查看: 6267|回复: 1
[Ubuntu] LS1028A全编译出错
i.MX6Q通行证i.MX6UL通行证LS1028A通行证AM335x通行证
发表于 2022-7-19 12:08:26 | 显示全部楼层 |阅读模式
编译命令:flex-builder -a arm64 -m ls1028ardb,错误提示:
Build kernel tools/perf  [Done]
make[1]: Leaving directory '/home/forlinx/work/linux/OK1028-linux-fs/packages/linux'
make: Leaving directory '/home/forlinx/work/linux/OK1028-linux-fs'
INSTRUCTION: mkflashscr
CONFIGLIST: build_lsdk.cfg
Image Name:
Created:      Mon Jul 18 20:55:01 2022
Image Type:   PowerPC Linux Script (uncompressed)
Data Size:    20999 Bytes = 20.51 kB = 0.02 MB
Load Address: 00000000
Entry Point:  00000000
Contents:
   Image 0: 20991 Bytes = 20.50 kB = 0.02 MB
/home/forlinx/work/linux/OK1028-linux-fs/build/images/flash_images.scr     [Done]
COMPONENT: bin_firmware
MACHINE: ls1028ardb
DESTARCH: arm64
make: Entering directory '/home/forlinx/work/linux/OK1028-linux-fs'
make[1]: Entering directory '/home/forlinx/work/linux/OK1028-linux-fs/packages/firmware'
fetch-git-tree fm_ucode
ls: cannot access '/home/forlinx/work/linux/OK1028-linux-fs/build/firmware/fm_ucode/*.bin': No such file or directory
Makefile:73: recipe for target 'fm_ucode' failed
make[1]: *** [fm_ucode] Error 2
make[1]: Leaving directory '/home/forlinx/work/linux/OK1028-linux-fs/packages/firmware'
Makefile:19: recipe for target 'bin_firmware' failed
make: *** [bin_firmware] Error 2
root@ubuntu:/home/forlinx/work/linux/OK1028-linux-fs#
 楼主| 发表于 2022-7-19 13:30:17 | 显示全部楼层
已经解决了,OK1028-linux-fs 目录必要在 ~/work/ 下,其它路径不行。
GMT+8, 2026-9-30 04:04
