查看: 5169|回复: 4
[Linux] OK3568 CAN无法接收
RK3568通行证
发表于 2023-3-23 09:44:44 | 显示全部楼层 |阅读模式
CAN无法接收
#define CAN0_DEV "can0"         //CAN设备映射节点
/**  打开CAN0**/
#define IP_CMD_CAN_OPEN            "ifconfig can0 up"
/**  将CAN0波特率设置为500000 bps**/
#define IP_CMD_SET_CAN_PARAMS      "ip link set can0 up type can bitrate 500000 sample-point 0.75 dbitrate 4000000 dsample-point 0.8 fd on"
/**  关闭CAN0**/
#define IP_CMD_CAN_CLOSE           "ifconfig can0 down"
int can_init(char *dev)
        struct ifreq ifr = {0};
        struct sockaddr_can can_addr = {0};
        int ret;
        /**  通过system调用ip命令设置CAN波特率**/
        system(IP_CMD_CAN_CLOSE);          // 必须先关闭CAN,才能成功设置CAN波特率
        system(IP_CMD_SET_CAN_PARAMS);
        system(IP_CMD_CAN_OPEN);
        printf("Set can baud rate success\n");
        /**  打开套接字**/
        can_fd = socket(PF_CAN, SOCK_RAW, CAN_RAW);
        if(0 > can_fd) {
                perror("socket");
                return -1;
        printf("Open socket success\n");
        /** 是否开启回环功能**/
        int loopback = 0;   // 0 = disabled, 1 = enabled (default)
        setsockopt(can_fd, SOL_CAN_RAW, CAN_RAW_LOOPBACK, &loopback, sizeof(loopback));
        /**  指定can0设备**/
        strcpy(ifr.ifr_name, CAN0_DEV);
        ret = ioctl(can_fd, SIOCGIFINDEX, &ifr);
        if(0 > ret){
                perror("SIOCGIFINDEX");
                close(can_fd);
                return -1;
        can_addr.can_family = AF_CAN;
        can_addr.can_ifindex = ifr.ifr_ifindex;
        printf("Iotcl SIOCGIFINDEX success\n");
        /**  将can0与套接字进行绑定**/
        ret = bind(can_fd, (struct sockaddr *)&can_addr, sizeof(can_addr));
        if (0 > ret) {
                perror("bind");
                close(can_fd);
                return -1;
        printf("Bind can success\n");
        /**  设置过滤规则**/
        setsockopt(can_fd, SOL_CAN_RAW, CAN_RAW_FILTER, NULL, 0);           //禁用过滤规则
        printf("Setsockopt success\n");
        return 0;
int main(void)
        struct can_frame frame = {0};
        int nread, i, ret, len;
        struct sockaddr_can addr;
    printf("Welcome to can test\n");
        if(can_init(CAN0_DEV) == FALSE){
                printf("Failed to can initial\n");
                return -1;
        printf("Can initial success\n");
        while(1)
                nread = read(can_fd, &frame, sizeof(frame));
                if(nread > 0)
                        printf("[%d] ", frame.can_dlc);
                        /**  打印数据**/
                        for (i = 0; i < frame.can_dlc; i++)
                                printf("%02x ", frame.data[i]);
                        printf("\n");
                        nread = 0;
//    close(can_fd);
//        return 0;
发表于 2023-3-23 10:25:42 | 显示全部楼层
首先确认您手上的底板CAN功能是否正常,短接两路can的H和H、L和L,使用命令行candump命令和cansend命令测试本身通讯是否正常,借此确认一下是您手上底板的硬件问题还是您应用用法的问题。
使用candump和cansend进行测试,正常;但还是不能接收  详情 回复 发表于 2023-4-14 11:33
RK3568通行证
 楼主| 发表于 2023-4-14 11:33:56 | 显示全部楼层
兵兵兵兵鸭 发表于 2023-3-23 10:25
首先确认您手上的底板CAN功能是否正常,短接两路can的H和H、L和L,使用命令行candump命令和cansend命令测试 ...
发表于 2023-4-19 18:59:05 | 显示全部楼层
运行有什么报错吗?将if(can_init(CAN0_DEV) == FALSE)改为if(can_init(CAN0_DEV) != 0)吧
发表于 2023-4-19 19:01:18 | 显示全部楼层
可以看下https://www.cnblogs.com/eaggle/p/7651856.html这个连接,或许对你有所帮助
GMT+8, 2026-9-21 03:38
