查看: 1665|回复: 1
[Linux] OK3506B-S12启动失败
RK3506通行证
发表于 2025-9-17 16:23:15 | 显示全部楼层 |阅读模式
OK3506B-S12 emmc板子,出厂没有emmc固件,自己编译后,无法启动。
自己分区的信息如下:
FIRMWARE_VER: 8.1
MACHINE_MODEL: RK3506
MACHINE_ID: 007
MANUFACTURER: RK3506
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: 3506
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
TYPE: GPT
GROW_ALIGN: 0
CMDLINE: mtdparts=:0x00002000@0x00002000(uboot),0x00000800@0x00004000(misc),0x00005000@0x00004800(boot),0x00008000@0x00009800(recovery),0x00080000@0x00011800(rootfs),0x00008000@0x00091800(oem),-@0x00099800(userdata:grow)
uuid:rootfs=614e0000-0000-4b53-8000-1d28000054a9
uuid:boot=7A3F0000-0000-446A-8000-702F00006273
启动信息如下:
DDR 0ac6b06a19 typ 24/11/13-17:22:47,fwver: v1.04
tREFI:4x, sr_idle:93, pd_idle:13
PHY drv:clk:40,ca:48,DQ:40,odt:240
vrefinner:50%, vrefout:50%
dram drv:40,odt:120
sr_dq:0, sr_ca:0, sr_clk:0
rg:0x37-0x0-0x2, 0x30-0x0-0x2,status:a007
rdtrn:0x11-0x2f-0x4d(0x3c)
wrtrn:0x0-0x20-0x3f(0x3f)
DDR3, 750MHz
BW=16 Col=10 Bk=8 CS0 Row=15 CS=1 Size=512MB
out
U-Boot SPL board init
U-Boot SPL 2017.09-g3fe339f #zmx (Jul 10 2025 - 10:06:23)
sfc cmd=03H(6BH-x4)
SPI Nand ID e5 b4 e5
unrecognized JEDEC id bytes: ff, e5, b4
Trying to boot from MTD1
SPL: A/B-slot: _a, successful: 0, tries-remain: 7
Trying fit image at 0x2000 sector
## Verified-boot: 0
## Checking optee 0x00001000 ... sha256(690eb8a14d...) + OK
## Checking uboot 0x00200000 ... sha256(f8eb3e03fb...) + OK
## Checking fdt 0x002a4b30 ... sha256(a3e730b8af...) + OK
Jumping to U-Boot(0x00200000) via OP-TEE(0x00001000)
Total: 114.655/180.369 ms
I/TC:
I/TC: Status: cluster=0xc00, core=0xe100, bootcpu=0
I/TC: Next entry point address: 0x00200000
I/TC: OP-TEE version: 3.13.0-894-g0e7e5b3c7ff #chenjh (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Tue Nov 12 09:21:23 CST 2024 arm, fwver: v1.25
I/TC: OP-TEE memory: TEEOS 0x5e000 TA 0x1000 SHM 0x1000
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
U-Boot 2017.09-g3fe339f #zmx (Jul 10 2025 - 10:06:23 +0800)
Model: Forlinx OK3506-S Board
MPIDR: 0xf00
PreSerial: 0, raw, 0xff0a0000
DRAM:  512 MiB
Sysmem: init
Relocation Offset: 1d4ef000
Relocation fdt: 1c4fa910 - 1c4fede0
CR: M/C/I
DM: v2
Bootdev(atags): mtd 1
PartType: EFI
boot mode: None
RESC: 'boot', blk@0x000074ee
resource: sha256+
FIT: no signed, no conf required
DTB: rk-kernel.dtb
HASH(c): OK
vdd_cpu init 1011000 uV
I2c0 speed: 400000Hz
I2c2 speed: 400000Hz
params load
Could not find baseparameter partition
read eth0 mac form vendor_storage error! try to read from eeprom
read eth0 mac from eeprom is ff:ff:ff:ff:ff:ff
read eth0 mac from eeprom error, use default mac address.
cpuid: 4D 34 48 37 35 30 00 00 00 00 00 00 00 0D 14 17
read eth1 mac form vendor_storage error! try to read from eeprom
read eth1 mac from eeprom is ff:ff:ff:ff:ff:ff
read eth1 mac from eeprom error, use default mac address.
