查看: 4080|回复: 7
[Linux] qt5.9 qtvirtualkeyboard qtwebengine
发表于 2023-4-24 14:48:00 | 显示全部楼层 |阅读模式
提供的qt-5.9.0 里面未包含 组件。
是否需要重新编译?
发表于 2023-4-25 09:04:36 | 显示全部楼层
源码的buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/里边有qtvirtualkeyboard的源码和相关库文件。您可以编译出来,这个是英文的输入法应用。
您好,请问,qtwebengine 如何编译? 5.9.9 按照5.9.0的编译条件报错!  详情 回复 发表于 2023-4-26 10:38
 楼主| 发表于 2023-4-25 11:25:29 | 显示全部楼层
您好,请问,qtwebengine 在5.9.0的版本上是不是不能生成?
 楼主| 发表于 2023-4-25 14:38:36 | 显示全部楼层
  Windows Media Foundation ............... no
Qt WebEngine:
  Embedded build ......................... yes
  Pepper Plugins ......................... no
  Printing and PDF ....................... no
  Proprietary Codecs ..................... no
  Spellchecker ........................... yes
  WebRTC ................................. no
  Using system ninja ..................... no
  ALSA ................................... yes
  PulseAudio ............................. no
  System libraries:
    re2 .................................. no
    ICU .................................. no
    libwebp and libwebpdemux ............. no
    Opus ................................. no
    ffmpeg ............................... no
Note: Also available for Linux: linux-clang linux-icc
Note: PKG_CONFIG_LIBDIR automatically set to /home/yanglei/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.9/../../..//out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/pkgconfig:/home/yanglei/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.9/../../..//out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/share/pkgconfig:/home/yanglei/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.9/../../..//out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/pkgconfig
Note: PKG_CONFIG_SYSROOT_DIR automatically set to /home/yanglei/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.9/../../..//out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot
Note: -optimized-tools is not useful in -release mode.
Note: No wayland-egl support detected. Cross-toolkit compatibility disabled.
WARNING: Feature qqnx_pps is insignificant in this configuration, ignoring related command line option(s).
WARNING: Feature lgmon is insignificant in this configuration, ignoring related command line option(s).
WARNING: Feature qqnx_imf is insignificant in this configuration, ignoring related command line option(s).
WARNING: Feature xcb-xlib is insignificant in this configuration, ignoring related command line option(s).
WARNING: Feature xinput2 is insignificant in this configuration, ignoring related command line option(s).
ERROR: Feature 'eglfs' was enabled, but the pre-condition '!config.android && !config.darwin && !config.win32 && features.egl' failed.
5.9.9 编译 Qt WebEngine 报错
 楼主| 发表于 2023-4-26 10:38:47 | 显示全部楼层
zhichao 发表于 2023-4-25 09:04
源码的buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/里边有qtvirtualkeyboard的源码和相关库文 ...
发表于 2023-4-26 10:59:28 | 显示全部楼层
您看看具体报什么错,qt版本不一致可能对应的库文件不一致。根据报错信息排查问题原因
从http://mirrors.ustc.edu.cn/qtproject/archive/qt/5.9/5.9.0/single/qt-everywhere-opensource-src-5.9.0.tar.xz 下载了源码,放到了/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0 参考OKA40i-全源  详情 回复 发表于 2023-4-26 11:58
5.9.9 编译参数参考的 5.9.0 Note: PKG_CONFIG_LIBDIR automatically set to /home/yanglei/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.9/../../..//out/sun8iw11p1/linux/common/buildroot/hos  详情 回复 发表于 2023-4-26 11:08
 楼主| 发表于 2023-4-26 11:08:59 | 显示全部楼层
5.9.9 编译参数参考的 5.9.0
 楼主| 发表于 2023-4-26 11:58:28 | 显示全部楼层
参考OKA40i-全源码编译_应用笔记_V1.0.pdf 步骤,同样的错误。
你们这边可以用我的流程模拟一遍。
GMT+8, 2026-9-21 06:19
