查看: 36957|回复: 3
[Linux] ERROR: update_mbr failed
发表于 2021-10-30 10:53:02 | 显示全部楼层 |阅读模式
A40i 源码编辑成功 打包失败
mbr size = 16384
mbr magic softw411
disk name=boot-resource
filename = boot-resource.fex
dl_file_size = 10682 sector
part_size = 28672 sector
disk name=env
filename = env.fex
dl_file_size = 256 sector
part_size = 8192 sector
disk name=boot
filename = boot.fex
dl_file_size = 26100 sector
part_size = 32768 sector
disk name=rootfs
filename = rootfs.fex
dl_file_size = 3931026 sector
part_size = 4200000 sector
disk name=private
disk name=usr
unable to open file usr-resource.fex
dl file usr-resource.fex size too large
update_for_part_info -1
update mbr file fail
发表于 2021-11-2 08:48:54 | 显示全部楼层
您是修改文件系统分区大小了吗,或者编译的时候是全编译,但是又重新解压文件系统了?
 楼主| 发表于 2021-11-2 15:44:26 | 显示全部楼层
已经解决了,谢谢
请问,怎么解决的?  详情 回复 发表于 2021-11-16 14:43
A40i/T3/T507/T527通行证i.MX6UL通行证FCU11xx通行证
发表于 2021-11-16 14:43:34 | 显示全部楼层
王敬松 发表于 2021-11-2 15:44
已经解决了,谢谢
请问,怎么解决的?
GMT+8, 2026-9-21 06:20