Rockchip UBOOT DRM driver version: v1.0.1
Using display timing dts
dsi@ff640000:  detailed mode clock 46000 kHz, flags[a]
    H: 1024 1084 1264 1324
    V: 0600 0605 0607 0617
bus_format: 100e
VOP:0xff600000 update mode to: 1024x600p56, type: MIPI0
VOP:0xff600000 set crtc_clock to 46000KHz, get 45454545Hz
Unsupported bt709f at 10bit csc depth, use bt601f instead
VOP:0xff600000 set plane [400x300->400x300@312x150] fmt[0] addr[0x1d900000]
final DSI-Link bandwidth: 612 Mbps x 2
CLK: (arm clk use pvtpll, rate = 1200M)
  gpll 1500000 KHz
  v0pll 1179648 KHz
  v1pll 903168 KHz
  clk_gpll_div 187500 KHz
  clk_gpll_div_100m 93750 KHz
  clk_v0pll_div 147456 KHz
  clk_v1pll_div 129024 KHz
  aclk_bus_root 187500 KHz
  hclk_bus_root 147456 KHz
  pclk_bus_root 93750 KHz
  aclk_hsperi_root 147456 KHz
  hclk_ksperi_root 93750 KHz
Can't find device id=0x49
rk_board_late_init: Cannot get lt8912b:-19
Net:   eth0: ethernet@ff4c8000
Hit key to stop autoboot('Spacebar'):  0
## Booting FIT Image at 0x1bd59d00 with size 0x0059dc00
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 1bd59d00 ...
   Using 'conf' configuration
## Verified-boot: 0
   Trying 'kernel' kernel subimage
     Description:  unavailable
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x1bd67100
     Data Size:    5834264 Bytes = 5.6 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x01100000
     Entry Point:  0x01100000
     Hash algo:    sha256
     Hash value:   e113d564c88d3e4d2cd5629829eaa128cbd584e9bf2a74b0a76f595734010f95
   Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at 1bd59d00 ...
   Trying 'fdt' fdt subimage
     Type:         Flat Device Tree
     Data Start:   0x1bd5a500
     Data Size:    51722 Bytes = 50.5 KiB
     Architecture: ARM
     Load Address: 0x00063000
     Hash algo:    sha256
     Hash value:   fa09370404b7fd24e35b92c32e19c2f687d9768b1dd1cf7e43d61584c02a074a
   Loading fdt from 0x00063000 to 0x00063000
   Booting using the fdt blob at 0x00063000
   Loading Kernel Image from 0x1bd67100 to 0x01100000 ... OK
   kernel loaded at 0x01100000, end = 0x01690618
   Using Device Tree in place at 00063000, end 00072a09
Unable to update property dsi@ff640000:status, err=FDT_ERR_BADPATH
## reserved-memory:
  trust@0: addr=0 size=62000
  drm-logo@0: addr=1d900000 size=ec000
  ramoops@83000: addr=83000 size=2d000
Adding bank: 0x00000000 - 0x20000000 (size: 0x20000000)
Total: 2102.686/2329.625 ms
Starting kernel ...
[    2.455163] Booting Linux on physical CPU 0xf00
[    2.455184] Linux version 6.1.99 (forlinx@ubuntu) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #1 SMP PREEMPT Tue Sep 16 13:09:14 CST 2025
[    2.455194] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
[    2.455205] CPU: div instructions available: patching division code
[    2.455210] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    2.455541] OF: fdt: Machine model: Forlinx OK3506-S Board
[    2.457962] earlycon: uart8250 at MMIO32 0xff0a0000 (options '')
[    2.524314] printk: bootconsole [uart8250] enabled
[    2.529351] Memory policy: Data cache writealloc
[    2.534349] Reserved memory: created CMA memory pool at 0x1ea00000, size 22 MiB
[    2.541928] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    2.550641] Zone ranges:
[    2.553288]   Normal   [mem 0x0000000000000000-0x000000001fffffff]
[    2.559699] Movable zone start for each node
[    2.564126] Early memory node ranges
[    2.567835]   node   0: [mem 0x0000000000000000-0x000000001fffffff]
[    2.574328] Initmem setup node 0 [mem 0x0000000000000000-0x000000001fffffff]
[    2.599184] psci: probing for conduit method from DT.
