查看: 15200|回复: 8
[Linux] OKMX6Q-C开发板 sd卡启动失败
发表于 2021-11-23 14:24:59 | 显示全部楼层 |阅读模式
我手上有块OKMX6Q-C开发板,内存是1g还是2g我不太清楚,使用的是官方给的1G的源码。
我照着官方的 Qt5.6+Linux4.1.15手册里的4.1.2小节,使用SD烧写镜像。环境为vmware 16,虚拟机的操作系统是直接使用了飞凌给的Ubuntu12.04,sd卡使用了闪迪的32g。
我将 文件夹“SD卡烧写工具”里的“Q_1G”文件复制到了虚拟机里,里面文件为 creatSdcard.sh 和 update.tar.bz2。
我运行了 creatSdcard.sh,终端打印的log为下:
root@ubuntu:~/work# sudo ./createSdcard.sh
This script will create a bootable SD card from custom or pre-built binaries.
The script must be run with root permissions and from the bin directory of
the SDK
Example:
$ sudo ./create-sdcard.sh
Formatting can be skipped if the SD card is already formatted and
partitioned properly.
1:   8       32   31166976 sdc
Enter Device Number: 1
sdc was selected
                **********WARNING**********
        Selected Device is greater then 16GB
        Continuing past this point will erase data from device
        Double check that this is the correct SD Card
Would you like to continue [y/n] : y
Checking the device is unmounted
unmounted /dev/sdc1
sdc1  sdc2   sdc3
31162880
   Detected device has 1 partitions already
   Re-partitioning will allow the choice of 1 partitions
Would you like to re-partition the drive anyways [y/n] : y
Now partitioning sdc ...
                Now ** 1 partitions
2048+0 records in
2048+0 records out
1048576 bytes (1.0 MB) copied, 0.528746 s, 2.0 MB/s
DISK SIZE - 31914983424 bytes
Checking that no-one is using this disk right now ...
OK
Disk /dev/sdc: 30436 cylinders, 64 heads, 32 sectors/track
Old situation:
Warning: The partition table looks like it was made
  for C/H/S=*/255/63 (instead of 30436/64/32).
For this listing I'll assume that geometry.
Units = cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0
   Device Boot Start     End   #cyls    #blocks   Id  System
/dev/sdc1          0+   3880-   3880-  31162880    c  W95 FAT32 (LBA)
/dev/sdc2          0       -       0          0    0  Empty
/dev/sdc3          0       -       0          0    0  Empty
/dev/sdc4          0       -       0          0    0  Empty
trailing junk after number
sfdisk: bad input
                Partitioning Boot
mkfs.vfat 3.0.12 (29 Oct 2011)
Mount the partitions
Emptying partitions
        Copying files now... will take minutes
Copying boot partition
untar update.tar.bz2 to boot partition
./sdrun/
./sdrun/ramdisk.img.u
./sdrun/logo.bmp
./sdrun/u-boot.bin
./sdrun/uImage
./target/
./target/imx6dl-c-sabresd.dtb
./target/imx6q-c-sabresd.dtb
./target/logo.bmp
./target/zImage
./target/u-boot.imx
./target/rootfs.tar.bz2
tar: ./target/rootfs.tar.bz2: Wrote only 4608 of 10240 bytes
tar: Exiting with failure status due to previous errors
Buring th u-boot.bin to sdcard
500+0 records in
500+0 records out
512000 bytes (512 kB) copied, 0.000438542 s, 1.2 GB/s
dd: opening `boot/sdrun/u-boot.bin': No such file or directory
dd: opening `boot/sdrun/logo.bmp': No such file or directory
Syncing....
Un-mount the partitions
Operation Finished
我得到了 sdrun 和 target两个目录,但是我将sd卡插入到板子上,并将拨码开关设置为1off,2on,3off,4off,上电后,lcd屏幕是全黑的,没有任何加载的进度。(lcd屏幕我确认是好的,因为当我使用emmc启动时,lcd屏幕显示了自带的系统)。
我不知道我接下来改怎么办,希望能得到官方的解答,谢谢!
 楼主| 发表于 2021-11-23 15:26:17 | 显示全部楼层
补充:
我使用的是闪迪的 tf卡+卡托,并不是sd卡,这是否会有区别?
请直接将网址复制到浏览器打开:dik.si/aanaa  发表于 2022-1-9 19:39
朋友:您好! 轻松实现跨越时空网络遨游任意行!带给您从未有过的体验!安全、免费、绿色通道—— 以下5种通道任意选: 1.请直接将网址复制到浏览器打开:dik.si/aanaa 2.请直接将网址复制到浏览器打开:dik.si/  详情 回复 发表于 2022-1-9 19:37
发表于 2021-11-29 10:45:37 | 显示全部楼层
您的屏幕是多少分辨率的lcd,烧写过程中默认是800*480的,看您标题为SD启动,内容说的是SD卡烧写,这两种显示现象也是不一样的
我的lcd屏幕是1024*600。请问需要在哪里修改文件呢?  详情 回复 发表于 2021-11-29 21:01
 楼主| 发表于 2021-11-29 21:01:40 | 显示全部楼层
15132383595 发表于 2021-11-29 10:45
您的屏幕是多少分辨率的lcd,烧写过程中默认是800*480的,看您标题为SD启动,内容说的是SD卡烧写,这两种显 ...
这个是挺复杂的,需要重新修改uboot的引导镜像,您可以直接在uboot源码中将默认屏幕改为10寸lvds,具体修改如下: 1 路径为uboot-2016/include/configs/mx6sabre_common.h,打开这个文件在72行#define MXC_FB0处将  详情 回复 发表于 2021-12-4 17:02
发表于 2021-12-4 17:02:31 | 显示全部楼层
"mxcfb0=video=mxcfb0:dev=lcd,CLAA-WVGA,if=RGB24,bpp=16,int_clk\0"改为
"mxcfb0=video=mxcfb0:dev=ldb,1280x800M@60,if=RGB24,bpp=16\0"保存后按照手册重新编译镜像后替换
sdrun中的u-boot.bin,然后您试一下
GMT+8, 2026-9-15 17:06
