查看: 3620|回复: 1
[Linux] 编译报错
发表于 2022-9-22 14:14:31 | 显示全部楼层 |阅读模式
编译报错
Copy rootfs for arm
rootfs_32bit.cpio_buildroot_201611.gz
  CHK     include/generated/uapi/linux/version.h
  CC      scripts/mod/empty.o
make[1]: 'include/generated/mach-types.h' is up to date.
  CC      scripts/mod/devicetable-offsets.s
  HOSTLD  scripts/dtc/dtc
/usr/bin/ld: scripts/dtc/dtc-parser.tab.o:(.bss+0x50): multiple definition of `yylloc'; scripts/dtc/dtc-lexer.lex.o:(.bss+0x0): first defined here
  CC      kernel/bounds.s
  MKELF   scripts/mod/elfconfig.h
  HOSTCC  scripts/mod/modpost.o
  HOSTCC  scripts/mod/sumversion.o
collect2: error: ld returned 1 exit status
make[2]: *** [scripts/Makefile.host:127: scripts/dtc/dtc] Error 1
make[1]: *** [scripts/Makefile.build:455: scripts/dtc] Error 2
make[1]: *** Waiting for unfinished jobs....
  GEN     scripts/mod/devicetable-offsets.h
  GEN     include/generated/bounds.h
  HOSTCC  scripts/mod/file2alias.o
  CC      arch/arm/kernel/asm-offsets.s
  GEN     include/generated/asm-offsets.h
  CALL    scripts/checksyscalls.sh
  HOSTLD  scripts/mod/modpost
make: *** [Makefile:521: scripts] Error 2
ERROR: build kernel Failed
发表于 2022-9-23 11:36:31 | 显示全部楼层
make distclean 清空一下linux-3.10里的中间文件,还不行的话就看看是否有什么修改导致
GMT+8, 2026-9-21 06:19