[    2.604322] psci: PSCIv1.0 detected in firmware.
[    2.609099] psci: Using standard PSCI v0.2 function IDs
[    2.614508] psci: MIGRATE_INFO_TYPE not supported.
[    2.619465] psci: SMC Calling Convention v1.1
[    2.624115] percpu: Embedded 11 pages/cpu s16340 r8192 d20524 u45056
[    2.630821] Built 1 zonelists, mobility grouping on.  Total pages: 130048
[    2.637869] Kernel command line: storagemedia=mtd androidboot.storagemedia=mtd androidboot.mode=normal  rw rootwait earlycon=uart8250,mmio32,0xff0a0000 console=ttyFIQ0 root=PARTUUID=614e0000-0000 snd_aloop.index=7 snd_aloop.use_raw_jiffies=1 mtdparts=spi-nand0:0x400000@0x400000(uboot),0x100000@0x800000(misc),0xa00000@0x900000(boot),0x1000000@0x1300000(recovery),0x10000000@0x2300000(rootfs),0x1000000@0x12300000(oem),0xcc60000@0x13300000(userdata) #z-07/10/2025 androidboot.fwver=ddr-v1.04-0ac6b06a19,tee-v1.25,uboot-3fe339f user_debug=31
[    2.687510] Unknown kernel command line parameters "#z-07/10/2025 storagemedia=mtd", will be passed to user space.
[    2.698394] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    2.706364] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    2.714214] mem auto-init: stack:off, heap alloc:off, heap free:off
[    2.733391] Memory: 486000K/524288K available (4932K kernel code, 1119K rwdata, 2460K rodata, 188K init, 359K bss, 15760K reserved, 22528K cma-reserved)
[    2.747686] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=3, Nodes=1
[    2.754662] rcu: Preemptible hierarchical RCU implementation.
[    2.760626] rcu:     RCU event tracing is enabled.
[    2.765322] rcu:     RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=3.
[    2.772086] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    2.779927] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=3
[    2.786680] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    2.793526] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    2.811067] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[    2.817419] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    2.828603] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    2.836904] Switching to timer-based delay loop, resolution 41ns
[    2.843670] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    2.854353] CPU: Testing write buffer coherency: ok
[    2.859355] pid_max: default: 4096 minimum: 301
[    2.864045] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    2.871656] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    2.880488] /cpus/cpu@f00 missing clock-frequency property
[    2.886250] /cpus/cpu@f01 missing clock-frequency property
[    2.891970] /cpus/cpu@f02 missing clock-frequency property
[    2.897684] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    2.904463] Setting up static identity map for 0x108240 - 0x108294
[    2.911105] rcu: Hierarchical SRCU implementation.
[    2.916114] rcu:     Max phase no-delay instances is 1000.
[    2.922275] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
[    2.935524] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    2.944138] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    2.944265] smp: Brought up 1 node, 3 CPUs
[    2.960472] SMP: Total of 3 processors activated (144.00 BogoMIPS).
[    2.966974] CPU: All CPU(s) started in SVC mode.
