查看: 3112|回复: 2
[硬件咨询] RK3568使用TF卡烧写失败
A40i/T3/T507/T527通行证RK3568通行证
发表于 2023-8-23 10:54:27 | 显示全部楼层 |阅读模式
按照用户手册5.2 TF卡烧写系统步骤来制作TF卡,查到OK3568-C主板上,启动起来后不进行烧写。请帮忙看下什么问题?
DDR Version V1.11 20211103
In
ddrconfig:15
DDR4, 324MHz
BW=32 Col=10 Bk=4 BG=2 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
tdqss: cs0 dqs0: -24ps, dqs1: -48ps, dqs2: -72ps, dqs3: -96ps,
change to: 324MHz
clk skew:0x6b
PHY drv:clk:37,ca:37,DQ:37,odt:0
vrefinner:50%, vrefout:50%
dram drv:34,odt:0
change to: 528MHz
clk skew:0x6b
PHY drv:clk:37,ca:37,DQ:37,odt:139
vrefinner:50%, vrefout:61%
dram drv:34,odt:120
change to: 780MHz
clk skew:0x6b
dram drv:34,odt:120
change to: 1560MHz(final freq)
clk skew:0x6b
dram drv:34,odt:120
cs 0:
the read training result:
DQS0:0x33, DQS1:0x2e, DQS2:0x2a, DQS3:0x31,
min  : 0xe 0x10  0xe  0xd  0x1  0x7  0x5  0x3 , 0xc  0xd  0x3  0x9  0xa  0xf  0xc  0xb ,
       0x3  0x7  0xa  0xc  0x5  0x1  0x4  0x4 , 0xd  0x9  0x8  0x2  0x7  0xc  0xc  0xa ,
mid  :0x29 0x29 0x28 0x26 0x1c 0x21 0x20 0x1e ,0x26 0x27 0x1b 0x23 0x23 0x28 0x26 0x24 ,
      0x1f 0x22 0x26 0x25 0x1f 0x1d 0x1e 0x1f ,0x27 0x24 0x22 0x1d 0x23 0x27 0x24 0x26 ,
max  :0x44 0x42 0x42 0x3f 0x38 0x3b 0x3b 0x39 ,0x41 0x41 0x34 0x3d 0x3d 0x41 0x41 0x3e ,
      0x3b 0x3d 0x42 0x3e 0x39 0x3a 0x39 0x3b ,0x42 0x3f 0x3d 0x39 0x3f 0x42 0x3d 0x42 ,
range:0x36 0x32 0x34 0x32 0x37 0x34 0x36 0x36 ,0x35 0x34 0x31 0x34 0x33 0x32 0x35 0x33 ,
      0x38 0x36 0x38 0x32 0x34 0x39 0x35 0x37 ,0x35 0x36 0x35 0x37 0x38 0x36 0x31 0x38 ,
the write training result:
DQS0:0x67, DQS1:0x62, DQS2:0x5d, DQS3:0x58,
min  :0x55 0x54 0x59 0x54 0x4a 0x47 0x49 0x47 0x4d ,0x4c 0x4c 0x47 0x4e 0x49 0x4d 0x50 0x4a 0x45 ,
      0x4b 0x4c 0x4f 0x4e 0x47 0x49 0x47 0x49 0x47 ,0x45 0x43 0x48 0x43 0x44 0x45 0x3f 0x45 0x3f ,
mid  :0x6f 0x6d 0x71 0x6d 0x61 0x61 0x60 0x5f 0x66 ,0x67 0x68 0x5f 0x65 0x62 0x68 0x68 0x65 0x5d ,
      0x63 0x67 0x67 0x68 0x60 0x60 0x5e 0x61 0x5f ,0x5d 0x5a 0x5d 0x59 0x5b 0x5e 0x57 0x5c 0x59 ,
max  :0x89 0x86 0x89 0x86 0x78 0x7b 0x78 0x77 0x7f ,0x82 0x84 0x77 0x7d 0x7b 0x84 0x81 0x80 0x76 ,
      0x7b 0x82 0x80 0x82 0x7a 0x77 0x76 0x7a 0x78 ,0x76 0x72 0x73 0x6f 0x72 0x77 0x6f 0x74 0x74 ,
range:0x34 0x32 0x30 0x32 0x2e 0x34 0x2f 0x30 0x32 ,0x36 0x38 0x30 0x2f 0x32 0x37 0x31 0x36 0x31 ,
      0x30 0x36 0x31 0x34 0x33 0x2e 0x2f 0x31 0x31 ,0x31 0x2f 0x2b 0x2c 0x2e 0x32 0x30 0x2f 0x35 ,
out
U-Boot SPL board init
U-Boot SPL 2017.09-ga1f6fc00a0-210413 #ldq (Apr 13 2021 - 11:35:00)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
SPL: A/B-slot: _a, successful: 0, tries-remain: 7
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256+ OK
## Checking uboot 0x00a00000 ... sha256+ OK
## Checking fdt 0x00b324c8 ... sha256+ OK
## Checking atf-2 0x00068000 ... sha256+ OK
## Checking atf-3 0xfdcd0000 ... sha256+ OK
## Checking atf-4 0xfdcc9000 ... sha256+ OK
## Checking atf-5 0x00066000 ... sha256+ OK
## Checking optee 0x08400000 ... sha256+ OK
Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000)
Total: 519.343 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-181-gc9a647cae:cl
NOTICE:  BL31: Built : 10:55:41, Oct 18 2021
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    pmu v1 is valid
INFO:    dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-515-g7b4275734 #hisping.lin (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 Wed Aug  4 07:11:39 UTC 2021 aarch64
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0xa00000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-g4a00a5a #jifu (Mar 30 2022 - 08:31:55 +0000)
Model: Forlinx OK3568-C
PreSerial: 2, raw, 0xfe660000
DRAM:  2 GiB
Sysmem: init
Relocation Offset: 7d346000
Relocation fdt: 7b9f91b0 - 7b9fece8
CR: M/C/I
no mmc device at slot 1
dwmmc@fe2b0000: 1 (SD), dwmmc@fe2c0000: 2, sdhci@fe310000: 0
Bootdev(atags): mmc 1
MMC1: Legacy, 52Mhz
PartType: EFI
boot mode: recovery (misc)
FIT: no signed, no conf required
DTB: rk-kernel.dtb
HASH(c): OK
I2c0 speed: 100000Hz
vsel-gpios- not found! Error: -2
vdd_cpu init 900000 uV
PMIC:  RK8090 (on=0x40, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
io-domain: OK
emmc pin check error -1 20400
Auth Success!
