查看: 2697|回复: 1
[硬件咨询] IMX8MP如何使用uart1和uart3?
i.MX8MP通行证RK3568通行证RK3588通行证AM62x资料下载
发表于 2024-8-27 19:44:30 | 显示全部楼层 |阅读模式
参考IMX8MP的产品手册,uart2(地址0x30890000)为cortex-A53的debug uart,uart4(地址0x30a60000)为cortex-M7的debug uart,那么,其他两个串口uart1和uart3应该如何使用?
发表于 2024-9-3 14:24:23 | 显示全部楼层
这是地址,已经配置在A核linux使用了,uart3作为485,uart1作为蓝牙有接流控
uart3: serial@30880000 {
                                compatible = "fsl,imx8mp-uart", "fsl,imx6q-uart";
                                reg = <0x30880000 0x10000>;
                                interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
                                clocks = <&clk IMX8MP_CLK_UART3_ROOT>,
                                         <&clk IMX8MP_CLK_UART3_ROOT>;
                                clock-names = "ipg", "per";
                                dmas = <&sdma1 26 4 0>, <&sdma1 27 4 0>;
                                dma-names = "rx", "tx";
                                status = "disabled";
                                uart1: serial@30860000 {
                                reg = <0x30860000 0x10000>;
                                interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
                                clocks = <&clk IMX8MP_CLK_UART1_ROOT>,
                                         <&clk IMX8MP_CLK_UART1_ROOT>;
                                dmas = <&sdma1 22 4 0>, <&sdma1 23 4 0>;
GMT+8, 2026-10-5 22:50
