查看: 4395|回复: 1
[Linux] 将wm960的I2S3改为I2S0后出现错误
发表于 2023-9-8 17:13:44 | 显示全部楼层 |阅读模式
root@integrated:/root# fltest_audioplayer test.mp3 -d wm8960
|Space  key | start or pause    |
|Down   key | stop              |
|Left   key | seek backend      |
|Right  key | seek forward      |
|Up     key | audio sink        |
[ 1312.874432] sunxi-ahub-daudio ahub_daudio0: unsupport clk_div
[ 1312.880882] snddaudio snddaudio0: cpu_dai set clkdiv failed
[ 1312.887119] snddaudio snddaudio0: ASoC: machine hw_params failed: -22
Unable to open PCM (cannot set hw params: Invalid argument)
audiosink open failed
setUrl failed
Segmentation fault
RK3568通行证
发表于 2023-9-11 09:11:20 | 显示全部楼层
T507音频接口应用笔记中有一些相关的配置可以参考一下,检查一下需要关闭的一些默认功能和需要添加的一些节点有没有修改正确呀
GMT+8, 2026-9-18 05:38
