查看: 10253|回复: 3
[Linux] T3,新建文件出错,最大文件数的限制
发表于 2021-11-28 22:37:30 | 显示全部楼层 |阅读模式
今天尝试在T3的linux文件目录中,新建1000个状态文件,当新建数超过900多时,返回错误。
网上查了一下,好像说是inode占用满了,但尝试使用df -i命令查看inode占用情况,发现T3的linux不支持该命令。
请问,不能新建更多的文件,是因为inode的关系吗?有什么解决办法吗?
ps:测试了一下,此种情况下,删除n个其他文件,就可以再多新建n个文件。而且确定不是空间不足。
发表于 2021-11-29 09:55:10 | 显示全部楼层
您用的资料不是最新的吧,我们最新的资料已经没有inode的问题了,您可以换一下试试
发表于 2021-11-29 17:51:01 | 显示全部楼层
可以试试dumpe2fs -h 后边加路径
例如:
root@forlinx:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/mmcblk0p4  5.9G  4.4G  1.5G  75% /
devtmpfs        985M     0  985M   0% /dev
tmpfs           994M     0  994M   0% /dev/shm
tmpfs           994M  1.1M  993M   1% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           994M     0  994M   0% /sys/fs/cgroup
tmpfs           199M  4.0K  199M   1% /run/user/1000
/dev/mmcblk0p6  1.1G  2.9M 1022M   1% /media/forlinx/data
/dev/mmcblk0p1  128M  5.4M  123M   5% /media/forlinx/Volumn
tmpfs           199M     0  199M   0% /run/user/0
root@forlinx:~# dumpe2fs -h /dev/mmcblk0p4
dumpe2fs 1.44.1 (24-Mar-2018)
Filesystem volume name:   <none>
Last mounted on:          /
Filesystem UUID:          57f8f4bc-abf4-655f-bf67-946fc0f9f25b
Filesystem magic number:  0xEF53
Filesystem revision #:    1 (dynamic)
Filesystem features:      has_journal ext_attr resize_inode filetype needs_recovery extent sparse_super large_file uninit_bg
Filesystem flags:         unsigned_directory_hash
Default mount options:    (none)
Filesystem state:         clean
Errors behavior:          Remount read-only
Filesystem OS type:       Linux
Inode count:              393216
Block count:              1572864
Reserved block count:     0
Free blocks:              386203
Free inodes:              281326
First block:              0
Block size:               4096
Fragment size:            4096
Reserved GDT blocks:      383
Blocks per group:         32768
Fragments per group:      32768
Inodes per group:         8192
Inode blocks per group:   512
Last mount time:          Mon Nov 29 16:06:57 2021
Last write time:          Mon Nov 29 16:06:57 2021
Mount count:              4
Maximum mount count:      -1
Last checked:             Thu Jan  1 08:00:00 1970
Check interval:           0 (<none>)
Reserved blocks uid:      0 (user root)
Reserved blocks gid:      0 (group root)
First inode:              11
Inode size:               256
Required extra isize:     28
Desired extra isize:      28
Journal inode:            8
Default directory hash:   tea
Journal backup:           inode blocks
Journal features:         journal_incompat_revoke
Journal size:             96M
 楼主| 发表于 2022-1-14 14:57:33 | 显示全部楼层
好的,我试一下,谢谢
GMT+8, 2026-9-21 06:18
