查看: 3358|回复: 3
开发板启动问题
RK3399通行证
发表于 2011-8-12 10:24:38 | 显示全部楼层 |阅读模式
我的是FL2440的
上电后开发板停在bootloder启动画面那里,在DNW上有以下两种显示情况
1,如果在读秒时不按任何键如下显示
|   FL2440 Bootloader VER-5.1              www.witech.com.cn |
|CPU ID is 0x32440001                                        |
|FCLK=400MHz,HCLK=100MHz,PCLK=50MHz, CPU is running at 400MHz|
|UPLL=96MHz, UCLK=48MHz                                      |
|Serial port 0, Baud rate is 115200.                         |
|OS image stored in NAND Flash.                              |
|Autoboot delay is 7 seconds.                                |
Load eboot...
run 0x30038000...
Microsoft Windows CE Ethernet Bootloader Common Library Version 1.1 Built Mar  5 2010 17:11:57
Microsoft Windows CE Bootloader for the Samsung SMDK2440 Version 2.4 Built Mar  5 2010
FMD: ReadID (Mfg=ec, Dev=da)
FMD_Init: finished successful
FMD_Init: reserved_blocks 548
FMD_GetInfo
Initiating image launch in 0 seconds.
Launching image from boot media ...
OEMPlatformInit: IMAGE_TYPE_RAMIMAGE
ReadOSImageFromBootMedia: ERROR_INVALID_ADDRESS: (address=0x0, sectors=0x0, launch address=0x0)...
OEMPlatformInit ERROR: Failed to load kernel region into RAM.
2,在读秒时按下空格键如下显示
nter your selection:
Load eboot...
run 0x30038000...
FMD_GetInfo
Initiating image launch in 4 seconds.
Ethernet Boot Loader Configuration:
0) IP address: 192.168.1.115
1) Subnet mask: 255.255.255.0
2) DHCP: Disabled
3) Boot delay: 5 seconds
6) Program disk image into SmartMedia card: Disabled
7) Program CS8900 MAC address (00:11:22:33:44:55)
8) Kernel Debugger: ENABLED
D) Download image now
U) DOWNLOAD image now(USB)
R) Read Configuration
Enter your selection:
这是什么情况,是没有bootloder了吗?
发表于 2011-8-12 13:03:45 | 显示全部楼层
有bootloader,wince的xip有问题吧~
重新烧写xip吧~
17
RK3399通行证
 楼主| 发表于 2011-8-12 15:45:21 | 显示全部楼层
如果我用拔码开关让linux自启动应该可以吧!必须重新烧写xip吗?
发表于 2011-8-12 16:57:04 | 显示全部楼层
必须烧
GMT+8, 2026-10-6 08:46
