查看: 2491|回复: 1
[Linux] 3568接USB摄像头问题求助,只能抓拍320x240分辨率的图片
RK3568通行证
发表于 2024-8-13 16:27:37 | 显示全部楼层 |阅读模式
烦请大佬帮忙看看这个是什么情况?
按照说明书用v4l2进行抓拍,只有320*240这个分辨率能抓拍成功。
用其他分辨率就会卡住,命令执行不下去。下面是执行失败的记录
[root@ok3568:~]# 412-ct1 --list-devicesrkisp-statistics (platform:rkisp):
/dev/video7
/dev/video8
rkisp mainpath (platform:rkisp-vir0):
/dev/video0
/dev/video1
/dev/video2
/dev/video3
/dev/video4
/dev/video5
/dev/video6
YW500 (usb-fd880000.usb-1):
        /dev/video9
        /dev/video10
[root@ok3568:~]# v4l2-ctl --list-formats-ext -d /dev/video9
ioctl: VIDIOC_ENUM_FMT
        Type: Video Capture
        [0]: 'MJPG' (Motion-JPEG, compressed)
                Size: Discrete 1920x1080
                        Interval: Discrete 0.033s (30.000 fps)
                Size: Discrete 2048x1536
                Size: Discrete 2592x1944
                Size: Discrete 1600x1200
        [1]: 'YUYV' (YUYV 4:2:2)
                        Interval: Discrete 0.067s (15.000 fps)
[root@ok3568:~]#
[root@ok3568:~]# v4l2-ctl -V -d /dev/video9
Format Video Capture:
        Width/Height      : 1920/1080
        Pixel Format      : 'MJPG' (Motion-JPEG)
        Field             : None
        Bytes per Line    : 0
        Size Image        : 2073600
        Colorspace        : sRGB
        Transfer Function : Default (maps to sRGB)
        YCbCr/HSV Encoding: Default (maps to ITU-R 601)
        Quantization      : Default (maps to Full Range)
        Flags             :
[root@ok3568:~]# v4l2-ctl -v width=640,height=480,pixelformat=YUYV -d /dev/video
        Width/Height      : 640/480
        Pixel Format      : 'YUYV' (YUYV 4:2:2)
        Field             : None
        Bytes per Line    : 1280
        Size Image        : 614400
        Colorspace        : sRGB
        Quantization      : Default (maps to Limited Range)
        Flags             :
[root@ok3568:~]# gst-launch-1.0 v4l2src device=/dev/video9 num-buffers=1 !videoc
onvert !video/x-raw,format=NV12,width=640,height=480 ! mppjpegenc !filesink loca
Setting pipeline to PAUSED ...
mpp[769]: mpp_rt: NOT found ion allocator
mpp[769]: mpp_rt: found drm allocator
mpp[769]: mpp_info: mpp version: unknown mpp version for missing VCS info
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
mpp[769]: mpp_enc: MPP_ENC_SET_RC_CFG bps 576000 [540000 : 612000] fps [15:15] g        op 15
RK3568通行证
 楼主| 发表于 2024-8-15 11:19:35 | 显示全部楼层
[root@M3568:~]# gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=1 !videoco
nvert !video/x-raw,format=NV12,width=1600,height=1200 ! mppjpegenc !filesink loc
mpp[889]: mpp_rt: NOT found ion allocator
mpp[889]: mpp_rt: found drm allocator
mpp[889]: mpp_info: mpp version: 49f29006 author: Jeffy Chen    2021-08-04 [drm]: Add mmap flag detection
mpp[889]: mpp_enc: MPP_ENC_SET_RC_CFG bps 3600000 [3375000 : 3825000] fps [15:15] gop 15
libv4l2: error turning on stream: Input/output error
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
Additional debug info:
gstv4l2src.c(656): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Buffer pool activation failed
Execution ended after 0:00:00.050571791
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
GMT+8, 2026-9-21 03:48