Could not find baseparameter partition
Model: Forlinx OK3568-C Board
Rockchip UBOOT DRM driver version: v1.0.1
VOP have 3 active VP
vp0 have layer nr:2[1 5 ], primary plane: 5
vp1 have layer nr:3[0 2 4 ], primary plane: 4
vp2 have layer nr:1[3 ], primary plane: 3
Using display timing dts
dsi@fe070000:  detailed mode clock 45000 kHz, flags[8000000a]
    H: 1024 1064 1112 1160
    V: 0600 0640 0644 0692
bus_format: 100e
VOP update mode to: 1024x600p0, type: MIPI1 for VP1
VOP VP1 enable Smart0[400x300->400x300@312x150] fmt[1] addr[0x7df00036]
final DSI-Link bandwidth: 300 Mbps x 4
hdmi@fe0a0000 disconnected
lvds:  detailed mode clock 71000 kHz, flags[6]
    H: 1280 1420 1430 1440
    V: 0800 0802 0822 0823
bus_format: 1011
VOP update mode to: 1280x800p0, type: LVDS0 for VP2
VOP VP2 enable Esmart1[400x300->400x300@440x250] fmt[1] addr[0x7df00036]
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 1416000 KHz
  dpll 780000 KHz
  gpll 1188000 KHz
  cpll 1000000 KHz
  npll 1200000 KHz
  vpll 630000 KHz
  hpll 24000 KHz
  ppll 200000 KHz
  armclk 1416000 KHz
  aclk_bus 150000 KHz
  pclk_bus 100000 KHz
  aclk_top_high 500000 KHz
  aclk_top_low 400000 KHz
  hclk_top 150000 KHz
  pclk_top 100000 KHz
  aclk_perimid 300000 KHz
  hclk_perimid 150000 KHz
  pclk_pmu 100000 KHz
Rockchip watchdog timeout: 5 sec
Net:   eth0: ethernet@fe2a0000, eth1: ethernet@fe010000
Hit key to stop autoboot('Spacebar'):  0
## Booting FIT Image at 0x79be5d80 with size 0x01c12400
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 79be5d80 ...
   Using 'conf' configuration
optee api revision: 2.0
TEEC: Waring: Could not find security partition
## Verified-boot: 0
   Trying 'kernel' kernel subimage
     Description:  unavailable
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x79c06d80
     Data Size:    22388744 Bytes = 21.4 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00280000
     Entry Point:  0x00280000
     Hash algo:    sha256
     Hash value:   bb759fedc6c2dc5c755ee20e9606af7eb75a0ee97b908468d65eea58b82cfce1
   Verifying Hash Integrity ... sha256+ OK
## Loading ramdisk from FIT Image at 79be5d80 ...
   Trying 'ramdisk' ramdisk subimage
     Type:         RAMDisk Image
     Data Start:   0x7b160f80
     Data Size:    6910104 Bytes = 6.6 MiB
     OS:           Linux
     Load Address: 0x0a200000
     Entry Point:  unavailable
     Hash algo:    sha256
     Hash value:   743d07e902646ae7261a1a328aab963ebc669486f083fec332b853112b85761a
   Loading ramdisk from 0x7b160f80 to 0x0a200000
## Loading fdt from FIT Image at 79be5d80 ...
   Trying 'fdt' fdt subimage
     Type:         Flat Device Tree
     Data Start:   0x79be6580
     Data Size:    132671 Bytes = 129.6 KiB
     Load Address: 0x0a100000
     Hash algo:    sha256
     Hash value:   a9c57603cddfca97e9c4f25028a60221d3ca5c5598381e8f7e034ad21579eb1e
   Loading fdt from 0x0a100000 to 0x0a100000
   Booting using the fdt blob at 0x0a100000
   Loading Kernel Image from 0x79c06d80 to 0x00280000 ... OK
   kernel loaded at 0x00280000, end = 0x017da008
  'reserved-memory' ramoops@110000: addr=110000 size=f0000
   Using Device Tree in place at 000000000a100000, end 000000000a12363e
vp1 adjust cursor plane from 0 to 1
vp0, plane_mask:0x22, primary-id:5, curser-id:1
vp1 adjust cursor plane from 1 to 0
vp1, plane_mask:0x15, primary-id:4, curser-id:0
vp2, plane_mask:0x8, primary-id:3, curser-id:-1
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x09400000 - 0x80000000 (size: 0x76c00000)
Total: 5589.140 ms
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 4.19.206 (jifu@004b0bbc7db2) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #1 SMP Wed Mar 30 09:32:39 UTC 2022
[    0.000000] Machine model: Forlinx OK3568-C Board
[    0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] cma: Reserved 16 MiB at 0x000000007ec00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 23 pages/cpu s54184 r8192 d31832 u94208
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 511496
[    0.000000] Kernel command line: storagemedia=sd androidboot.storagemedia=sd androidboot.mode=normal  sdfwupdate rw rootwait earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTUUID=614e0000-0000
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1994352K/2078720K available (13566K kernel code, 1960K rwdata, 4772K rodata, 1536K init, 536K bss, 67984K reserved, 16384K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 49885 entries in 195 pages
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] ITS [mem 0xfd440000-0xfd45ffff]
[    0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @7e4f0000 (indirect, esz 8, psz 64K, shr 0)
[    0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @7e500000 (flat, esz 2, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x000000007e510000
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    0.000000] CPU0: using LPI pending table @0x000000007e520000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x510 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.009727] Console: colour dummy device 80x25
[    0.014632] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.025902] pid_max: default: 32768 minimum: 301
[    0.031082] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.038448] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.047394] ASID allocator initialised with 32768 entries
[    0.053450] rcu: Hierarchical SRCU implementation.
[    0.060587] Platform MSI: interrupt-controller@fd440000 domain created
[    0.068146] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[    0.078317] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[    0.091555] Detected VIPT I-cache on CPU1
[    0.091583] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.091618] CPU1: using LPI pending table @0x000000007e6b0000
[    0.091659] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.099959] Detected VIPT I-cache on CPU2
[    0.099982] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.100020] CPU2: using LPI pending table @0x000000007e700000
[    0.100052] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.108316] Detected VIPT I-cache on CPU3
[    0.108338] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.108376] CPU3: using LPI pending table @0x000000007e720000
[    0.108406] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.108492] smp: Brought up 1 node, 4 CPUs
[    0.189775] SMP: Total of 4 processors activated.
