查看: 3773|回复: 2
[Android] uuu烧录失败
i.MX8MM通行证i.MX8MP通行证FDU070K02\FDU101K02通行证
发表于 2023-4-9 23:52:25 | 显示全部楼层 |阅读模式
uuu烧录失败
一直卡在这
串口日志如下:
U-Boot SPL 2018.03 (Mar 30 2022 - 00:56:08 +0000)
power_bd71837_init
DRAM PHY training for 2400MTS
check ddr4_pmu_train_imem code
check ddr4_pmu_train_imem code pass
check ddr4_pmu_train_dmem code
check ddr4_pmu_train_dmem code pass
Training PASS
DRAM PHY training for 400MTS
Training PASS
DRAM PHY training for 100MTS
Training PASS
Training PASS
DS2460 error
secure check passed
Normal Boot
Trying to boot from USB SDP
SDP: initialize...
SDP: handle requests...
Downloading file of size 714492 to 0x40400000... done
Jumping to header at 0x40400000
Header Tag is not an IMX image
U-Boot 2018.03 (Mar 30 2022 - 00:56:08 +0000)
CPU:   Freescale i.MX8MMQ rev1.0 1800 MHz (running at 1200 MHz)
CPU:   Commercial temperature grade (0C to 95C) at 43C
Reset cause: POR
Model: FSL i.MX8MM EVK board
DRAM:  2 GiB
Loading Environment from MMC... OK
In:    serial
Out:   serial
Err:   serial
BuildInfo:
  - ATF 513e828
  - U-Boot 2018.03
switch to partitions #0, OK
mmc0 is current device
Detect USB boot. Will enter fastboot mode!
flash target is MMC:0
Net:   config yt8521
eth0: ethernet@30be0000
cannot get the partion info for misc
idx 0, ptn 0 name='gpt' start=0 len=2048
idx 1, ptn 0 name='' start=0 len=0
idx 2, ptn 0 name='m4_os' start=10240 len=512
idx 3, ptn 0 name='all' start=0 len=8054784
idx 4, ptn 0 name='bootloader0' start=66 len=8192
idx 5, ptn 1 name='mmcsda1' start=16384 len=8038400
Cannot find partition 4080
do_raw_read failed, ret 1
read_bootctl, bcb_rw_block read failed
read command failed
Fastboot: Normal
Boot from USB for mfgtools
environment is too large
## Baudrate may not be deleted
gpio@30200000: dir_output: error: gpio GPIO1_1 not reserved
fsl_read_from_partition_multi: no misc partition
avb_ab_flow.c:99: ERROR: Error reading A/B metadata.
fsl_avb_ab_flow.c:461: ERROR: I/O error while loading A/B metadata.
fsl_write_to_partition: no misc partition
avb_ab_flow.c:128: ERROR: Error writing A/B metadata.
发表于 2023-4-10 09:00:05 | 显示全部楼层
您烧写的是飞凌发布的出厂镜像还是自己编译生成的镜像?
 楼主| 发表于 2023-4-10 10:10:52 | 显示全部楼层
自己编译产生的镜像和出长的镜像都不行
GMT+8, 2026-9-14 01:39
