查看: 9606|回复: 7
[Android] OV5640在安卓系统一拍照就卡住
A40i/T3/T507/T527通行证RK3506通行证
发表于 2022-4-9 17:10:54 | 显示全部楼层 |阅读模式
在安卓系统上打开相机,图像都正常。
点了拍照后,就卡住不动了。相机可以退出,安卓系统没有挂。
以下是串口的log,请飞凌工程师帮忙分析一下,谢谢
[   59.368042] ov5640 id:5640
[   59.371560] audit: audit_lost=1 audit_rate_limit=5 audit_backlog_limit=64
[   59.379254] audit: rate limit exceeded
[   59.792125] raw_flag value is 0
[   60.477240] ov5640 id:5640
[  114.592397] type=1400 audit(1649495157.763:44): avc: denied { read } for comm="HwBinder:2144_2" name="u:object_r:system_prop:s0" dev="tmpfs" ino=4771 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=0
[  114.616801] type=1400 audit(1649495211.636:45): avc: denied { read } for comm="CameraCommandTh" name="u:object_r:system_prop:s0" dev="tmpfs" ino=4771 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=0
[  117.171189] [VIN_ERR]vidioc_vb2_ioctl_qbuf:video2: buffer0 is used,cannot be qbuf!!
[  117.180202] [VIN_ERR]vidioc_vb2_ioctl_qbuf:video2: buffer1 is used,cannot be qbuf!!
[  117.189164] [VIN_ERR]vidioc_vb2_ioctl_qbuf:video2: buffer2 is used,cannot be qbuf!!
[  118.655076] type=1400 audit(1649495211.666:46): avc: denied { read } for comm="CameraCommandTh" name="u:object_r:system_prop:s0" dev="tmpfs" ino=4771 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=0
[  118.679847] type=1400 audit(1649495215.696:47): avc: denied { read } for comm="HwBinder:2144_2" name="u:object_r:system_prop:s0" dev="tmpfs" ino=4771 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=0
[  120.191240] type=1400 audit(1649495216.256:48): avc: denied { read } for comm="HwBinder:2144_2" name="u:object_r:system_prop:s0" dev="tmpfs" ino=4771 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=0
[  120.215855] type=1400 audit(1649495217.233:49): avc: denied { read } for comm="CameraPictrueTh" name="cedarc.conf" dev="dm-0" ino=900 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=0
[  126.035559] raw_flag value is 0
[  127.943015] type=1400 audit(1649495217.236:50): avc: denied { read } for comm="CameraPictrueTh" name="cedarc.conf" dev="dm-0" ino=900 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=0
[  127.966371] type=1400 audit(1649495224.986:51): avc: denied { read } for comm="HwBinder:2144_2" name="u:object_r:system_prop:s0" dev="tmpfs" ino=4771 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=0
 楼主| 发表于 2022-4-10 11:14:38 | 显示全部楼层
更正,没有彻底卡住,可以按返回键。
拍摄视频功能正常。
发表于 2022-4-11 09:10:15 | 显示全部楼层
您使用的是飞凌的开发板进行测试的吗?板子里烧写的是用户资料里的镜像吗?镜像是哪个版本的(什么时间的)?
就是T507的开发板,用的是我加过USB触摸驱动的镜像。现在我换用户资料里的试试。 摄像头是我原来有的OV5640  详情 回复 发表于 2022-4-11 09:11
 楼主| 发表于 2022-4-11 09:11:22 | 显示全部楼层
tanglu 发表于 2022-4-11 09:10
您使用的是飞凌的开发板进行测试的吗?板子里烧写的是用户资料里的镜像吗?镜像是哪个版本的(什么时间的) ...
摄像头是我原来有的OV5640
换用户资料里的这个镜像
OKT507-C(Android)用户资料-20211020\Android\镜像\t507_android10_okt507_uart0.img
md5是ab7c2357b3bd92d886ac22996fe0e3a8
更新现象描述:
拍照按钮变灰,不能点。相机软件没有卡死,从左向右滑能出来相机和视频的选择。
日志没变,一样的内容。
发表于 2022-4-13 09:01:56 | 显示全部楼层
您使用的是mipi 5640还是dvp5640?是从飞凌购买的吗?
上周从飞凌买的DVP的OV5640,已经到了。 硬件识别正常,在点拍照的时候,相同的现象: 拍照button变灰,相机软件没有挂,可以点返回,可以从左向右滑。  详情 回复 发表于 2022-4-22 17:18
DVP的OV5640,用的是我这原来就有的。 刚从飞凌买了一个,到了再试。  详情 回复 发表于 2022-4-13 11:18
 楼主| 发表于 2022-4-13 11:18:37 | 显示全部楼层
刚从飞凌买了一个,到了再试。
 楼主| 发表于 2022-4-22 17:18:20 | 显示全部楼层
发表于 2022-4-26 13:19:27 | 显示全部楼层
目前您是使用飞凌的开发板,使用飞凌的用户资料里边的镜像,参考用户使用手册里的方法,用相机的测试程序去测试时,选择拍照时,相机的标志变成灰色,无法点击吗?
GMT+8, 2026-10-4 12:20