[    2.972601] devtmpfs: initialized
[    2.986031] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    2.994228] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    3.004347] futex hash table entries: 16 (order: -2, 1024 bytes, linear)
[    3.011384] pinctrl core: initialized pinctrl subsystem
[    3.018048] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    3.024779] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    3.032706] Registered FIQ tty driver
[    3.036840] thermal_sys: Registered thermal governor 'step_wise'
[    3.036853] thermal_sys: Registered thermal governor 'user_space'
[    3.043176] cpuidle: using governor menu
[    3.055202] ramoops: boot-log-0      0xd000@0x00083000
[    3.060278] ramoops: console 0x20000@0x00090000
[    3.065294] printk: console [ramoops-1] enabled
[    3.069995] pstore: Registered ramoops as persistent store backend
[    3.076405] ramoops: using 0x2d000@0x83000, ecc: 0
[    3.092406] rockchip-gpio ff940000.gpio: probed /pinctrl/gpio@ff940000
[    3.099956] rockchip-gpio ff870000.gpio: probed /pinctrl/gpio@ff870000
[    3.107460] rockchip-gpio ff1c0000.gpio: probed /pinctrl/gpio@ff1c0000
[    3.114942] rockchip-gpio ff1d0000.gpio: probed /pinctrl/gpio@ff1d0000
[    3.122518] rockchip-gpio ff1e0000.gpio: probed /pinctrl/gpio@ff1e0000
[    3.129414] rockchip-pinctrl pinctrl: probed pinctrl
[    3.136725] platform ff600000.vop: Fixed dependency cycle(s) with /dsi@ff640000
[    3.144466] platform ff640000.dsi: Fixed dependency cycle(s) with /dsi@ff640000/panel@0
[    3.152802] platform ff640000.dsi: Fixed dependency cycle(s) with /vop@ff600000
[    3.172131] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ fiq not found
[    3.179155] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ wakeup not found
[    3.186452] fiq_debugger_probe: could not install nmi irq handler
[[    3.192919] printk: console [ttyFIQ0] enabled
[    3.201797] printk: bootconsole [uart8250] disabled
[    3.207145] Registered fiq debugger ttyFIQ0
[    3.210723] SCSI subsystem initialized
[    3.210962] usbcore: registered new inte**ce driver usbfs
[    3.211024] usbcore: registered new inte**ce driver hub
[    3.211081] usbcore: registered new device driver usb
[    3.211378] mc: Linux media inte**ce: v0.10
[    3.211494] videodev: Linux video capture inte**ce: v2.00
[    3.211546] pps_core: LinuxPPS API ver. 1 registered
[    3.211560] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    3.211588] PTP clock support registered
[    3.212803] Advanced Linux Sound Architecture Driver Initialized.
[    3.213347] Bluetooth: Core ver 2.22
[    3.213425] NET: Registered PF_BLUETOOTH protocol family
[    3.213443] Bluetooth: HCI device and connection manager initialized
[    3.213464] Bluetooth: HCI socket layer initialized
[    3.213480] Bluetooth: L2CAP socket layer initialized
[    3.213509] Bluetooth: SCO socket layer initialized
[    3.214192] rockchip-cpuinfo cpuinfo: SoC            : 35060000
[    3.214229] rockchip-cpuinfo cpuinfo: Serial         : 6f17e9525e443a7c
[    3.215146] clocksource: Switched to clocksource arch_sys_counter
[    3.217320] NET: Registered PF_INET protocol family
[    3.21756E/TC:0   plat_shm_get_page_num:373 plat_shm_get_page_num: type 6 alloc is not supported
9] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    3.219062] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    3.219113] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    3.219140] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    3.219183] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    3.219307] TCP: Hash tables configured (established 4096 bind 4096)
[    3.219435] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    3.219488] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    3.219740] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    3.222339] rockchip-thermal ff650000.tsadc: tsadc is probed successfully!
[    3.223533] Initialise system trusted keyrings
[    3.223824] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[    3.227780] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    3.228014] ntfs: driver 2.1.32 [Flags: R/W DEBUG].