[    0.194940] CPU features: detected: GIC system register CPU inte**ce
[    0.202010] CPU features: detected: Privileged Access Never
[    0.208127] CPU features: detected: LSE atomic instructions
[    0.214244] CPU features: detected: User Access Override
[    0.220074] CPU features: detected: 32-bit EL0 Support
[    0.225714] CPU features: detected: RAS Extension Support
[    0.231761] CPU: All CPU(s) started at EL2
[    0.236282] alternatives: patching kernel code
[    0.245447] devtmpfs: initialized
[    0.265793] Registered cp15_barrier emulation handler
[    0.271378] Registered setend emulation handler
[    0.276579] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.287290] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.294574] pinctrl core: initialized pinctrl subsystem
[    0.301050] NET: Registered protocol family 16
[    0.308794] cpuidle: using governor menu
[    0.313115] Registered FIQ tty driver
[    0.317488] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.326183] DMA: preallocated 256 KiB pool for atomic allocations
[    0.336066] console [pstore-1] enabled
[    0.340209] pstore: Registered ramoops as persistent store backend
[    0.346998] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[    0.377855] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[    0.385385] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[    0.392892] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[    0.400401] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[    0.407895] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[    0.415047] rockchip-pinctrl pinctrl: probed pinctrl
[    0.429506] cryptd: max_cpu_qlen set to 1000
[[    0.435506] console [ttyFIQ0] enabled
[    0.443200] bootconsole [uart8250] disabled
[    0.447967] Registered fiq debugger ttyFIQ0
[    0.448689] vcc5v0_sys: supplied by vcc12v
[    0.448985] vcc3v3_sys: supplied by vcc5v0_sys
[    0.449273] vcc3v3: supplied by vcc5v0_sys
[    0.449549] vcc1v8: supplied by vcc3v3
[    0.449832] vcc1v2: supplied by vcc3v3
[    0.450125] vcc2v8: supplied by vcc3v3
[    0.450440] vcc3v3_lcd2_n: supplied by vcc3v3_sys
[    0.450732] vcc2v5-sys: supplied by vcc3v3_sys
[    0.452375] rk_iommu fde4b000.iommu: version = 2
[    0.452812] rk_iommu fdea0800.iommu: version = 2
[    0.453111] rk_iommu fded0480.iommu: version = 2
[    0.453452] rk_iommu fdee0800.iommu: version = 2
[    0.453759] rk_iommu fdef0800.iommu: version = 2
[    0.454027] rk_iommu fdf40f00.iommu: version = 2
[    0.454363] rk_iommu fdf80800.iommu: version = 2
[    0.454685] rk_iommu fdff1a00.iommu: version = 2
[    0.454964] rk_iommu fe043e00.iommu: version = 2
[    0.455666] SCSI subsystem initialized
[    0.455877] usbcore: registered new inte**ce driver usbfs
[    0.455931] usbcore: registered new inte**ce driver hub
[    0.455978] usbcore: registered new device driver usb
[    0.456058] media: Linux media inte**ce: v0.10
[    0.456101] videodev: Linux video capture inte**ce: v2.00
[    0.456176] pps_core: LinuxPPS API ver. 1 registered
[    0.456192] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.456218] PTP clock support registered
[    0.456485] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    0.458474] Advanced Linux Sound Architecture Driver Initialized.
[    0.458853] Bluetooth: Core ver 2.22
[    0.458901] NET: Registered protocol family 31
[    0.458915] Bluetooth: HCI device and connection manager initialized
[    0.458934] Bluetooth: HCI socket layer initialized
[    0.458950] Bluetooth: L2CAP socket layer initialized
[    0.458985] Bluetooth: SCO socket layer initialized
[    0.459364] rockchip-cpuinfo cpuinfo: SoC            : 35682000
[    0.459384] rockchip-cpuinfo cpuinfo: Serial         : 50e0fefa5a6bba81
[    0.460135] clocksource: Switched to clocksource arch_sys_counter
[    0.522171] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.522447] NET: Registered protocol family 2
[    0.522605] IP idents hash table entries: 32768 (order: 6, 262144 bytes)
[    0.523448] tcp_listen_portaddr_hash hash table entries: 1024 (order: 3, 40960 bytes)
[    0.523539] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.523646] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[    0.523994] TCP: Hash tables configured (established 16384 bind 16384)
[    0.524148] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[    0.524244] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[    0.524481] NET: Registered protocol family 1
[    0.524981] RPC: Registered named UNIX socket transport module.
[    0.524997] RPC: Registered udp transport module.
[    0.525011] RPC: Registered tcp transport module.
[    0.525025] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.526237] Trying to unpack rootfs image as initramfs...
[    0.755815] Freeing initrd memory: 6748K
[    0.756723] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.758638] Initialise system trusted keyrings
[    0.758810] workingset: timestamp_bits=61 max_order=19 bucket_order=0
[    0.764007] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.764666] NFS: Registering the id_resolver key type
[    0.764701] Key type id_resolver registered
[    0.764716] Key type id_legacy registered
[    0.764752] ntfs: driver 2.1.32 [Flags: R/O].
[    0.764926] jffs2: version 2.2. (NAND) &#169; 2001-2006 Red Hat, Inc.
[    0.765108] fuse init (API version 7.27)
[    0.765414] SGI XFS with security attributes, no debug enabled
[    0.767547] NET: Registered protocol family 38
[    0.767580] Key type asymmetric registered
[    0.767595] Asymmetric key parser 'x509' registered
[    0.767639] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.767656] io scheduler noop registered
[    0.767669] io scheduler deadline registered
[    0.767769] io scheduler cfq registered (default)
[    0.767786] io scheduler mq-deadline registered
[    0.767795] io scheduler kyber registered
[    0.768675] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[    0.768804] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[    0.770859] phy phy-fe8a0000.usb2-phy.1: No vbus specified for otg port
[    0.771963] extcon extcon1: failed to create extcon usb2-phy link
[    0.772223] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port
[    0.780964] rk-pcie 3c0000000.pcie: Linked as a consumer to regulator.3
[    0.781198] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.3
[    0.781261] rk-pcie 3c0000000.pcie: missing legacy IRQ resource
[    0.781280] rk-pcie 3c0000000.pcie: Missing *config* reg space
[    0.781302] rk-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges:
[    0.781332] rk-pcie 3c0000000.pcie:   err 0x300000000..0x3007fffff -> 0x00000000
[    0.781356] rk-pcie 3c0000000.pcie:    IO 0x300800000..0x3008fffff -> 0x00800000
[    0.781378] rk-pcie 3c0000000.pcie:   MEM 0x300900000..0x33fffffff -> 0x00900000
[    0.781743] pwm-backlight dsi1-backlight: dsi1-backlight supply power not found, using dummy regulator
[    0.781818] pwm-backlight dsi1-backlight: Linked as a consumer to regulator.0
[    0.782049] pwm-backlight lvds-backlight: lvds-backlight supply power not found, using dummy regulator
[    0.782106] pwm-backlight lvds-backlight: Linked as a consumer to regulator.0
[    0.782309] pwm-backlight edp-backlight: edp-backlight supply power not found, using dummy regulator
[    0.782367] pwm-backlight edp-backlight: Linked as a consumer to regulator.0
[    0.782561] mpp_service mpp-srv: unknown mpp version for missing VCS info
[    0.782581] mpp_service mpp-srv: probe start
[    0.783379] iommu: Adding device fdf40000.rkvenc to group 5
[    0.783412] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu
[    0.783639] mpp_rkvenc fdf40000.rkvenc: probing start
[    0.784085] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry
[    0.784102] rkvenc_init:1199: failed to add venc devfreq
