -22
"Synchronous Abort" handler, esr 0x96000010
* Relocate offset = 000000007dbe9000
* ELR(PC)    =   0000000000251644
* LR         =   00000000002517ec
* SP         =   000000007bddcc80
* ESR_EL2    =   0000000096000010
        EC[31:26] == 100101, Exception from a Data abort, from current exception level
        IL[25] == 1, 32-bit instruction trapped
* DAIF       =   00000000000003c0
        D[9] == 1, DBG masked
        A[8] == 1, ABORT masked
        I[7] == 1, IRQ masked
        F[6] == 1, FIQ masked
* SPSR_EL2   =   00000000a0000349
        I[7] == 0, IRQ not masked
        M[4] == 0, Exception taken from AArch64
        M[3:0] == 1001, EL2h
* SCTLR_EL2  =   0000000030c51835
        I[12] == 1, Icaches enabled
        C[2] == 1, Dcache enabled
        M[0] == 1, MMU enabled
* HCR_EL2    =   000000000800003a
* VBAR_EL2   =   000000007dde9800
* TTBR0_EL2  =   000000007fff0000
x0 : 0000000008400009 x1 : 00000000fff0bdf7
x2 : 0000000000000020 x3 : 0000000000000023
x4 : 000000007dea5fd0 x5 : 0000000000006c70
x6 : 000000000000000a x7 : 0000000000000044
x8 : 0000000000000003 x9 : 0000000000000008
x10: 00000000ffffffe0 x11: 000000007de8ed6b
x12: 000000007dea91d0 x13: 000000007dea8ff0
x14: 0000000008300000 x15: 00000000ffffffff
x16: 0000000000008080 x17: 0000000000a80181
x18: 000000007bde0d10 x19: 000000000830bc7c
x20: 000000007be38be0 x21: 0000000000003738
x22: 000000007be397d0 x23: 000000007be12d20
x24: 000000007de95b45 x25: 000000007be12a08
x26: 000000007be38fb0 x27: 000000007de98938
x28: 0000000000000000 x29: 000000007bddce60
SP:
7bddcc80:  00000000 00000000 00000000 00000000
7bddcc90:  00000000 00000000 7de99a9d 00000000
7bddcca0:  00000000 00000000 00000000 00000000
7bddccb0:  7de99ae4 00000000 7de99b0a 00000000
7bddccc0:  7de99b57 00000000 7de99ba4 00000000
7bddccd0:  7de99be4 00000000 7de99c24 00000000
7bddcce0:  7de99c61 00000000 00000000 00000000
7bddccf0:  00000000 00000000 7de99c9e 00000000
7bddcd00:  7bddce60 00000000 7dde9a0c 00000000
7bddcd10:  0830bc7c 00000000 7be38be0 00000000
7bddcd20:  7fff0000 00000000 0800003a 00000000
7bddcd30:  30c51835 00000000 7bddcc80 00000000
7bddcd40:  a0000349 00000000 7dde9800 00000000
7bddcd50:  000003c0 00000000 96000010 00000000
7bddcd60:  7de3a644 00000000 08400009 00000000
7bddcd70:  fff0bdf7 00000000 00000020 00000000
Call trace:
  PC:   [< 00251644 >]
  LR:   [< 002517ec >]
Stack:
        [< 00251644 >]
        [< 002517ec >]
        [< 002335a8 >]
        [< 002346a8 >]
        [< 00234808 >]
        [< 00242554 >]
        [< 00242bb8 >]
        [< 002335c4 >]
        [< 002346a8 >]
        [< 0023499c >]
        [< 002349c4 >]
        [< 00206d68 >]
        [< 00202dd4 >]
        [< 0027dc28 >]
        [< 00218d4c >]
        [< 0020199c >]
Copy above stack info to a file(eg. dump.txt), and
execute command in your U-Boot project: ./scripts/stacktrace.sh dump.txt
Resetting CPU ...
这是串口打印信息,一直重复
发表于 2021-10-22 13:43:13 | 显示全部楼层
请重新烧写update.img,看能否启动,测试是否是镜像的原因。
尝试过了,按照步骤做了张烧写TK卡,插上去上电还是一直在重启,没有进行烧写。  详情 回复 发表于 2021-10-22 14:03
AM335x通行证XX18通行证
 楼主| 发表于 2021-10-22 14:03:05 | 显示全部楼层
请描述一下拿到开发板时能否正常启动,您进行了什么操作。 您描述说烧写boot导致重启,是OTG分布烧写boot,请尝试OTG烧写update.img tf卡无法烧写,可能是未识别到tf卡,若尝试后仍不成功,请在工作日通过电话联系  详情 回复 发表于 2021-10-23 13:50
发表于 2021-10-23 13:50:38 | 显示全部楼层
tf卡无法烧写,可能是未识别到tf卡,若尝试后仍不成功,请在工作日通过电话联系我司
板子到手时是没问题的,使用期间我多次更改设备树,编译镜像,使用OTG将boot.img烧入开发板,没有出现过问题。 只是最近一次,更改了设备树中显示部分的一组参数,编译完成后,使用OTG将boot.img烧入开办板之后,再  详情 回复 发表于 2021-10-25 15:03
AM335x通行证XX18通行证
 楼主| 发表于 2021-10-25 15:03:41 | 显示全部楼层
您描述说烧写boot导致重启,是OTG分布烧写boo ...
只是最近一次,更改了设备树中显示部分的一组参数,编译完成后,使用OTG将boot.img烧入开办板之后,再次开机,打印信息就一直在显示重启。
tf卡烧写update.img也不成功,不知道是不是未识别到。
您所说的尝试OTG烧写update.img,我这边目前电脑上OTG的软件根本就识别不到loader设备,可能是因为一直在重启的原因,也正是因为OTG无法进行烧写才想尝试用tf卡进行烧写的。
OTG分步烧写boot.img 应该是在发现loader设备后的操作,您可以将过程截图或者录制视频通过销售发送至技术服务,帮您排查问题  详情 回复 发表于 2021-10-25 16:30
识别不到loader设备这个问题,如果操作没有问题的话,请将瑞芯微开发工具解压到全英文的路径下进行尝试  详情 回复 发表于 2021-10-25 16:19
发表于 2021-10-25 16:19:46 | 显示全部楼层
lvzeshuai 发表于 2021-10-25 15:03
板子到手时是没问题的,使用期间我多次更改设备树,编译镜像,使用OTG将boot.img烧入开发板,没有出现过 ...
发表于 2021-10-25 16:30:27 | 显示全部楼层
OTG分步烧写boot.img 应该是在发现loader设备后的操作,您可以将过程截图或者录制视频通过销售或者邮件发送至技术服务,帮您排查问题
GMT+8, 2026-10-7 14:28