[    3.228177] ntfs3: Enabled Linux POSIX ACLs support
[    3.228197] ntfs3: Read-only LZX/Xpress compression included
[    3.228276] fuse: init (API version 7.37)
[    3.294428] Key type asymmetric registered
[    3.294466] Asymmetric key parser 'x509' registered
[    3.294597] io scheduler mq-deadline registered
[    3.294618] io scheduler kyber registered
[    3.294771] io scheduler bfq registered
[    3.296456] rockchip-usb2phy ff2b0000.usb2-phy: error -ENXIO: IRQ index 0 not found
[    3.300040] rockchip-pwm ff931000.pwm: No active pinctrl state
[    3.300865] pwm-backlight backlight: supply power not found, using dummy regulator
[    3.305291] dma-pl330 ff000000.dma-controller: Loaded driver for PL330 DMAC-241330
[    3.305328] dma-pl330 ff000000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    3.306846] dma-pl330 ff008000.dma-controller: Loaded driver for PL330 DMAC-241330
[    3.306881] dma-pl330 ff008000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    3.307260] rockchip-sI/TC: ddr_plat_smc_handler: default
ystem-monitor rockchip-system-monitor: system monitor probe
[    3.308547] Serial: 8250/I/TC: ddr_plat_smc_handler: unhandled DDR SMC id(0x13)
16550 driver, 6 ports, IRQ sharing disabled
[    3.309207] ff0b0000.serial: ttyS1 at MMIO 0xff0b0000 (irq = 47, base_baud = 1500000) is a 16550A
[    3.310444] random: crng init done
[    3.312523] dw-mipi-dsi-rockchip ff640000.dsi: Fixed dependency cycle(s) with /dsi@ff640000/panel@0
[    3.312655] mipi-dsi ff640000.dsi.0: Fixed dependency cycle(s) with /dsi@ff640000
[    3.315797] rockchip-drm display-subsystem: bound ff600000.vop (ops 0xb072bcf8)
[    3.315863] dw-mipi-dsi-rockchip ff640000.dsi: failed to find panel or bridge: -517
[    3.335436] no ATF memory for init
[    3.340837] rockchip-spi ff120000.spi: no high_speed pinctrl state
[    3.342022] rockchip-spi ff120000.spi: probed, poll=0, rsd=0, cs-inactive=0, ready=0
[    3.342566] rockchip-spi ff130000.spi: no high_speed pinctrl state
[    3.343468] rockchip-spi ff130000.spi: probed, poll=0, rsd=0, cs-inactive=0, ready=0
[    3.344967] CAN device driver inte**ce
[    3.345844] rk_gmac-dwmac ff4c8000.ethernet: IRQ eth_lpi not found
[    3.346039] rk_gmac-dwmac ff4c8000.ethernet: supply phy not found, using dummy regulator
[    3.346219] rk_gmac-dwmac ff4c8000.ethernet: clock input or output? (output).
[    3.346246] rk_gmac-dwmac ff4c8000.ethernet: Can not read property: tx_delay.
[    3.346259] rk_gmac-dwmac ff4c8000.ethernet: set tx_delay to 0xffffffff
[    3.346274] rk_gmac-dwmac ff4c8000.ethernet: Can not read property: rx_delay.
[    3.346286] rk_gmac-dwmac ff4c8000.ethernet: set rx_delay to 0xffffffff
[    3.346309] rk_gmac-dwmac ff4c8000.ethernet: integrated PHY? (no).
[    3.346330] rk_gmac-dwmac ff4c8000.ethernet: cannot get clock mac_clk_rx
[    3.346346] rk_gmac-dwmac ff4c8000.ethernet: cannot get clock mac_clk_tx
[    3.346378] rk_gmac-dwmac ff4c8000.ethernet: cannot get clock clk_mac_ref
[    3.346396] rk_gmac-dwmac ff4c8000.ethernet: cannot get clock clk_mac_refout
[    3.346412] rk_gmac-dwmac ff4c8000.ethernet: cannot get clock clk_mac_speed
[    3.346671] rk_gmac-dwmac ff4c8000.ethernet: init for RMII
[    3.346949] rk_gmac-dwmac ff4c8000.ethernet: User ID: 0x40, Synopsys ID: 0x51
[    3.346986] rk_gmac-dwmac ff4c8000.ethernet:         DWMAC4/5
[    3.347003] rk_gmac-dwmac ff4c8000.ethernet: DMA HW capability register supported
[    3.347017] rk_gmac-dwmac ff4c8000.ethernet: RX Checksum Offload Engine supported
[    3.347031] rk_gmac-dwmac ff4c8000.ethernet: TX Checksum insertion supported
