查看: 5164|回复: 1
[Linux] MUC SDK编译出错
A40i/T3/T507/T527通行证i.MX8MP通行证T113i通行证
发表于 2022-10-12 11:13:39 | 显示全部楼层 |阅读模式
按照OKMX8MPQ-C_MCU手册_V1.0_2021.08.25上面编译MCU SDK出错,报错信息如下-- TOOLCHAIN_DIR: /usr
-- BUILD_TYPE: ddr_release
-- The ASM compiler identification is unknown
-- Found assembler: /usr/bin/arm-none-eabi-gcc
CMake Error at CMakeLists.txt:10 (ENABLE_LANGUAGE):
  The CMAKE_ASM_COMPILER:
  is not a full path to an existing compiler tool.
  Tell CMake where to find the compiler by setting either the environment
  variable "ASM" or the CMake cache entry CMAKE_ASM_COMPILER to the full path
  to the compiler, or to the compiler name if it is in the PATH.
-- Warning: Did not find file Compiler/-ASM
-- Configuring incomplete, errors occurred!
See also "/home/forlinx/work/OK8MP-linux-sdk/OK8MP-FreeRTOS/boards/evkmimx8mp/demo_apps/hello_world/armgcc/CMakeFiles/CMakeOutput.log".
See also "/home/forlinx/work/OK8MP-linux-sdk/OK8MP-FreeRTOS/boards/evkmimx8mp/demo_apps/hello_world/armgcc/CMakeFiles/CMakeError.log".
make: *** No targets specified and no makefile found.  Stop.
发表于 2022-10-12 15:49:13 | 显示全部楼层
您好,需要看一下您具体的操作步骤,单看报错结果不好排查问题。您方便的话可以将您的操作步骤发送到我们的邮箱linux@forlinx.com 标明您所使用的平台,效率更高。
GMT+8, 2026-9-14 01:39
