查看: 4063|回复: 11
[Linux] RK3506
i.MX6UL通行证i.MX RT通行证RK3506通行证
发表于 2025-5-22 18:38:44 | 显示全部楼层 |阅读模式
才买了 RK3506J开发板。。。有没有一起填坑的  进来拍个爪:lol
RK3506通行证
发表于 2025-5-24 11:32:53 | 显示全部楼层
______666_______
RK3506通行证
发表于 2025-5-25 14:07:05 | 显示全部楼层
RK3506一起学习
RK3506通行证
发表于 2025-5-25 14:54:47 | 显示全部楼层
资料都没有,问客服半天不回
RK3506通行证
发表于 2025-5-25 19:24:22 | 显示全部楼层
这款开发板不适合新手吗?没看到新手教程
 楼主| 发表于 2025-5-29 21:43:32 | 显示全部楼层
:) 新出来的,资料少得可怜,慢慢摸。。。我已经在开始画底板了
发表于 2025-6-1 00:03:03 | 显示全部楼层
刚买了开发板,一起折腾
RK3506通行证
发表于 2025-6-8 20:46:39 | 显示全部楼层
果断下单一片,不过断货了,要等17号才能发货。一起学习
发表于 2025-6-21 18:37:32 | 显示全部楼层
才收到货,联网用了一会,网络就断开了,再也恢复不了网络
RK3506通行证
发表于 2025-10-27 13:57:51 | 显示全部楼层
GPIO4 PB2开发板默认是作为SARADC_IN2 ADC使用,我想改成GPIO口输入,在dts里面配置了,但读到的值始终是0
    saradc {
        // 通道1作为ADC
        saradc_ch1: saradc-ch1 {
            rockchip,pins = <4 RK_PB1 1 &pcfg_pull_none>;
        // 其他通道作为GPIO
        saradc_ch0_gpio: saradc-ch0-gpio {
            rockchip,pins = <4 RK_PB0 1 &pcfg_pull_none>;
        saradc_ch2_gpio: saradc-ch2-gpio {
            rockchip,pins = <4 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
        saradc_ch3_gpio: saradc-ch3-gpio {
            rockchip,pins = <4 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>;
        mylabe: my_trigger0 {
    compatible = "iio_interrupt_trigger";
        pinctrl-names = "default";
        pinctrl-0 = <&adc_irq_gpio>;
    interrupt-parent = <&gpio1>;
        interrupts = <RK_PB2 IRQ_TYPE_EDGE_FALLING>;
        gpios = <&gpio4 RK_PB2 GPIO_ACTIVE_LOW>;
    status = "okay";
root@ok3506-buildroot:/sys/bus/iio/devices/iio:devicel# cd /sys/class/gpio/
root@ok3506-buildroot:/sys/class/gpio#ls
export gpiochipo gpiochip128 gpiochip32 gpiochip64 gpiochip96 unexport
root@ok3506-buildroot:/sys/class/gpio# echo 138 > export
root@ok3506-buildroot:/sys/class/gpio# cd gpio138
root@ok3506-buildroot:/sys/class/gpio/gpio138#ls
active lowdevice direction edge powersubsvstem ueventvalue
root@ok3506-buildroot:/sys/class/gpio/gpio138# cat direction
in
root@ok3506-buildroot:/sys/class/gpio/gpio138# cat value
root@ok3506-buildroot:/sys/class/gpio/gpio138# echo out > direction
root@ok3506-buildroot:/sys/class/gpio/gpio138#:echo 1>value
rootdok3506-buildroot:/sys/class/gpio/gpio138#echo 0>value
root@ok3506-buildroot:/sys/class/gpio/gpio138#cat value
root@ok3506-buildroot:/sys/class/gpio/gpio138#echo 1>value
作为输入时,无论输入0,1,cat value始终是0
作为输出,万用表量可以输出0,1;但cat value都是0
T153通行证
发表于 2026-5-9 14:15:21 | 显示全部楼层
我也刚买了一块3506 MINI开发板,发现上手挺难啊。。
RK3506通行证
发表于 2026-6-12 23:51:19 | 显示全部楼层
我想说的是,Uboot源码在哪里?这都不提供吗?只放了一个image文件?
GMT+8, 2026-9-25 12:18
