查看: 12344|回复: 7
libncurses5-dev在哪里
发表于 2011-9-14 09:20:54 | 显示全部楼层 |阅读模式
Android用户手册上说到安装
libncurses5
但执行命令时说:没发现软件包libncurses
发表于 2011-9-14 10:21:36 | 显示全部楼层
在手册前面有说明,下载的那个几个包中有这个
 楼主| 发表于 2011-9-14 13:37:58 | 显示全部楼层
哪本手册,我看的是android 2.3.6,第50页
 楼主| 发表于 2011-9-14 13:42:57 | 显示全部楼层
我看到了!
 楼主| 发表于 2011-9-14 15:46:17 | 显示全部楼层
终于配置好网络了,但还是不行。
安装一大堆库,老是说:没发现软件包XXXXXX
 楼主| 发表于 2011-9-14 16:29:37 | 显示全部楼层
编译时:
/android2.3.4_32bit# ./build-android
including device/htc/passion/vendorsetup.sh
including device/samsung/crespo/vendorsetup.sh
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=2.3.4
TARGET_PRODUCT=OK6410
TARGET_BUILD_VARIANT=eng
TARGET_SIMULATOR=false
TARGET_BUILD_TYPE=release
TARGET_BUILD_APPS=
TARGET_ARCH=arm
HOST_ARCH=x86
HOST_OS=linux
HOST_BUILD_TYPE=release
BUILD_ID=GRJ06D
/bin/bash: bison:找不到命令
Checking build tools versions...
find: `frameworks/base/frameworks/base/docs/html': 没有那个文件或目录
find: `out/target/common/docs/gen': 没有那个文件或目录
diff: out/target/product/OK6410/obj/PACKAGING/updater_extensions_intermediates/register.inc.list: 没有那个文件或目录
build/core/Makefile:21: 警告:覆盖关于目标“out/target/product/OK6410/root/init.rc”的命令
system/core/rootdir/Android.mk:38: 警告:忽略关于目标“out/target/product/OK6410/root/init.rc”的旧命令
host Java: apicheck (out/host/common/obj/JAVA_LIBRARIES/apicheck_intermediates/classes)
Header: out/host/linux-x86/obj/include/libexpat/expat.h
Header: out/host/linux-x86/obj/include/libexpat/expat_external.h
Header: out/target/product/OK6410/obj/include/libexpat/expat.h
Header: out/target/product/OK6410/obj/include/libexpat/expat_external.h
Header: out/host/linux-x86/obj/include/libpng/png.h
Header: out/host/linux-x86/obj/include/libpng/pngconf.h
Header: out/host/linux-x86/obj/include/libpng/pngusr.h
Header: out/target/product/OK6410/obj/include/libpng/png.h
Header: out/target/product/OK6410/obj/include/libpng/pngconf.h
Header: out/target/product/OK6410/obj/include/libpng/pngusr.h
Header: out/target/product/OK6410/obj/include/libwpa_client/wpa_ctrl.h
Header: out/target/product/OK6410/obj/include/libsonivox/eas.h
Header: out/target/product/OK6410/obj/include/libsonivox/eas_types.h
Header: out/target/product/OK6410/obj/include/libsonivox/eas_reverb.h
Header: out/target/product/OK6410/obj/include/libsonivox/jet.h
Header: out/target/product/OK6410/obj/include/libsonivox/ARM_synth_constants_gnu.inc
host C: acp <= build/tools/acp/acp.c
host C++: libhost <= build/libs/host/pseudolocalize.cpp
/bin/bash: g++:找不到命令
make: *** [out/host/linux-x86/obj/STATIC_LIBRARIES/libhost_intermediates/pseudolocaliz目录
 楼主| 发表于 2011-9-14 16:38:24 | 显示全部楼层
sudo apt-get install get-core flex bison gperf libsdl-dev libesd0-dev
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
现在没有可用的软件包 flex,但是它被其它的软件包引用了。
这可能意味着这个缺失的软件包可能已被废弃,
或者只能在其他发布源中找到
现在没没有可用的软件包 bison,但是它被其它的软件包引用了。
或者只能在其他发布源中找到
E: 未发现软件包 get-core
E: 软件包 flex 没有可供安装的候选者
E: 软件包 bison 没有可供安装的候选者
 楼主| 发表于 2011-9-14 17:28:26 | 显示全部楼层
问题解决了,更新了source.list
但安装过程中又出现新问题:
软件包没满足依赖关系。
GMT+8, 2026-9-26 03:52