[    0.784375] mpp_rkvenc fdf40000.rkvenc: probing finish
[    0.785390] iommu: Adding device fdea0400.vdpu to group 1
[    0.785425] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu
[    0.785571] mpp_vdpu2 fdea0400.vdpu: probe device
[    0.786031] mpp_vdpu2 fdea0400.vdpu: probing finish
[    0.786517] iommu: Adding device fdee0000.vepu to group 3
[    0.786551] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu
[    0.786713] mpp_vepu2 fdee0000.vepu: probe device
[    0.787216] mpp_vepu2 fdee0000.vepu: probing finish
[    0.787686] iommu: Adding device fdef0000.iep to group 4
[    0.787719] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu
[    0.787847] mpp-iep2 fdef0000.iep: probe device
[    0.788237] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[    0.788386] mpp-iep2 fdef0000.iep: probing finish
[    0.788822] iommu: Adding device fded0000.jpegd to group 2
[    0.788856] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu
[    0.788981] mpp_jpgdec fded0000.jpegd: probe device
[    0.789441] mpp_jpgdec fded0000.jpegd: probing finish
[    0.789908] iommu: Adding device fdf80200.rkvdec to group 6
[    0.789940] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu
[    0.790188] mpp_rkvdec2 fdf80200.rkvdec: probing start
[    0.790316] mpp_rkvdec2 fdf80200.rkvdec: 16 task capacity link mode detected
[    0.790614] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[    0.790632] rkvdec2_init:661: No niu aclk reset resource define
[    0.790650] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[    0.790663] rkvdec2_init:664: No niu hclk reset resource define
[    0.790825] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[    0.790843] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[    0.790858] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[    0.790871] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[    0.790886] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[    0.790940] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[    0.791009] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[    0.791305] mpp_service mpp-srv: probe success
[    0.793335] rk-pcie 3c0800000.pcie: missing legacy IRQ resource
[    0.793364] rk-pcie 3c0800000.pcie: Missing *config* reg space
[    0.793383] rk-pcie 3c0800000.pcie: host bridge /pcie@fe280000 ranges:
[    0.793411] rk-pcie 3c0800000.pcie:   err 0x380000000..0x3807fffff -> 0x80000000
[    0.793432] rk-pcie 3c0800000.pcie:    IO 0x380800000..0x3808fffff -> 0x80800000
[    0.793453] rk-pcie 3c0800000.pcie:   MEM 0x380900000..0x3bfffffff -> 0x80900000
[    0.797295] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[    0.797322] dma-pl330 fe530000.dmac:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.799263] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[    0.799287] dma-pl330 fe550000.dmac:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.800458] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    0.801483] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.802284] fe670000.serial: ttyS3 at MMIO 0xfe670000 (irq = 74, base_baud = 1500000) is a 16550A
[    0.802736] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 75, base_baud = 1500000) is a 16550A
[    0.803146] fe690000.serial: ttyS5 at MMIO 0xfe690000 (irq = 76, base_baud = 1500000) is a 16550A
[    0.803647] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 77, base_baud = 1500000) is a 16550A
[    0.806081] random: fast init done
[    0.806375] random: crng init done
[    0.806446] iommu: Adding device fe040000.vop to group 8
[    0.806484] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu
[    0.811191] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop
[    0.811396] rockchip-drm display-subsystem: Linked as a consumer to fdc60000.syscon:lvds
[    0.812377] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi
[    0.812817] rockchip-drm display-subsystem: Linked as a consumer to fe070000.dsi
[    0.814195] rockchip-drm display-subsystem: defer getting devfreq
[    0.814457] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x22, primary plane phy id: 5
[    0.814483] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x15, primary plane phy id: 4
[    0.814504] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[    0.814595] [drm] unsupported AFBC format[3432564e]
[    0.814652] rockchip-vop2 fe040000.vop: [drm:vop2_bind] Cluster1-win0 as cursor plane for vp0
[    0.814767] rockchip-vop2 fe040000.vop: [drm:vop2_bind] Cluster0-win0 as cursor plane for vp1
[    0.814878] [drm] failed to init overlay plane Cluster0-win1
[    0.814895] [drm] failed to init overlay plane Cluster1-win1
[    0.815088] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8008e99758)
[    0.819331] /edp-panel: could not find display-timings node
[    0.819343] /edp-panel: no timings specified
[    0.819397] panel-** edp-panel: edp-panel supply power not found, using dummy regulator
[    0.819467] panel-** edp-panel: Linked as a consumer to regulator.0
[    0.819508] panel-** edp-panel: edp-panel supply vsp not found, using dummy regulator
[    0.819576] panel-** edp-panel: edp-panel supply vsn not found, using dummy regulator
[    0.819869] panel-** panel: Linked as a consumer to regulator.8
[    0.819913] panel-** panel: panel supply vsp not found, using dummy regulator
[    0.819964] panel-** panel: Linked as a consumer to regulator.0
[    0.820003] panel-** panel: panel supply vsn not found, using dummy regulator
[    0.820682] panel-**-dsi fe070000.dsi.0: fe070000.dsi.0 supply power not found, using dummy regulator
[    0.820746] panel-**-dsi fe070000.dsi.0: Linked as a consumer to regulator.0
[    0.820790] panel-**-dsi fe070000.dsi.0: fe070000.dsi.0 supply vsp not found, using dummy regulator
[    0.820860] panel-**-dsi fe070000.dsi.0: fe070000.dsi.0 supply vsn not found, using dummy regulator
[    0.821904] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[    0.822004] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.822043] mali fde60000.gpu: Device initialization Deferred
[    0.822593] brd: module loaded
[    0.828639] loop: module loaded
[    0.829041] zram: Added device: zram0
[    0.829166] lkdtm: No crash points registered, enable through debugfs
[    0.833113] libphy: Fixed MDIO Bus: probed
[    0.833304] CAN device driver inte**ce
[    0.835344] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    0.835370] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.836469] rk_gmac-dwmac fe2a0000.ethernet: no regulator found
[    0.836496] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (output).
[    0.836512] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x2f).
[    0.836528] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x0).
[    0.836546] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[    0.841613] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[    0.841842] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    0.841861] rk_gmac-dwmac fe2a0000.ethernet:         DWMAC4/5
[    0.841878] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[    0.841893] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[    0.841906] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[    0.841918] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[    0.841955] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[    0.841970] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    0.841986] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[    0.973491] libphy: stmmac: probed
[    0.977419] rk_gmac-dwmac fe010000.ethernet: no regulator found
[    0.977447] rk_gmac-dwmac fe010000.ethernet: clock input or output? (output).
[    0.977465] rk_gmac-dwmac fe010000.ethernet: TX delay(0x35).
[    0.977480] rk_gmac-dwmac fe010000.ethernet: RX delay(0x0).
