查看: 3039|回复: 0
[Linux] 烧录的desktop ubuntu .img文件 firefox播放视频一直报错
RK3568通行证
发表于 2023-6-30 14:43:53 | 显示全部楼层 |阅读模式
[18628.666791] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18628.666946] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18628.985841] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18628.986064] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18629.669810] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18629.670026] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18632.366841] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18632.366935] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.209854] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.209985] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.283459] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.283628] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.325689] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.325791] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.712773] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.712902] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.745744] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.745886] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.759874] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.760004] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.792769] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.792915] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.804614] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.804789] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.821274] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.821507] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.825333] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18633.825444] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18634.088711] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18634.088859] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18635.730297] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18635.730359] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18635.767900] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18635.768004] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18635.929428] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18635.929521] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
[18635.930124] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
GMT+8, 2026-9-21 03:43
