查看: 6682|回复: 4
[Ubuntu] LS1028A flex-build 全编译报错
LS1028A通行证
发表于 2022-6-30 19:16:20 | 显示全部楼层 |阅读模式
使用命令:flex-builder clean 和 flex-builder clean-rfs。
clean之后通过命令flex-builder -a arm64 -m ls1028ardb 重新全编译。
编译中报错:
    CC      common/main.o
make[3]: *** No rule to make target 'common/initcall.o', needed by 'common/built-in.o'.  Stop.
make[3]: *** Waiting for unfinished jobs....
make[5]: *** No rule to make target 'arch/arm/cpu/armv8/fsl-layerscape/nxp_a1006/a1006.o', needed by 'arch/arm/cpu/armv8/fsl-layerscape/nxp_a1006/nxp-a1006.o'.  Stop.
/home/forlinx/work/OK1028-linux-fs/packages/firmware/OK1028-linux-uboot/scripts/Makefile.build:432: recipe for target 'arch/arm/cpu/armv8/fsl-layerscape/nxp_a1006' failed
make[4]: *** [arch/arm/cpu/armv8/fsl-layerscape/nxp_a1006] Error 2
make[4]: *** Waiting for unfinished jobs....
make[5]: *** No rule to make target 'arch/arm/cpu/armv8/fsl-layerscape/nxp_a1007/a1007_crypto.o', needed by 'arch/arm/cpu/armv8/fsl-layerscape/nxp_a1007/nxp-a1007.o'.  Stop.
/home/forlinx/work/OK1028-linux-fs/packages/firmware/OK1028-linux-uboot/scripts/Makefile.build:432: recipe for target 'arch/arm/cpu/armv8/fsl-layerscape/nxp_a1007' failed
make[4]: *** [arch/arm/cpu/armv8/fsl-layerscape/nxp_a1007] Error 2
/home/forlinx/work/OK1028-linux-fs/packages/firmware/OK1028-linux-uboot/scripts/Makefile.build:432: recipe for target 'arch/arm/cpu/armv8/fsl-layerscape' failed
LS1028A通行证
 楼主| 发表于 2022-7-1 09:42:07 | 显示全部楼层
从日志结合代码看是编译uboot的时候arch/arm/cpu/armv8/fsl-layerscape/nxp_a1006/下没有对应c源文件, 可是为啥会没有对应源文件呢?是clean的时候clean掉了吗?
hai
​您是使用flex-builder clean时把加密芯片的源码删除了,您需要重新解压一下源码,在编译就没问题了。还有在重新全编译的时候是不需要使用flex-builder clean的以及 flex-builder clean-rfs的,直接使用flex-  详情 回复 发表于 2022-7-1 13:46
发表于 2022-7-1 13:46:59 | 显示全部楼层
leon10 发表于 2022-7-1 09:42
从日志结合代码看是编译uboot的时候arch/arm/cpu/armv8/fsl-layerscape/nxp_a1006/下没有对应c源文件, 可 ...
​您是使用flex-builder clean时把加密芯片的源码删除了,您需要重新解压一下源码,在编译就没问题了。还有在重新全编译的时候是不需要使用flex-builder clean的以及 flex-builder clean-rfs的,直接使用flex-builder -a arm64 -m ls1028ardb全编译即可。
好的,就是clean就会出现这样的问题对吗?  详情 回复 发表于 2022-7-1 19:17
LS1028A通行证
 楼主| 发表于 2022-7-1 19:17:16 | 显示全部楼层
hai 发表于 2022-7-1 13:46
​您是使用flex-builder clean时把加密芯片的源码删除了,您需要重新解压一下源码,在编译就没问题 ...
hai
是的,在重新全编译的时候不需要flex-builder clean  详情 回复 发表于 2022-7-4 08:51
发表于 2022-7-4 08:51:14 | 显示全部楼层
GMT+8, 2026-9-30 04:05