[    0.977498] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    0.982554] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    0.982787] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    0.982807] rk_gmac-dwmac fe010000.ethernet:         DWMAC4/5
[    0.982823] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    0.982837] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    0.982850] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    0.982864] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    0.982905] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    0.982921] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    0.982935] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    1.113492] libphy: stmmac: probed
[    1.116832] usbcore: registered new inte**ce driver rndis_wlan
[    1.116902] usbcore: registered new inte**ce driver rtl8150
[    1.116957] usbcore: registered new inte**ce driver r8152
[    1.117008] usbcore: registered new inte**ce driver asix
[    1.117054] usbcore: registered new inte**ce driver ax88179_178a
[    1.117100] usbcore: registered new inte**ce driver cdc_ether
[    1.117146] usbcore: registered new inte**ce driver rndis_host
[    1.117205] usbcore: registered new inte**ce driver cdc_ncm
[    1.117253] usbcore: registered new inte**ce driver cdc_mbim
[    1.117284] GobiNet: Quectel_WCDMA&LTE_Linux&Android_GobiNet_Driver_V1.5.0
[    1.117332] usbcore: registered new inte**ce driver GobiNet
[    1.118381] dwc3 fcc00000.dwc3: Failed to get clk 'ref': -2
[    1.123725] dwc3 fd000000.dwc3: Failed to get clk 'ref': -2
[    1.129334] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.129365] ehci-pci: EHCI PCI platform driver
[    1.129501] ehci-platform: EHCI generic platform driver
[    1.131744] ehci-platform fd800000.usb: EHCI Host Controller
[    1.131915] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1
[    1.132203] ehci-platform fd800000.usb: irq 11, io mem 0xfd800000
[    1.143480] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[    1.143721] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.143740] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.143755] usb usb1: Product: EHCI Host Controller
[    1.143768] usb usb1: Manufacturer: Linux 4.19.206 ehci_hcd
[    1.143782] usb usb1: SerialNumber: fd800000.usb
[    1.144209] hub 1-0:1.0: USB hub found
[    1.144248] hub 1-0:1.0: 1 port detected
[    1.146753] ehci-platform fd880000.usb: EHCI Host Controller
[    1.146942] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[    1.147252] ehci-platform fd880000.usb: irq 13, io mem 0xfd880000
[    1.160157] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[    1.160349] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.160369] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.160385] usb usb2: Product: EHCI Host Controller
[    1.160399] usb usb2: Manufacturer: Linux 4.19.206 ehci_hcd
[    1.160413] usb usb2: SerialNumber: fd880000.usb
[    1.160806] hub 2-0:1.0: USB hub found
[    1.160851] hub 2-0:1.0: 1 port detected
[    1.161554] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.161583] ohci-platform: OHCI generic platform driver
[    1.161802] ohci-platform fd840000.usb: Generic Platform OHCI controller
[    1.161964] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[    1.162197] ohci-platform fd840000.usb: irq 12, io mem 0xfd840000
[    1.220980] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    1.221000] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.221015] usb usb3: Product: Generic Platform OHCI controller
[    1.221029] usb usb3: Manufacturer: Linux 4.19.206 ohci_hcd
[    1.221042] usb usb3: SerialNumber: fd840000.usb
[    1.22NAME=1Buil4droot
VERSION=2018.02-rc3
ID=buildroot
VERSION_ID3=20118.02-rc3
PRETTY_NAME="Buildroot 2018.02-rc3"
] hStartuing logging: b 3-0:1.0: USB hub found
[    1.221476] OK
hub 3-0:1.0: 1 port detected
[    1.221944] ohci-plaPopulating /dev using udev: tform fd8c0000.usb: Generic Platform OHCI controller
[    1.222116] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4
[    1.222353] ohci-platform fd8c0000.usb: irq 14, io mem 0xfd8c0000
[    1.280981] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    1.281002] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.281016] usb usb4: Product: Generic Platform OHCI controller
[    1.281030] usb usb4: Manufacturer: Linux 4.19.206 ohci_hcd
[    1.281043] usb usb4: SerialNumber: fd8c0000.usb
[    1.281426] hub 4-0:1.0: USB hub found
[    1.281473] hub 4-0:1.0: 1 port detected
[    1.282968] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.283141] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[    1.283614] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010
[    1.283683] xhci-hcd xhci-hcd.0.auto: irq 90, io mem 0xfd000000
[    1.283986] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.284005] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.284020] usb usb5: Product: xHCI Host Controller
[    1.284029] usb usb5: Manufacturer: Linux 4.19.206 xhci-hcd
[    1.284042] usb usb5: SerialNumber: xhci-hcd.0.auto
[    1.284458] hub 5-0:1.0: USB hub found
[    1.284505] hub 5-0:1.0: 1 port detected
[    1.284821] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.284987] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
[    1.285014] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    1.285090] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.285223] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    1.285243] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.285258] usb usb6: Product: xHCI Host Controller
[    1.285271] usb usb6: Manufacturer: Linux 4.19.206 xhci-hcd
[    1.285285] usb usb6: SerialNumber: xhci-hcd.0.auto
[    1.285662] hub 6-0:1.0: USB hub found
[    1.285705] hub 6-0:1.0: 1 port detected
[    1.286141] usbcore: registered new inte**ce driver cdc_acm
[    1.286159] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.286227] usbcore: registered new inte**ce driver cdc_wdm
[    1.286442] usbcore: registered new inte**ce driver uas
[    1.286575] usbcore: registered new inte**ce driver usb-storage
[    1.286671] usbcore: registered new inte**ce driver usbserial_generic
[    1.286707] usbserial: USB Serial support registered for generic
[    1.286762] usbcore: registered new inte**ce driver cp210x
[    1.286825] usbserial: USB Serial support registered for cp210x
[    1.286921] usbcore: registered new inte**ce driver ftdi_sio
[    1.286959] done
usbserial: USB Serial support registInitializing random number genereatorr... ed for FTDI USB Serial Device
[    1.287164] done.
usbcore: registered new inte**ce driver keyspan
[    1.287198] usbserial: US
B******************************** ****S****e****r*************
Starting network:             ROCKCHIP recovery system         i    a
**********************l**********************************
**** version : v1.0.1  ****
Starting recovery on Sun Apr 19 18:18:40 1970
OK
Recovery System have UIs defined.
failed to read font: res=-u, fall back to the compiled-in font
Debug: configps_init
port registered for Keyspan - (without firmware)
[    1.287230] usbserial: USB Serial support registered for Keyspan 1 port amkdir: can't create directory '/sys/kernel/config/usb_gaddget/arockpchiptfunctions/uac1.gs0': No such file or directory
er
[    1.287261] usbserial: mkdir: can't create diUrectSory B'/sys/kernel/config/usb_gadget/rockchip/functions/uac2.gs0': No such file or directory
Serial support registered for Keyspan 2 port adapter
[  mkdir : ca n't create directory '/s.ys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0': No such file or directory
287293] usbserial: USB Serimkdir: can't create diarectlory  '/syss/kernel/config/usb_gadget/rockchip/functions/rndis.gs0': No such file or directory
upport registered for Keyspan 4 port adapter
[    1.287358] usbcore: registered nmkdir: can't create directory '/sys/kernel/config/usb_gadget/rockchip/functions/hied.uswb0':  No isuch file or directory
nte**ce driver option
[    1.287392] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.287677] usbcore: registered new inte**ce driver oti6858
[    1.287712] usbserial: USB Serial support registered for oti6858
[    1.287765] usbcore: registered new inte**ce driver pl2303
[    1.287799] usbserial: USB Serial support registered for pl2303
[    1.287864] usbcore: registered new inte**ce driver qcserial
[    1.287898] usbserial: USB Serial support registered for Qualcomm USB modem
[    1.287980] usbcore: registered new inte**ce driver sierra
[    1.288016] usbserial: USB Serial support registered for Sierra USB modem
[    1.289356] usbcore: registered new inte**ce driver usbtouchscreen
[    1.289404] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[    1.289421] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[    1.290034] i2c /dev entries driver
[    1.291903] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    1.293687] vdd_cpu: supplied by vcc5v0_sys
[    1.298442] rk808 0-0020: chip id: 0x8090
[    1.298490] rk808 0-0020: No cache defaults, reading back from HW
[    1.322189] rk808 0-0020: source: on=0x40, off=0x00
[    1.322215] rk808 0-0020: support dcdc3 fb mode:-22, 63
[    1.322234] rk808 0-0020: support pmic reset mode:0,0
[    1.327802] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    1.327842] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    1.328266] vdd_logic: supplied by vcc3v3_sys
[    1.328944] vdd_gpu: supplied by vcc3v3_sys
[    1.329232] vcc_ddr: supplied by vcc3v3_sys
[    1.329521] vdd_npu: supplied by vcrotate degrece: 0 - none, 1 - right, 2 - down, 3 - l3eft.
