查看: 4981|回复: 3
[Linux] 脚本打包镜像失败
发表于 2021-12-8 16:38:26 | 显示全部楼层 |阅读模式
使用脚本打包镜像出现  dl file rootfs.fex size too largeERROR: update_mbr failed,麻烦哪位大佬帮忙看看是啥问题,谢谢~!build buidroot-201611...
xgnueabihf
sun8iw11p1_hf_defconfig
INFO: packing firmware ...
copying tools file
copying configs file
./out/aultls32.fex
./out/aultools.fex
./out/boot_package.cfg
./out/boot_package.fex
./out/boot_package_nor.cfg
./out/cardscript.fex
./out/cardscript_secure.fex
./out/cardtool.fex
./out/diskfs.fex
./out/env.cfg
./out/env_burn.cfg
./out/image.cfg
renamed './out/image_linux.cfg' -> './out/image.cfg'
./out/split_**x.fex
./out/sunxi.fex
./out/sys_config.fex
./out/sys_config1024x600.fex
./out/sys_config1024x600_v1.fex
./out/sys_config1024x600mipi.fex
./out/sys_config1024x600mipi_v1.fex
./out/sys_config1080p.fex
./out/sys_config1080p_v1.fex
./out/sys_config1280x800.fex
./out/sys_config1280x800_v1.fex
./out/sys_config800x480.fex
./out/sys_config800x480_v1.fex
./out/sys_config_new_evb_lvds1024600.fex
./out/sys_partition_dump.fex
renamed './out/sys_partition_linux.fex' -> './out/sys_partition.fex'
./out/sys_partition_linux_128M.fex
./out/sys_partition_linux_256M.fex
./out/sys_partition_linux_mmc.fex
./out/sys_partition_private.fex
./out/toc0.fex
./out/toc1.fex
./out/usbtool.fex
./out/usbtool_test.fex
copying boot resource
copying boot file
p=soc c=product state=0
p=soc c=platform state=0
p=soc c=target state=0
p=soc c=norflash state=0
p=soc c=boot_init_gpio state=0
p=soc c=power_sply state=0
p=soc c=card_boot state=0
p=soc c=pm_para state=0
p=soc c=card0_boot_para state=0
p=soc c=card2_boot_para state=0
p=soc c=twi_para state=0
p=soc c=uart_para state=0
p=soc c=jtag_para state=0
p=soc c=clock state=0
p=soc c=dram state=0
p=soc c=emac0 state=0
p=soc c=gmac0 state=0
p=soc c=can0 state=0
p=soc c=can0 state=1
p=soc c=twi0 state=0
p=soc c=twi1 state=0
p=soc c=twi2 state=0
p=soc c=twi3 state=0
p=soc c=twi4 state=0
p=twi2 c=rx8010 state=0
p=twi4 c=at24 state=0
p=soc c=ir0 state=0
p=soc c=uart0 state=0
p=soc c=uart0 state=1
p=soc c=uart1 state=0
p=soc c=uart1 state=1
p=soc c=uart2 state=0
p=soc c=uart2 state=1
p=soc c=uart3 state=0
p=soc c=uart3 state=1
p=soc c=uart4 state=0
p=soc c=uart4 state=1
p=soc c=uart5 state=0
p=soc c=uart5 state=1
p=soc c=uart6 state=0
p=soc c=uart6 state=1
p=soc c=uart7 state=0
p=soc c=uart7 state=1
p=soc c=spi0 state=0
p=soc c=spi1 state=0
p=soc c=spi2 state=0
p=soc c=spi3 state=0
p=soc c=rtp_para state=0
p=soc c=ctp state=0
p=soc c=ctp_list state=0
p=soc c=tkey_para state=0
p=soc c=motor_para state=0
p=soc c=nand0 state=0
p=soc c=sata state=0
p=soc c=disp state=0
p=soc c=tv0 state=0
p=soc c=tv1 state=0
p=soc c=tvd state=0
p=soc c=tvd0 state=0
p=soc c=tvd1 state=0
p=soc c=tvd2 state=0
p=soc c=tvd3 state=0
p=soc c=lcd0 state=0
p=soc c=lcd0 state=1
p=soc c=pwm0 state=0
p=soc c=pwm0 state=1
p=soc c=car_reverse state=0
p=soc c=Transmit_fm state=0
p=soc c=hdmi state=0
p=soc c=ak7601 state=0
p=soc c=csi0 state=0
p=csi0 c=csi0_dev0 state=0
p=soc c=csi1 state=0
p=csi1 c=csi1_dev0 state=0
p=soc c=tvout_para state=0
p=soc c=tvin_para state=0
p=soc c=di state=0
p=soc c=sdc0 state=0
