查看: 5375|回复: 1
[Android] im8mp烧写问题
i.MX6UL通行证i.MX8MP通行证RV1126通行证
发表于 2024-6-16 20:51:04 | 显示全部楼层 |阅读模式
hi,forlinx
im8mp ubuntu下烧写不成功:
  1. $ sudo ./uuu_imx_android_flash.sh -f imx8mp -e
  2. This script is validated with uuu 1.4.72 version, it is recommended to align with this version.
  3. dtbo is supported
  4. dual slot is supported
  5. dynamic parttition is supported
  6. vendor_boot parttition is supported
  7. skip flash bootloader0
  8. skip flash gpt
  9. skip flash dtbo_a
  10. skip flash boot_a
  11. skip flash vendor_boot_a
  12. skip flash vbmeta_a
  13. skip flash dtbo_b
  14. skip flash boot_b
  15. skip flash vendor_boot_b
  16. skip flash vbmeta_b
  17. skip flash super
  18. skip flash logo
  19. uuu script generated, start to invoke uuu with the generated uuu script
  20. uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.139-0-g1a8f760
  21. Success 0    Failure 1
  22.
  23.
  24. 1:1      9/14 [partition does not exist or uneraseabl] FB[-t 600000]: erase misc
请问这个问题怎么解决呢?
我的板子系统默认是Linux的,现在想烧写成Android的,使用的Android镜像是SDK包里自带的镜像。
另外,windows7下烧写也不成功:
  1. G:\workspace\forlinx\OKMX8MP\vmshare\uuu>uuu_imx_android_flash.bat -f imx8mp -e
  3. h this version.
  4. dtbo is supported
  5. dual slot is supported
  6. dynamic partition is supported
  7. vendor_boot is supported
  8. generate lines to flash u-boot-imx8mp.imx to the partition of bootloader0
  9. generate lines to flash partition-table.img to the partition of gpt
  10. generate lines to flash dtbo-imx8mp.img to the partition of dtbo_a
  11. generate lines to flash vendor_boot.img to the partition of vendor_boot_a
  12. generate lines to flash boot.img to the partition of boot_a
  13. generate lines to flash vbmeta-imx8mp.img to the partition of vbmeta_a
  14. generate lines to flash logo.img to the partition of logo
  15. generate lines to flash dtbo-imx8mp.img to the partition of dtbo_b
  16. generate lines to flash vendor_boot.img to the partition of vendor_boot_b
  17. generate lines to flash boot.img to the partition of boot_b
  18. generate lines to flash vbmeta-imx8mp.img to the partition of vbmeta_b
  19. generate lines to flash logo.img to the partition of logo
  20. generate lines to flash super.img to the partition of super
  21. uuu script generated, start to invoke uuu with the generated uuu script
  22. uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.139-0-g1a8f760
  23. Your console don't support VT mode, fail back to verbose mode
  24. Build in config:
  25.         Pctl     Chip            Vid     Pid     BcdVersion
  26.         ==================================================
  27.         SDPS:    MX8QXP          0x1fc9  0x012f  [0x0002..0xffff]
  28.         SDPS:    MX8QM           0x1fc9  0x0129  [0x0002..0xffff]
  29.         SDPS:    MX8DXL          0x1fc9  0x0147
  30.         SDPS:    MX28            0x15a2  0x004f
  31.         SDPS:    MX815           0x1fc9  0x013e
  32.         SDPS:    MX865           0x1fc9  0x0146
  33.         SDPS:    MX8ULP          0x1fc9  0x014a
  34.         SDPS:    MX8ULP          0x1fc9  0x014b
  35.         SDP:     MX7D            0x15a2  0x0076
  36.         SDP:     MX6Q            0x15a2  0x0054
  37.         SDP:     MX6D            0x15a2  0x0061
  38.         SDP:     MX6SL           0x15a2  0x0063
  39.         SDP:     MX6SX           0x15a2  0x0071
  40.         SDP:     MX6UL           0x15a2  0x007d
  41.         SDP:     MX6ULL          0x15a2  0x0080
  42.         SDP:     MX6SLL          0x1fc9  0x0128
  43.         SDP:     MX7ULP          0x1fc9  0x0126
  44.         SDP:     MXRT106X        0x1fc9  0x0135
  45.         SDP:     MX8MM           0x1fc9  0x0134
  46.         SDP:     MX8MQ           0x1fc9  0x012b
  47.         SDPU:    SPL             0x0525  0xb4a4  [0x0000..0x04ff]
  48.         SDPV:    SPL1            0x0525  0xb4a4  [0x0500..0x9998]
  49.         SDPU:    SPL             0x0525  0xb4a4  [0x9999..0x9999]
  50.         SDPU:    SPL             0x3016  0x1001  [0x0000..0x04ff]
  51.         SDPV:    SPL1            0x3016  0x1001  [0x0500..0x9998]
  52.         FBK:                     0x066f  0x9afe
  53.         FBK:                     0x066f  0x9bff
  54.         FB:                      0x0525  0xa4a5
  55.         FB:                      0x18d1  0x0d02
  56.         FB:                      0x3016  0x0001
  57. Wait for Known USB Device Appear...
  58. New USB Device Attached at 2:15
  59. 2:15>Start Cmd:SDPS: boot -f u-boot-imx8mp-evk-uuu.imx.link
  60. 100%2:15>Okay (3.151s)
  61. New USB Device Attached at 2:15
  62. 2:15>Fail Failure open usb device(1.845e+16s)
  63. [?25h
 楼主| 发表于 2024-6-20 21:49:19 | 显示全部楼层
ubuntu下换个uuu脚本
windows下还没有解决
GMT+8, 2026-9-14 01:39
