查看: 23503|回复: 4
[Linux] phy
发表于 2022-2-14 15:08:18 | 显示全部楼层 |阅读模式
重新设计的底板,网口phy更换为裕太的YT8512。系统启动后能正常识别mdio通讯正常,但是系统一直报link is up / link is down,并且无法ping完成,有知道是什么问题的吗:handshake
[ 1040.490160] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1041.570170] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1047.810307] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1048.890429] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1050.970355] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1072.570368] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1074.650160] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1075.730430] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1077.810289] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1083.210322] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1085.290312] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1087.450433] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1089.530319] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1090.610452] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1094.770315] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1104.490449] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1106.570241] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1118.450434] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1120.530318] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1133.490434] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1135.570280] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1142.050437] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1144.130244] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1152.770172] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1154.850242] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1161.330281] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1163.410176] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1187.170373] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1193.410160] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1194.490171] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1198.650160] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1205.130434] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1207.210306] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1219.090436] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1221.170206] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1230.890430] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1232.970160] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1239.450327] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1241.530314] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1251.250434] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1253.330313] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1259.810172] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1261.890159] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1265.130387] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1267.210330] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1275.850172] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1277.930160] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1281.170386] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1283.250315] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1290.810320] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
[ 1292.890314] libphy: 1c0b080.mdio-mii:01 - Link is Down
[ 1296.130288] libphy: 1c0b080.mdio-mii:01 - Link is Up - 10/Full
 楼主| 发表于 2022-2-14 15:15:53 | 显示全部楼层
系统启动日志
log.txt.zip
13.58 KB, 下载次数: 2, 下载积分: 贡献 1
系统启动日志
发表于 2022-2-14 17:37:20 | 显示全部楼层
您这个是百兆网口配置吗,打印信息里是mii,但是裕泰8521不是千兆网卡吗
我们选的这款是8512H手册里描述的是100M  详情 回复 发表于 2022-2-14 17:42
 楼主| 发表于 2022-2-14 17:42:16 | 显示全部楼层
发表于 2022-2-15 14:32:33 | 显示全部楼层
检查一下芯片的电路,看看外围电路,mdio总线是否有有问题,可以量一下波形
GMT+8, 2026-9-21 06:18