[    3.347043] rk_gmac-dwmac ff4c8000.ethernet: Wake-Up On Lan supported
[    3.347145] rk_gmac-dwmac ff4c8000.ethernet: TSO supported
[    3.347164] rk_gmac-dwmac ff4c8000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.347180] rk_gmac-dwmac ff4c8000.ethernet: Enabled RFS Flow TC (entries=10)
[    3.347196] rk_gmac-dwmac ff4c8000.ethernet: TSO feature enabled
[    3.347210] rk_gmac-dwmac ff4c8000.ethernet: Using 40/40 bits DMA host/device width
[    4.360481] PPP generic driver version 2.4.2
[    4.360780] usbcore: registered new inte**ce driver asix
[    4.360849] usbcore: registered new inte**ce driver ax88179_178a
[    4.360896] usbcore: registered new inte**ce driver cdc_ether
[    4.360942] usbcore: registered new inte**ce driver net1080
[    4.360999] usbcore: registered new inte**ce driver cdc_subset
[    4.361056] usbcore: registered new inte**ce driver zaurus
[    4.361131] usbcore: registered new inte**ce driver cdc_ncm
[    4.361175] usbcore: registered new inte**ce driver qmi_wwan
[    4.361218] usbcore: registered new inte**ce driver r8153_ecm
[    4.361945] dwc2 ff740000.usb: supply vusb_d not found, using dummy regulator
[    4.362132] dwc2 ff740000.usb: supply vusb_a not found, using dummy regulator
[    4.491910] dwc2 ff740000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[    4.492133] dwc2 ff740000.usb: DWC OTG Controller
[    4.492179] dwc2 ff740000.usb: new USB bus registered, assigned bus number 1
[    4.492225] dwc2 ff740000.usb: irq 53, io mem 0xff740000
[    4.493013] hub 1-0:1.0: USB hub found
[    4.493076] hub 1-0:1.0: 1 port detected
[    4.494102] dwc2 ff780000.usb: supply vusb_d not found, using dummy regulator
[    4.494286] dwc2 ff780000.usb: supply vusb_a not found, using dummy regulator
[    4.625219] dwc2 ff780000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[    4.625398] dwc2 ff780000.usb: DWC OTG Controller
[    4.625442] dwc2 ff780000.usb: new USB bus registered, assigned bus number 2
[    4.625486] dwc2 ff780000.usb: irq 54, io mem 0xff780000
[    4.626264] hub 2-0:1.0: USB hub found
[    4.626329] hub 2-0:1.0: 1 port detected
[    4.627443] usbcore: registered new inte**ce driver cdc_wdm
[    4.627565] usbcore: registered new inte**ce driver usb-storage
[    4.627675] usbcore: registered new inte**ce driver option
[    4.627714] usbserial: USB Serial support registered for GSM modem (1-port)
[    4.627879] usbcore: registered new inte**ce driver cdc_xr_usb_serial
[    4.627900] xr_usb_serial_common: Exar USB UART (serial port) driver
[    4.628635] i2c_dev: i2c /dev entries driver
[    4.630064] edt_ft5x06 0-0038: supply vcc not found, using dummy regulator
[    4.630281] edt_ft5x06 0-0038: supply iovcc not found, using dummy regulator
[    4.632476] rtc-pcf8563 2-0051: pcf8563_write_block_data: err=-6 addr=0e, data=03
[    4.632515] rtc-pcf8563 2-0051: pcf8563_probe: write error
[    4.632584] rtc-pcf8563: probe of 2-0051 failed with error -5
[    4.634362] usbcore: registered new inte**ce driver btusb
[    4.634567] cpu cpu0: bin=0
[    4.634642] cpu cpu0: leakage=4
[    4.635603] cpu cpu0: pvtm=1556
[    4.636275] cpu cpu0: pvtm-volt-sel=0
[    4.637469] cpu cpu0: avs=0
[    4.637700] cpu cpu0: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=1
[    4.638375] Synopsys Designware ** Card Inte**ce Driver
[    4.639696] dwmmc_rockchip ff480000.mmc: No normal pinctrl state
[    4.639736] dwmmc_rockchip ff480000.mmc: No idle pinctrl state
[    4.639974] dwmmc_rockchip ff480000.mmc: IDMAC supports 32-bit address mode.
