查看: 5037|回复: 9
[Linux] 开机一直重启,有时候开机还好好的,有时候就是下面的情况
RK3568通行证
发表于 2023-10-10 10:56:21 | 显示全部楼层 |阅读模式
开机中止启动log如下
[    0.535058] phy phy-fe8a0000.usb2-phy.1: No vbus specified for otg port
[    0.536123] extcon extcon1: failed to create extcon usb2-phy link
[    0.536369] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port
[    0.544551] rk-pcie 3c0000000.pcie: Linked as a consumer to regulator.3
[    0.544788] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.3
[    0.544843] rk-pcie 3c0000000.pcie: missing legacy IRQ resource
[    0.544867] rk-pcie 3c0000000.pcie: Missing *config* reg space
[    0.544886] rk-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges:
[    0.544913] rk-pcie 3c0000000.pcie:   err 0x300000000..0x3007fffff -> 0x00000000
[    0.544933] rk-pcie 3c0000000.pcie:    IO 0x300800000..0x3008fffff -> 0x00800000
[    0.544952] rk-pcie 3c0000000.pcie:   MEM 0x300900000..0x33fffffff -> 0x00900000
[    0.545289] pwm-backlight dsi1-backlight: dsi1-backlight supply power not found, using dummy regulator
[    0.545367] pwm-backlight dsi1-backlight: Linked as a consumer to regulator.0
[    1.563354] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    2.576682] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    3.590012] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    4.603345] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    5.616682] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    6.630014] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    7.643346] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    8.656680] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    9.670011] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[   10.683347] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[   11.696678] rk-pcie 3c0000000.pcie: PCIe Link Fail
[   11.696697] rk-pcie 3c0000000.pcie: failed to initialize host
发表于 2023-10-10 11:30:30 | 显示全部楼层
是自制底板吗
RK3568通行证
 楼主| 发表于 2023-10-10 11:37:48 | 显示全部楼层
是配套开发板
发表于 2023-10-10 11:56:37 | 显示全部楼层
是否修改过镜像,使用默认镜像会出现这个问题吗
RK3568通行证
 楼主| 发表于 2023-10-10 12:03:33 | 显示全部楼层
没有修改,有时候就好好的,有时候开机就这样然后一直重启。就是下载口按步骤在电脑上也不提示,内核也下载不了。
就是国庆前都是好好的,放了个假期,上午还开机成功了一次。然后我用reboot 就一直重启了。就修改了个netplan配网文件,别的啥也没动。
可以试试重新烧写默认镜像看看还会不会这样(使用K8按键,maskrom按键代替recovery进maskrom模式),按描述是只有reboot后有问题吗?断电再上电会这样吗  详情 回复 发表于 2023-10-10 13:12
发表于 2023-10-10 13:12:22 | 显示全部楼层
xxz 发表于 2023-10-10 12:03
没有修改,有时候就好好的,有时候开机就这样然后一直重启。就是下载口按步骤在电脑上也不提示,内核也下 ...
RK3568通行证
发表于 2023-10-10 13:41:16 | 显示全部楼层
看着像PCIe初始化失败+看门狗重启;
试着更换一个12V供电看看。
RK3568通行证
 楼主| 发表于 2023-10-10 13:42:27 | 显示全部楼层
forqs 发表于 2023-10-10 13:12
可以试试重新烧写默认镜像看看还会不会这样(使用K8按键,maskrom按键代替recovery进maskrom模式),按描 ...
断电再上电也有阿
看一下电源适配器是否是12v2A或3A,之前有发现使用稳压源在ubuntu系统上低于1.8A会概率出现无法启动/反复重启,linux系统不会。  详情 回复 发表于 2023-10-10 14:02
发表于 2023-10-10 14:02:56 | 显示全部楼层
xxz 发表于 2023-10-10 13:42
断电再上电也有阿
RK3568通行证
 楼主| 发表于 2023-10-10 14:46:13 | 显示全部楼层
forqs 发表于 2023-10-10 14:02
看一下电源适配器是否是12v2A或3A,之前有发现使用稳压源在ubuntu系统上低于1.8A会概率出现无法启动/反复 ...
一直重启,现在好了。不知道是啥原因。
GMT+8, 2026-9-21 03:44
