查看: 3611|回复: 2
[Linux] ov5645 mipi测试
i.MX8MM通行证i.MX8MP通行证RK3568通行证RK3588通行证RK3576通行证RK3562通行证RK3506通行证T536通行证
发表于 2023-3-6 13:18:50 | 显示全部楼层 |阅读模式
你好,
我用IMX8MP开发板接上0V5645的摄像头进行测试,没有图像输出,打印信息如下:
root@OK8MP:~# gst-launch-1.0 v4l2src device=/dev/video0 io-mode=2 ! video/x-raw, format=YUY2, width=640, height=480,fram
erate=30/1 ! imxvideoconvert_g2d ! queue ! video/x-raw, format=RGB16, width=640, height=480 ! waylandsink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
../../../../git/libs/gst/base/gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
ERROR: pipeline doesn't want to preroll.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
root@OK8MP:~#
root@OK8MP:~#
请问这一般是什么问题。
TKS
发表于 2023-3-9 09:36:08 | 显示全部楼层
您输出的分辨率不对吧,ov5645只支持1280x960和1920x1080,您可以按照手册中的命令进行测试。在用户使用手册,5.6.2章节。
GMT+8, 2026-9-14 01:43
