查看: 1267|回复: 1
[Linux] 开始的全编译出现错误
RK3568通行证RK3506通行证
发表于 2025-4-9 16:51:22 | 显示全部楼层 |阅读模式
./build.sh chip 后,无论选什么,后面的 ./build.sh,都会出现编译错误:
sudo: unknown user #1032
ERROR: Running /home/forlinx/work/OK3506_Linux_Source/device/rockchip/common/scripts/mk-kernel.sh - run_command failed!
ERROR: exit code 1 from line 36:
ERROR: call stack:
    build-helper: run_command(36)
    mk-kernel.sh: do_make_kernel_config(31)
    mk-kernel.sh: make_kernel_config(36)
    mk-kernel.sh: do_build(57)
    mk-kernel.sh: build_hook(438)
    mk-kernel.sh: main(496)
ERROR: Running /home/forlinx/work/OK3506_Linux_Source/device/rockchip/common/build-hooks/99-all.sh - build_all failed!
ERROR: exit code 1 from line 20:
    "$RK_SCRIPTS_DIR/mk-kernel.sh"
ERROR: call stack:
    99-all.sh: build_all(20)
    99-all.sh: build_hook(136)
    build-helper: try_func(63)
    build-helper: try_hook(96)
    build-helper: source(165)
    99-all.sh: main(147)
ERROR: Running /home/forlinx/work/OK3506_Linux_Source/device/rockchip/common/build-hooks/99-all.sh - try_func build_hook all failed!
ERROR: exit code 1 from line 67:
    build_hook
ERROR: call stack:
    build-helper: try_func(67)
请指点一下
i.MX6UL通行证RK3568通行证AM335x通行证
发表于 2025-4-11 09:32:43 | 显示全部楼层
从本人使用 3568 的经验来看,可能是,1、要全编译的系统与所用虚拟机不匹配,需咨询飞凌确认;2、所用主机能够给虚拟机的配置不足。
个人经验,仅供参考。
GMT+8, 2026-9-21 03:38
