查看: 2426|回复: 3
[Linux] rk3506 编译报错
RK3506通行证
发表于 2025-8-2 19:03:53 | 显示全部楼层 |阅读模式
各位大佬 在编译 OK3506J-S_Linux6.1.99+Qt5.15.11_用户资料_R2文件夹下的OK3506.bz2源码时报错
具体报错如下+ ln -rsf kernel/zboot.img /home/forlinx/work/3506r2/3506/output/firmware/boot.i        mgNot Found io-domains in kernel/arch/arm/boot/dts/OK3506-S_linux_emmc.dts
Running mk-kernel.sh - build_kernel succeeded.
          Start building rootfs(buildroot)
          Start building buildroot(2024.02)
/home/forlinx/work/3506r2/3506/device/rockchip/common/scripts/check-network.sh:        line 7: curl: command not found
Your network is not able to access sources.buildroot.net!
Please retry later (it could be down for a while) or setup a VPN to bypass the G        FW.
Unset RK_NETWORK_CHECK in the SDK config to continue...
ERROR: Running /home/forlinx/work/3506r2/3506/device/rockchip/common/scripts/mk-        rootfs.sh - build_buildroot failed!
ERROR: exit code 1 from line 16:
    "$RK_SCRIPTS_DIR/mk-buildroot.sh" $RK_BUILDROOT_CFG "$IMAGE_DIR"
ERROR: call stack:
    mk-rootfs.sh: build_buildroot(16)
    mk-rootfs.sh: build_hook(297)
    mk-rootfs.sh: main(326)
ERROR: Running /home/forlinx/work/3506r2/3506/device/rockchip/common/build-hooks        /99-all.sh - build_all failed!
ERROR: exit code 1 from line 21:
    "$RK_SCRIPTS_DIR/mk-rootfs.sh"
ERROR: call stack:
    99-all.sh: build_all(21)
    99-all.sh: build_hook(136)
    build-helper: try_func(63)
    build-helper: try_hook(96)
    build-helper: source(165)
    99-all.sh: main(147)
ERROR: Running /home/forlinx/work/3506r2/3506/device/rockchip/common/build-hooks        /99-all.sh - try_func build_hook all failed!
ERROR: exit code 1 from line 67:
    build_hook
ERROR: call stack:
    build-helper: try_func(67)
使用ssh登陆虚拟机  ping 网关和baidu多是通的
请问有可能是什么问题呢?
第二个问题
开机按住rec键  进入rec模式
选择下载工具 局部下载时需要需要读取分区表 但读取时一堆错误
具体如下 请问会是什么原因造成的
RK3506通行证
 楼主| 发表于 2025-8-2 22:33:14 | 显示全部楼层
搞定了  是dns解析错误 设置dns为自己的路由器就好了
RK3568通行证RK3506通行证
发表于 2025-9-6 10:57:41 | 显示全部楼层
这个编译报错,我也遇到了
发表于 2026-8-24 11:45:04 | 显示全部楼层
有可能是有些库需要科学上网
GMT+8, 2026-9-15 09:09
