查看: 5144|回复: 3
[Linux] A40i打包时遇到 ERROR: update_mbr failed 怎么解决
发表于 2022-8-7 07:15:58 | 显示全部楼层 |阅读模式
飞凌 A40i 的源码版本为 20201218,打包时遇到 ERROR: update_mbr failed,请教下怎么解决?dtbpath=/root/workspace/allwinner/A40i/bsp_more/bsp20201218/lichee/tools/pack/out/sunxi.fex
update_fdt: u-boot.fex will merage sunxi.fex, generate u-boot.fex
---0xd0, 0xd
update_fdt: num 844384 randto1k
update_fdt: num 157184 randto1k
file1_len = ce400, file2_len = 28800
dtb offset ce400,size 28800
update_fdt:genrate /root/workspace/allwinner/A40i/bsp_more/bsp20201218/lichee/tools/pack/out/u-boot.fex ok
pack boot package
GetPrivateProfileSection read to end
content_count=1
packing for linux
normal
mbr count = 4
partitation file Path=/root/workspace/allwinner/A40i/bsp_more/bsp20201218/lichee/tools/pack/out/sys_partition.bin
mbr_name file Path=/root/workspace/allwinner/A40i/bsp_more/bsp20201218/lichee/tools/pack/out/sunxi_mbr.fex
download_name file Path=/root/workspace/allwinner/A40i/bsp_more/bsp20201218/lichee/tools/pack/out/dlinfo.fex
mbr size = 16384
mbr magic softw411
disk name=boot-resource
filename = boot-resource.fex
dl_file_size = 10682 sector
part_size = 28672 sector
disk name=env
filename = env.fex
dl_file_size = 256 sector
part_size = 8192 sector
disk name=boot
filename = boot.fex
dl_file_size = 26100 sector
part_size = 32768 sector
disk name=rootfs
filename = rootfs.fex
dl_file_size = 4602784 sector
part_size = 4200000 sector
dl file rootfs.fex size too large
update_for_part_info -1
update mbr file fail
发表于 2022-8-8 09:29:38 | 显示全部楼层
disk name=rootfs
说明文件系统太大,超出分区大小了,看看您的文件系统能不能裁剪或者修改分区大小
您好。不是这个原因。改分区分配的空间有6G左右,不是分区太小。  详情 回复 发表于 2022-9-5 08:39
发表于 2022-8-16 09:41:49 | 显示全部楼层
学习下。。。
A40i/T3/T507/T527通行证i.MX6Q通行证RK3568通行证FCU2401通行证AM335x通行证
发表于 2022-9-5 08:39:06 | 显示全部楼层
zhichao 发表于 2022-8-8 09:29
disk name=rootfs
您好。不是这个原因。该分区分配的空间有6G左右,不是分区太小。
GMT+8, 2026-9-21 06:18