p=soc c=sdc1 state=0
p=soc c=sdc2 state=0
p=soc c=sdc3 state=0
p=soc c=smc state=0
p=soc c=gpio_para state=0
p=soc c=usbc0 state=0
p=soc c=usbc1 state=0
p=soc c=usbc2 state=0
p=soc c=gsensor_para state=0
p=soc c=gps_para state=0
p=soc c=ril_para state=0
p=soc c=wlan state=0
p=soc c=bt state=0
p=soc c=btlpm state=0
p=soc c=gy_para state=0
p=soc c=ls_para state=0
p=soc c=compass_para state=0
p=soc c=spdif state=0
p=soc c=sndspdif state=0
p=soc c=audiohdmi state=0
p=soc c=sndhdmi state=0
p=soc c=snddaudio0 state=0
p=soc c=daudio0 state=0
p=soc c=snddaudio1 state=0
p=soc c=daudio1 state=0
p=soc c=sndcodec state=0
p=soc c=codec state=0
p=soc c=pmu0 state=0
p=soc c=charger0 state=0
p=soc c=powerkey0 state=0
p=soc c=regulator0 state=0
p=soc c=axp_gpio0 state=0
p=soc c=dvfs_table state=0
p=soc c=Vdevice state=0
p=soc c=gpu_mali400_0 state=0
Conver script to dts ok.
dtbpath=/media/lzy/0000AC1F00080549/1/1/Linux/源码/lichee/tools/pack/out/sunxi.fex
update_fdt: u-boot.fex will merage sunxi.fex, generate u-boot.fex
---0xd0, 0xd
update_fdt: num 873244 randto1k
update_fdt: num 160928 randto1k
file1_len = d5400, file2_len = 29800
dtb offset d5400,size 29800
update_fdt:genrate /media/lzy/0000AC1F00080549/1/1/Linux/源码/lichee/tools/pack/out/u-boot.fex ok
ERROR: ld.so: object '/usr/lib/x86_64-linux-gnu/libgtk3-nocsd.so.0' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
pack boot package
GetPrivateProfileSection read to end
content_count=1
packing for linux
normal
partitation file Path=/media/lzy/0000AC1F00080549/1/1/Linux/源码/lichee/tools/pack/out/sys_partition.bin
mbr_name file Path=/media/lzy/0000AC1F00080549/1/1/Linux/源码/lichee/tools/pack/out/sunxi_mbr.fex
download_name file Path=/media/lzy/0000AC1F00080549/1/1/Linux/源码/lichee/tools/pack/out/dlinfo.fex
mbr size = 16384
mbr magic softw411
disk name=boot-resource
filename = boot-resource.fex
dl_file_size = 11432 sector
part_size = 28672 sector
disk name=env
filename = env.fex
dl_file_size = 256 sector
part_size = 8192 sector
disk name=boot
filename = boot.fex
dl_file_size = 27416 sector
part_size = 32768 sector
disk name=rootfs
unable to open file rootfs.fex
update_for_part_info -1
update mbr file fail
lzy@lzy:/media/lzy/0000AC1F00080549/1/1/Linux/源码/lichee$ ./build.sh pack
xgnueabihf
copying tools file
./out/aultls32.fex
./out/aultools.fex
./out/cardtool.fex
./out/diskfs.fex
./out/env.cfg
./out/env_burn.cfg
./out/image.cfg
./out/split_**x.fex
./out/sunxi.fex
./out/toc0.fex
./out/toc1.fex
./out/usbtool.fex
copying boot file
p=soc c=ir0 state=0
p=soc c=ctp state=0
p=soc c=tv0 state=0
p=soc c=tv1 state=0
p=soc c=tvd state=0
p=soc c=di state=0
p=soc c=smc state=0
p=soc c=bt state=0
---0xd0, 0xd
pack boot package
content_count=1
packing for linux
normal
mbr size = 16384
mbr magic softw411
disk name=env
filename = env.fex
disk name=boot
filename = boot.fex
disk name=rootfs
发表于 2021-12-8 17:20:33 | 显示全部楼层
dl file rootfs.fex size too large文件系统太大,一般是文件系统修改导致,或者改分区导致
没改过,就直接执行build.sh编译,然后打包的  详情 回复 发表于 2021-12-8 17:31
 楼主| 发表于 2021-12-8 17:31:44 | 显示全部楼层
发表于 2021-12-8 18:20:02 | 显示全部楼层
编译之前有删除out文件夹吗
GMT+8, 2026-9-22 06:54
