查看: 26986|回复: 3
[Linux] imx6ul制作SD卡启动问题
发表于 2021-11-10 14:35:50 | 显示全部楼层 |阅读模式
SD卡在windows用sd_formtter格式化后,在linux执行sudo ./create-sdcard.sh后,没有生成boot文件夹。制作终端打印log为
root@100ask:/home/book/work/imx6ul/createSdcard# ./createSdcard.sh
This script will create a bootable SD card from custom or pre-built binaries.
The script must be run with root permissions and from the bin directory of
the SDK
Example:
$ sudo ./create-sdcard.sh
Formatting can be skipped if the SD card is already formatted and
partitioned properly.
1:   8       16   15558144 sdb
Enter Device Number: 1
sdb was selected
Checking the device is unmounted
unmounted /dev/sdb1
sdb1  sdb2   sdb3
15554048
   Detected device has 1 partitions already
   Re-partitioning will allow the choice of 1 partitions
Would you like to re-partition the drive anyways [y/n] : y
Now partitioning sdb ...
                Now ** 1 partitions
1+0 records in
1+0 records out
1024 bytes (1.0 kB, 1.0 KiB) copied, 0.00890667 s, 115 kB/s
DISK SIZE - 15931539456 bytes
sfdisk: unsupported unit 'M'
                Partitioning Boot
mkfs.fat 4.1 (2017-01-24)
mkfs.vfat: unable to open /dev/sdb1: No such file or directory
Mount the partitions
mount: /home/book/work/imx6ul/createSdcard/boot: special device /dev/sdb1 does not exist.
Emptying partitions
        Copying files now... will take minutes
Copying boot partition
untar update.tar.bz2 to boot partition
sdrun/
sdrun/u-boot.imx
sdrun/zImage
sdrun/imx6ul-14x14-evk.dtb
sdrun/ramdisk.img.u
target/
target/modules.tar.bz2
target/imx6ul-14x14-evk-emmc-c-bak.dtb
target/u-boot.imx
target/imx6ul-14x14-evk-emmc-c-10.4-800x600.dtb
target/rootfs.tar.bz2
target/logo.bmp
target/zImage
target/imx6ul-14x14-evk-emmc-c-7-1024x600.dtb
target/imx6ul-14x14-evk-emmc-c-8-800x600.dtb
target/imx6ul-14x14-evk-emmc-c-10.1-1280x800.dtb
target/imx6ul-14x14-evk-emmc-c-5.6-640x480.dtb
target/imx6ul-14x14-evk-emmc-c-7-800x480.dtb
target/imx6ul-14x14-evk-emmc-c-3.5-320x240.dtb
target/imx6ul-14x14-evk-emmc-c-4.3-480x272.dtb
Buring th u-boot.imx to sdcard
129+0 records in
129+0 records out
132096 bytes (132 kB, 129 KiB) copied, 0.157855 s, 837 kB/s
371+0 records in
371+0 records out
379904 bytes (380 kB, 371 KiB) copied, 0.373231 s, 1.0 MB/s
Syncing....
Un-mount the partitions
umount: boot: not mounted.
Operation Finished
 楼主| 发表于 2021-11-10 17:56:04 | 显示全部楼层
使用的ubuntu是18.4的,按照官方的指南烧写的SD卡
whl
由于Ubuntu版本不同,需要修改一下制卡脚本。参考这边知识库修改一下,把卡重新格式化,再重新制卡 http://bbs.witech.com.cn/article-415-1.html  详情 回复 发表于 2021-11-11 08:38
发表于 2021-11-11 08:38:51 | 显示全部楼层
感谢,可以了  详情 回复 发表于 2021-11-11 11:10
 楼主| 发表于 2021-11-11 11:10:29 | 显示全部楼层
http ...
感谢,可以了
:victory:
GMT+8, 2026-10-4 10:26