current rotate dvegree is : 0
3_sys
[    1.330172] vcc_1v8: supplied by vcc3v3_sys
[    1.330444] vdda0v9_image: supplied by vcc3v3_sys
[    1.331067] vdda_0v9: supplied by vcc3v3_sys
[    1.331346] vdda0v9_pmu: supplied by vcc3v3_sys
[    1.331623] vccio_acodec: supplied by vcc3v3_sys
[    1.332232] vccio_sd: supplied by vcc3v3_sys
[    1.332539] vcc3v3_pmu: supplied by vcc3v3_sys
[    1.333162] vcca_1v8: supplied by vcc3v3_sys
[    1.333439] vcca1v8_pmu: supplied by vcc3v3_sys
[    1.333761] vcca1v8_image: supplied by vcc3v3_sys
[    1.334382] vcc_3v3: supplied by vcc3v3_sys
[    1.334977] vcc3v3_sd: supplied by vcc3v3_sys
[    1.335369] rk817-battery rk817-battery: Failed to find matching dt id
[    1.335608] rk817-charger rk817-charger: Failed to find matching dt id
[    1.338754] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[    1.433654] Goodix-TS 2-005d: i2c test failed attempt 1: -6
[    1.460315] Goodix-TS 2-005d: i2c test failed attempt 2: -6
[    1.486824] Goodix-TS 2-005d: I2C communication failure: -6
[    1.580357] Goodix-TS 2-0014: i2c test failed attempt 1: -6
[    1.606980] Goodix-TS 2-0014: i2c test failed attempt 2: -6
[    1.633490] Goodix-TS 2-0014: I2C communication failure: -6
[    1.633940] edt_ft5x06 2-0038: touchscreen probe failed
[    1.638950] rtc rtc0: invalid alarm value: 1970-4-31 15:26:0
[    1.639107] rtc-pcf8563 3-0051: rtc core: registered rtc-pcf8563 as rtc0
[    1.640329] rtc-pcf8563 3-0051: setting system clock to 1970-04-19 18:18:39 UTC (9397119)
[    1.642244] vm149c 2-000c: probing...
[    1.642265] vm149c 2-000c: driver version: 00.01.00
[    1.642280] vm149c 2-000c: could not get module rockchip,vcm-max-current from dts!
[    1.642294] vm149c 2-000c: could not get module rockchip,vcm-start-current from dts!
[    1.642308] vm149c 2-000c: could not get module rockchip,vcm-rated-current from dts!
[    1.642321] vm149c 2-000c: could not get module rockchip,vcm-step-mode from dts!
[    1.642360] vm149c 2-000c: probing successful
[    1.644048] iommu: Adding device fdff0000.rkisp to group 7
[    1.644084] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu
[    1.644262] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[    1.644283] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[    1.644313] rkisp_hw fdff0000.rkisp: can't request region for resource [mem 0xfdff0000-0xfdffffff]
[    1.645110] rkisp rkisp-vir0: rkisp driver version: v01.07.00
[    1.645206] rkisp rkisp-vir0: No memory-region-thunderboot specified
[    1.645384] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[    1.645409] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[    1.647119] usbcore: registered new inte**ce driver uvcvideo
[    1.647138] USB Video Class driver (1.1.1)
[    1.647395] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.23
[    1.647438] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[    1.647542] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[    1.647624] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.21
[    1.647660] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[    1.647791] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.22
[    1.647827] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[    1.647910] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.17
[    1.647944] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    1.648027] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.27
[    1.648062] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[    1.648166] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    1.648263] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[    1.651405] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[    1.652418] Bluetooth: HCI UART driver ver 2.3
[    1.652439] Bluetooth: HCI UART protocol H4 registered
[    1.652450] Bluetooth: HCI UART protocol ATH3K registered
[    1.652527] usbcore: registered new inte**ce driver bfusb
[    1.652597] usbcore: registered new inte**ce driver btusb
[    1.652880] cpu cpu0: leakage=29
[    1.652933] cpu cpu0: pvtm = 88900, from nvmem
[    1.652955] cpu cpu0: pvtm-volt-sel=1
[    1.653755] cpu cpu0: Linked as a consumer to regulator.12
[    1.653817] cpu cpu0: Dropping the link to regulator.12
[    1.654455] cpu cpu0: Linked as a consumer to regulator.12
[    1.655156] cpu cpu0: avs=0
[    1.655217] energy_model: pd0: hertz/watts ratio non-monotonically decreasing: em_cap_state 2 >= em_cap_state1
[    1.655421] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    1.658822] cpu cpu0: failed to find power_model node
[    1.660276] sdhcrecovery filesystem table
=====i====:================
  0 (null) /tmp ramdis k (null) (null) (null)
  1 /dev/root / ext2 rw,noauto 0 1
  2 proc /proc proc defaults 0 0
  3 devpts /dev/ptSs devpts defaults,gid=5,mode=620 0 0
  4 tmpfs /dev/shm tmpfs mode=0777 0 0
  5 tmpfs /tmp tmpfs mode=1777 0 0
  6 tmpfs /run tmpefs mcode=u0755r,nosuid,nodev 0 0
  7 sysfs /sys sysfs defaults 0 0
  8 /dev/blocek/by -name/misc /misc emmc defaults 0 0
  9 /dev/block/by-name/userdata /userdata ext2 defaults 0 0
D  10i /degv/bliock/tby-name/oem /oem ext2 defaults 0 0
  11 /dev/sda1 /mnt/usb_storage vfat defaults 0 0
  12 a/dev/mmcblk1p1 /mnt/sdcard vfat defaults 0 0
l Hoemmc_point is /dev/mmcblk0
sd_point is /dev/mmcblk1p1
sd_point_2 is /dev/smmcblk1
tread cmdline
>>> Boot from SDcard
is_sdcard_update in
configFile = /mnt/sdcard/sd_boCot_coonfing.config
func get_cfg_Item err:-1
troller Inte**ce driver
[   Command: "/usr/bin/recovery"
1.660292] sdhci: Copyright(c) Pierre Ossman
[    1.660309] Synopsys Designware ** Card Inte**ce Driver
[    1.661369] dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode.
