查看: 5606|回复: 6
[硬件咨询] 只有屏幕的1/4显示,但显示的正常,怎么处理能全部屏幕显示?
发表于 2023-9-25 16:55:43 | 显示全部楼层 |阅读模式
我在驱动另一款屏幕21寸,按照屏参,进行了配置,只有屏幕的1/4显示,但显示的正常,怎么处理能全部屏幕显示?
屏参:
Screen Diagonal [mm] 21.5”
Active Area [mm] 476.064 (H) x 267.786 (V)
Pixels H x V 1920(x3) x 1080
Signal Item Symbol Min Typ Max Unit
V-section
Period Tv 1094 1130 1836 Th
Active Tdisp(v) 1080 1080 1080 Th
Blanking Tbp(v)+Tfp(v)+PWvs 14 50 756 Th
H-section
Period Th 1000 1050 1678 Tclk
Active Tdisp(h) 960 960 960 Tclk
Blanking Tbp(h)+Tfp(h)+PWhs 40 90 718 Tclk
Clock
Period Tclk 11.2 14 18.6 ns
Frequency Freq. 53.7 71.2 90 MHz
Frame Rate Frame Rate 1/Tv 49 60 76 Hz
我配置的设备树:OKT507-C-Common.dtsi
lcd0: lcd0@01c0c000 {
        lcd_used            = <1>;
        lcd_driver_name     = "forlinx_gt911";
        lcd_backlight       = <250>;  // 根据屏幕资料调整
        lcd_if              = <3>;
        lcd_x               = <1920>;
        lcd_y               = <1080>;
        lcd_width           = <476>;  // 调整为屏幕的实际宽度
         lcd_height          = <268>;  // 调整为屏幕的实际高度
        lcd_dclk_freq       = <71>;   // 根据屏幕资料的中值调整
        lcd_pwm_used        = <0>;
        lcd_pwm_ch          = <0>;
        lcd_pwm_freq        = <50000>;
        lcd_pwm_pol         = <1>;
        lcd_pwm_max_limit   = <255>;
        /* hsync back porch(pixel) + hsync plus width(pixel)  */
        lcd_hbp                           = <130>;
        /* HBP + HFP + HSPW +   Horizontal Resolution */
        lcd_ht                                   = <2100>;
        /* Horizontal Sync Pluse Width */
        lcd_hspw                           = <20>;
        /* vsync back porch(line) + vysnc plus width(line) */
        lcd_vbp                           = <30>;
        /* VBP + VFP + VSPW + Vertical Resolution */
        lcd_vt                                   = <1130>;
        /* Vertical Sync Pluse Width  */
        lcd_vspw                           = <5>;
        lcd_lvds_if         = <1>;
        lcd_lvds_colordepth = <0>;
        lcd_lvds_mode       = <0>;
        lcd_frm             = <0>;
        lcd_hv_clk_phase    = <0>;
        lcd_hv_sync_polarity= <0>;
        lcd_gamma_en        = <0>;
        lcd_bright_curve_en = <0>;
        lcd_cmap_en         = <0>;
        lcd_fsync_en        = <0>;
        lcd_fsync_act_time  = <1000>;
        lcd_fsync_dis_time  = <1000>;
        lcd_fsync_pol       = <0>;
        deu_mode            = <0>;
        lcdgamma4iep        = <22>;
        smart_color         = <90>;
        lcd_pin_power = "bldo1";
        lcd_power = "dc1sw";
        lcd_bl_en        = <&pio PE 22 1 0 3 1>;
        pinctrl-0 = <&lvds2link_pins_a>;
        pinctrl-1 = <&lvds2link_pins_b>;
 楼主| 发表于 2023-9-25 16:58:12 | 显示全部楼层
我任职的公司在用飞凌T507在做产品样机,我一共遇到两个问题,随时等回复:)
发表于 2023-9-26 08:52:34 | 显示全部楼层
这个21寸的屏幕,屏幕显示的1/4是显示了全部的桌面信息还是也是1/4呢?您这个21寸的屏幕是什么类型的呢?电阻屏还是电容屏,他是hdmi还是lcd、mipi之类的呢?
2.1 Display Characteristics The following items are characteristics summary on the table under 25oC condition: ITEMS Unit SPECIFICATIONS Screen Diagonal [mm] 21.5” Active Area [mm] 476.064 (H) x  详情 回复 发表于 2023-9-26 10:05
2.0 General Description This specification applies to the 21.5 inch-wide Color AHVA (IPS-like) TFT-LCD Module G215HAN01.3 The display supports the FHD [1920(H) x 1080(V)] screen format and 16.7M col  详情 回复 发表于 2023-9-26 09:54
1.屏幕显示的1/4是显示了全部,21寸是  详情 回复 发表于 2023-9-26 09:50
 楼主| 发表于 2023-9-26 09:50:30 | 显示全部楼层
shuishui 发表于 2023-9-26 08:52
这个21寸的屏幕,屏幕显示的1/4是显示了全部的桌面信息还是也是1/4呢?您这个21寸的屏幕是什么类型的呢?电 ...
屏幕类型为: Module 21.5” Color TFT-LCD Model Name G215HAN01.3 电容屏  详情 回复 发表于 2023-9-26 09:53
 楼主| 发表于 2023-9-26 09:53:20 | 显示全部楼层
屏幕类型为:
电容屏
 楼主| 发表于 2023-9-26 09:54:46 | 显示全部楼层
The display supports the FHD [1920(H) x 1080(V)] screen format and 16.7M colors . All input signals are
LVDS inte**ce comaptible.
 楼主| 发表于 2023-9-26 10:05:33 | 显示全部楼层
Pixel Pitch [um] 247.95 (per one triad) ×247.95
Pixel Arrangement R.G.B. Vertical Stripe
Display Mode AHVA Mode, Normally Black
White Luminance ( Center ) [cd/m2
] 250 cd/m2 (Typ.)
Contrast Ratio 1000 (Typ.)
Optical Response Time [msec] 22
Nominal Input Voltage VDD [Volt] 5 V (Typ)
Power Consumption
(VDD line + LED line) [Watt]
11.1W (Typ.)
LCD module : PDD (Typ.)= 2.3 @ White
pattern,Fv=60Hz
Backlight unit : PBLU (Typ.) =8.8W
Weight [Grams] 1740 (Typ)
Physical Size [mm] 497.6(H) x 292.2(V) x 10.5 (D)Typ
Electrical Inte**ce Dual LVDS
Support Color 16.7M colors
Su**ce Treatment Anti-Glare, 3H
RoHS Compliance RoHS Compliance
GMT+8, 2026-10-4 13:16
