查看: 5461|回复: 1
[Linux] imx8mp uboot启动后停止
i.MX8MP通行证LS1028A通行证AM62x资料下载
发表于 2022-5-23 18:16:18 | 显示全部楼层 |阅读模式
单板:imx8mp
单板是从emmc 启动的,我想要查看u-boot 信息
下面是u-boot 的打印:
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from BOOTROM
image offset 0x0, pagesize 0x200, ivt offset 0x0
NOTICE:  BL31: v2.2(release):rel_imx_5.4.70_2.3.0-0-gf1d7187f2
NOTICE:  BL31: Built : 03:31:00, Apr  8 2021
Forlinx
U-Boot 2020.04-00005-g23b6e181f8-dirty (Jan 21 2022 - 08:24:05 +0000)
CPU:   i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 38C
Reset cause: POR
Model: Forlinx OK8MPlus LPDDR4 EVK board
DRAM:  4 GiB
MMC:   FSL_SDHC: 1, FSL_SDHC: 2
try kernel dtb
Error binding driver 'gpio_led': -22
Some drivers failed to bind
MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
lvds0_panel enable
mipi_panel_uboot enable
eth0 enable
eth1 enable
Loading Environment from MMC... *** Warning - bad CRC, using default environment
video link is full
  • -Video Link 0 (1024 x 600)
            [0] lcd-controller@32e80000, video
            [1] mipi_dsi@32e60000, video_bridge
            [2] mipi_panel_uboot, panel
  • -Video Link 1 (1280 x 800)
            [0] lcd-controller@32e90000, video
            [1] ldb@32ec005c, video_bridge
            [2] lvds0_panel, panel
    [ ]-Video Link 2
    In:    serial
    Out:   serial
    Err:   serial
    BuildInfo:
      - ATF f1d7187
      - U-Boot 2020.04-00005-g23b6e181f8-dirty
    switch to partitions #0, OK
    mmc2(part 0) is current device
    a1007 auth ok!
    flash target is MMC:2
    Net:   config yt8521
    eth0: ethernet@30be0000
    Fastboot: Normal
    Normal Boot
    Autoboot in 1 seconds    单板能在这里停住吗?
    28215808 bytes read in 637 ms (42.2 MiB/s)
    Booting from mmc ...
    67111 bytes read in 16 ms (4 MiB/s)
    ## Flattened Device Tree blob at 43000000
       Booting using the fdt blob at 0x43000000
       Using Device Tree in place at 0000000043000000, end 0000000043013626
  • 回复
    发表于 2022-5-27 14:59:04 | 显示全部楼层
    您可以在开机时在终端按空格键,这时会出现选项,选择1.可以对uboot进行操作
    GMT+8, 2026-9-14 01:43