[    1.661593] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller.
[    1.661615] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a
[    1.661672] dwmmc_rockchip fe000000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    1.661813] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq
[    1.661834] mmc_host mmc3: card is non-removable.
[    1.807048] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[    1.807135] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[    1.881203] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    1.894775] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[    1.895472] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[    1.895503] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[    1.895571] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 58,32 bit host data width,256 deep fifo
[    1.895713] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.28
[    1.895807] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.22
[    1.911367] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    1.924300] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.925541] mmc0: Unknown controller version (5). You may experience problems.
[    1.941896] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    1.957240] mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[    1.958746] hidraw: raw HID events driver (C) Jiri Kosina
[    1.959193] usbcore: registered new inte**ce driver usbhid
[    1.959211] usbhid: USB HID core driver
[    1.959574] rockchip,bus bus-npu: Linked as a consumer to regulator.13
[    1.959602] rockchip,bus bus-npu: Failed to get leakage
[    1.959663] rockchip,bus bus-npu: pvtm = 88900, from nvmem
[    1.959685] rockchip,bus bus-npu: pvtm-volt-sel=1
[    1.959957] rockchip,bus bus-npu: avs=0
[    1.963604] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.24
[    1.964310] optee: probing for conduit method from DT.
[    1.964336] optee: revision 3.13 (7b427573)
[    1.964796] optee: initialized driver
[    1.964828] rksfc_base v1.1 2016-01-08
[    1.965550] rksfc fe300000.sfc: rksfc_probe clk rate = 99000000
[    1.965637] rkflash_dev_init enter
[    1.965662] sfc nor id: ff ff ff
[    1.965676] rkflash[1] is invalid
[    1.965678] rkflash_dev_init enter
[    1.965701] sfc_nand id: ff ff ff
[    1.965712] rkflash[2] is invalid
[    1.968338] rk817-codec rk817-codec: DMA mask not set
[    1.975289] Initializing XFRM netlink socket
[    1.975701] NET: Registered protocol family 10
[    1.976483] Segment Routing with IPv6
[    1.976576] NET: Registered protocol family 17
[    1.976611] NET: Registered protocol family 15
[    1.976626] can: controller area network core (rev 20170425 abi 9)
[    1.976765] NET: Registered protocol family 29
[    1.976837] can: raw protocol (rev 20170425)
[    1.976857] can: broadcast manager protocol (rev 20170425 t)
[    1.976882] can: netlink gateway (rev 20170425) max_hops=1
[    1.977260] Bluetooth: RFCOMM socket layer initialized
[    1.977367] Bluetooth: RFCOMM ver 1.11
[    1.977419] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    1.977461] Bluetooth: HIDP socket layer initialized
[    1.977550] [BT_RFKILL]: Enter rfkill_rk_init
[    1.977573] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    1.978833] Key type dns_resolver registered
[    1.979450] flash vendor_init_thread!
[    1.979486] flash vendor storage:20170308 ret = -1
[    1.981184] ov13850 2-0010: driver versioStarting input-event-daemon: : 00.01.05
[    1.981279] oinput-event-daemon: Start parsing /etc/input-event-daemon.conf...
v13inpu8t-ev5ent-daemon: Adding device: /dev/input/event0...
input-event-daemon: Adding device: /dev/input/event1...
input-event0-dae mon:2 Adding device: /dev/input/event2...
input-event-daemon: Adding device: /dev/input/event3...
input-event-daemon: Start listening on 4 device-s...0
                                                     010: Failedone
d to get power-gpios, maybe no use
[    1.981503] ov13850 2-0010: 2-0010 supply avdd not f[root@buildroot:/]# ound, using dummy regulator
[    1.981725] ov13850 2-0010: Linked as a consumer to regulator.0
[    1.981830] ov13850 2-0010: 2-0010 supply dovdd not found, using dummy regulator
[    1.982005] ov13850 2-0010: 2-0010 supply dvdd not found, using dummy regulator
[    1.982155] ov13850 2-0010: could not get default pinstate
[    1.982200] ov138
Install fail!
finish_r5ecovery Enter.....
2-0010: could not get sleep pi[E/]RECOVERYn failed to mount /userdata (Invalid argusmentt
[E/]RECOVERY Can't mount /userdata/recovery/log
[E/]RECOVERY Can't open /userdata/recovery/log
ate
[    1.98598[E/]RECOVERY failed to mount /userdat3a (I]nval id argument)
[E/]RECOVERY Can't mount /userdata/recovery/last_log
[E/]RECoOVERvY Ca1n't open /userdata/recovery/last_log
38Now is SD.
[I/]RECOVERY no found mtd.
50 2-0010: Unexpected sensor i[E/]RECOVERY failed to moudt /userdata (Invalid argument)
[W/]RECOVERY Can't unlink /userdata/recov(ery/command
000000), ret(-5)
[    1.987850] Loading compiled-in X.509 certificates
[    1.988559] pstore: Using compression: deflate
[    1.989749] rga2: Driver loaded successfully ver:3.2.63318
[    1.990490] rga2: Module initialized.
[    1.990908] mmc0: new HS200 MMC card at address 0001
[    1.992024] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    1.992840] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[    1.993792] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[    1.994064] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (238:0)
[    1.997907]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[    2.000867] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    2.023831] rockchip-drm display-subsystem: defer getting devfreq
[    2.024107] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x22, primary plane phy id: 5
[    2.024130] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x15, primary plane phy id: 4
[    2.024147] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[    2.024257] rockchip-vop2 fe040000.vop: [drm:vop2_bind] Cluster1-win0 as cursor plane for vp0
[    2.024354] rockchip-vop2 fe040000.vop: [drm:vop2_bind] Cluster0-win0 as cursor plane for vp1
[    2.024444] [drm] failed to init overlay plane Cluster0-win1
[    2.024457] [drm] failed to init overlay plane Cluster1-win1
[    2.024616] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8008e99758)
[    2.024662] rockchip-drm display-subsystem: bound fdc60000.syscon:lvds (ops 0xffffff8008e9f730)
[    2.024817] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    2.025583] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.026957] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8008e9d270)
[    2.027016] rockchip-drm display-subsystem: bound fe070000.dsi (ops 0xffffff8008e9e338)
[    2.027034] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.027044] [drm] No driver support for vblank timestamp query.