[    4.640024] dwmmc_rockchip ff480000.mmc: Using internal DMA controller.
[    4.640046] dwmmc_rockchip ff480000.mmc: Version ID is 270a
[    4.640128] dwmmc_rockchip ff480000.mmc: DW MMC controller at irq 59,32 bit host data width,256 deep fifo
[    4.640222] usbcore: registered new inte**ce driver usbhid
[    4.640243] usbhid: USB HID core driver
[    4.640607] mmc_host mmc0: card is non-removable.
[    4.643934] rk_dsm ff4b0000.acdcdig-dsm: ioremap ioc res[0] start: 0xff660000 success
[    4.643979] rk_dsm ff4b0000.acdcdig-dsm: ioremap ioc res[1] start: 0xff4d8000 success
[    4.644131] rk_dsm ff4b0000.acdcdig-dsm: iomuxes audm_en: 0x1
[    4.644182] rk_dsm ff4b0000.acdcdig-dsm: no need pa-ctl gpio
[    4.647999] Initializing XFRM netlink socket
[    4.648076] NET: Registered PF_PACKET protocol family
[    4.648105] NET: Registered PF_KEY protocol family
[    4.648120] can: controller area network core
[    4.648192] NET: Registered PF_CAN protocol family
[    4.648213] can: raw protocol
[    4.648235] can: broadcast manager protocol
[    4.648256] can: netlink gateway - max_hops=1
[    4.648550] Bluetooth: RFCOMM socket layer initialized
[    4.648627] Bluetooth: RFCOMM ver 1.11
[    4.648658] [BT_RFKILL]: Enter rfkill_rk_init
[    4.648671] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    4.649918] Registering SWP/SWPB emulation handler
[    4.650267] Loading compiled-in X.509 certificates
[    4.652756] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    4.657391] rga2 ff610000.rga: probe successfully, irq = 63, hw_version:3.a.07135
[    4.657608] rga: IOMMU binding successfully, default mapping core[0x4]
[    4.657908] rga: Module initialized. v1.3.6
[    4.678118] rockchip-drm display-subsystem: bound ff600000.vop (ops 0xb072bcf8)
[    4.678284] rockchip-drm display-subsystem: bound ff640000.dsi (ops 0xb072d26c)
[    4.679549] [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0
[    4.684942] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    4.694611] rockchip-drm display-subsystem: [drm] run display error_event monitor
[    4.695587] input: adc-keys as /devices/platform/adc-keys/input/input0
[    4.704939] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.707775] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.709402] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    4.709562] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    4.709593] cfg80211: failed to load regulatory.db
[    4.709713] clk: Disabling unused clocks
[    4.710264] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    4.710515] rockchip-suspend not set sleep-mode-config for mem-lite
[    4.710539] rockchip-suspend not set wakeup-config for mem-lite
[    4.710558] rockchip-suspend not set sleep-mode-config for mem-ultra
[    4.710572] rockchip-suspend not set wakeup-config for mem-ultra
[    4.711277] ALSA device list:
[    4.711309]   #0: rockchip,acodec
[    4.711324]   #1: rockchip-dsm-sound
[    4.715209] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[    4.748073] mmc_host mmc0: Bus speed (slot 0) = 187500Hz (slot req 187500Hz, actual 187500HZ div = 0)
[    4.945299] edt_ft5x06 0-0038: touchscreen probe failed
[    4.946076] Waiting for root device PARTUUID=614e0000-0000...
[    7.741872] vendor storage:20190527 ret = -1
[   14.785541] platform mtd_vendor_storage: deferred probe pending
RK3506通行证
 楼主| 发表于 2025-9-19 08:16:33 | 显示全部楼层
1. MINI板子只有nand,所以选错型号了
2. 目前只能通过loader方式烧录,MASKROM方式烧录后无法进入文件系统,不知道啥原因
GMT+8, 2026-9-25 12:17