[    2.027584] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
[    2.042560] rockchip-drm display-subsystem: fb0:  frame buffer device
[    2.043427] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[    2.044181] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[    2.044232] input: adc-keys as /devices/platform/adc-keys/input/input2
[    2.044354] mali fde60000.gpu: Linked as a consumer to regulator.14
[    2.044482] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19
[    2.044577] mali fde60000.gpu: leakage=7
[    2.044633] mali fde60000.gpu: pvtm = 88900, from nvmem
[    2.044810] rockchip-dmc dmc: Linked as a consumer to regulator.13
[    2.044883] rockchip-dmc dmc: leakage=52
[    2.044904] rockchip-dmc dmc: leakage-volt-sel=0
[    2.044943] rockchip-dmc dmc: pvtm = 88900, from nvmem
[    2.044959] rockchip-dmc dmc: pvtm-volt-sel=1
[    2.045038] mali fde60000.gpu: avs=0
[    2.045058] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[    2.045088] rockchip-dmc dmc: avs=0
[    2.045106] rockchip-dmc dmc: current ATF version 0x101
[    2.045350] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[    2.045440] mali fde60000.gpu: No priority control manager is configured
[    2.045456] mali fde60000.gpu: No memory group manager is configured
[    2.045931] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    2.045940] rockchip-dmc dmc: normal_rate = 780000000
[    2.045961] rockchip-dmc dmc: reboot_rate = 1560000000
[    2.045973] rockchip-dmc dmc: suspend_rate = 324000000
[    2.045985] rockchip-dmc dmc: video_4k_rate = 780000000
[    2.045996] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[    2.046007] rockchip-dmc dmc: boost_rate = 1560000000
[    2.046018] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1560000000
[    2.046030] rockchip-dmc dmc: performance_rate = 1560000000
[    2.046059] rockchip-dmc dmc: failed to get vop pn to msch rl
[    2.046182] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    2.046226] rockchip-dmc dmc: could not find power_model node
[    2.046588] mali fde60000.gpu: Probed as mali0
[    2.047205] asoc-**-card rk809-sound: ASoC: DAPM unknown pin Headphones
[    2.052146] asoc-**-card rk809-sound: rk817-hifi <-> fe410000.i2s mapping ok
[    2.052655] input: rockchip,rk809-codec Headphones as /devices/platform/rk809-sound/sound/card0/input3
[    2.053973] rk-hdmi-sound hdmi-sound: i2s-hifi <-> fe400000.i2s mapping ok
[    2.054336] input: rockchip,hdmi rockchip,hdmi as /devices/platform/hdmi-sound/sound/card1/input4
[    2.056767] iommu: Adding device fde40000.npu to group 0
[    2.056845] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu
[    2.057260] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[    2.057381] RKNPU fde40000.npu: Linked as a consumer to regulator.16
[    2.057406] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff]
[    2.057942] [drm] Initialized rknpu 0.4.2 20210701 for fde40000.npu on minor 1
[    2.058206] RKNPU fde40000.npu: leakage=4
[    2.058249] RKNPU fde40000.npu: pvtm = 88900, from nvmem
[    2.058680] RKNPU fde40000.npu: avs=0
[    2.059242] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    2.059269] RKNPU fde40000.npu: failed to find power_model node
[    2.059282] RKNPU fde40000.npu: RKNPU: failed to initialize power model
[    2.059293] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[    2.059972] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    2.064651] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    2.064809] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    2.064833] cfg80211: failed to load regulatory.db
[    2.066328] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    2.067419] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '09:33:15', on 'Mar 30 2022'.
[    2.067828] Mali:
[    2.067830] Mali device driver loaded
[    2.067859] rkisp rkisp-vir0: clear unready subdev num: 1
[    2.067875] rockchip-csi2-dphy0: No link between dphy and sensor
[    2.068386] rockchip-csi2-dphy0: No link between dphy and sensor
[    2.068402] rkisp-vir0: update sensor failed
[    2.068588] ALSA device list:
[    2.068602]   #0: rockchip,rk809-codec
[    2.068615]   #1: rockchip,hdmi
[    2.069835] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 244
[    2.070659] mmc3: new ultra high speed SDR104 SDIO card at address 0001
[    2.071190] Freeing unused kernel memory: 1536K
[    2.083600] Run /init as init process
[    2.107124] vendor storage:20190527 ret = 0
[    2.132761] udevd[122]: starting version 3.2.7
[    2.135368] udevd[122]: specified group 'kvm' unknown
[    2.139687] dwmmc_rockchip fe2b0000.dwmmc: Successfully tuned phase to 253
[    2.139723] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[    2.140052] udevd[123]: starting eudev-3.2.7
[    2.141131] mmcblk1: mmc1:aaaa SD32G 29.7 GiB
[    2.142980]  mmcblk1: p1
[    2.150863] devfreq fde60000.gpu: Couldn't update frequency transition information.
[    2.200194] asoc-**-card rk809-sound: ASoC: DAPM unknown pin Headphones
[    2.436295] dw-mipi-dsi fe070000.dsi: [drm:dw_mipi_dsi_encoder_enable] final DSI-Link bandwidth: 300 x 4 Mbps
[    2.473613] file system registered
[    2.503576] Mass Storage Function, version: 2009/09/11
[    2.503604] LUN: removable file: (no medium)
[    2.536123] read descriptors
[    2.536166] read strings
[    2.610269] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_disable] Crtc atomic disable vp1
[    2.667280] Freeing drm_logo memory: 700K
[    2.820191] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[    2.820194] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[    3.632143] EXT4-fs (mmcblk0p9): mounting ext2 file system using the ext4 subsystem
[    3.632469] EXT4-fs (mmcblk0p9): bad geometry: block count 2212859 exceeds size of device (2212856 blocks)
[    3.647335] EXT4-fs (mmcblk0p9): mounting ext2 file system using the ext4 subsystem
[    3.647685] EXT4-fs (mmcblk0p9): bad geometry: block count 2212859 exceeds size of device (2212856 blocks)
[    3.668446] EXT4-fs (mmcblk0p9): mounting ext2 file system using the ext4 subsystem
[    3.668876] EXT4-fs (mmcblk0p9): bad geometry: block count 2212859 exceeds size of device (2212856 blocks)
[    3.833530] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[    3.833577] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[    4.847114] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[    4.847213] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[    5.860443] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[    5.860480] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[    6.873649] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[    6.873759] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[    7.887047] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[    7.887134] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x1
[    8.900424] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[    8.900467] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[    9.913760] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[   10.927064] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[   10.927168] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[   11.940416] rk-pcie 3c0000000.pcie: PCIe Link Fail
[   11.940431] rk-pcie 3c0800000.pcie: PCIe Link Fail
[   11.940465] rk-pcie 3c0800000.pcie: failed to initialize host
[   11.940533] rk-pcie 3c0000000.pcie: failed to initialize host
发表于 2023-8-25 15:58:42 | 显示全部楼层
可以试下在/OK3568-linux-source/buildroot/board/rockchip/ok3568/fs-overlay-recovery/etc/init.d/S40_recovery内加上:
                touch /.rkdebug
                mount /dev/mmcblk1p1 /mnt/sdcard/
                /usr/bin/recovery &
之后全编译得到update.img制卡烧写测试。
 楼主| 发表于 2023-10-27 11:00:52 | 显示全部楼层
forqs 发表于 2023-8-25 15:58
可以试下在/OK3568-linux-source/buildroot/board/rockchip/ok3568/fs-overlay-recovery/etc/init.d/S40_re ...
非常感谢:handshake
GMT+8, 2026-9-21 03:44
