查看: 1922|回复: 0
[Linux] IMX8MP M7自启动问题(Linux6.1.36) 报错Memory Limit: none
i.MX8MM通行证i.MX8MP通行证
发表于 2025-11-12 22:37:31 | 显示全部楼层 |阅读模式
之前我在Linux5.4上,M7自启动一点问题都没有。今天升级到Linux6.1.36之后,一样的bootcmd,但是会出现启动失败。bootcmd:
setenv loadm "fatload mmc 2:1 0x80000000 IMX8MP_DemoBase.bin;dcache flush;bootaux 0x80000000"
setenv bootcmd "run loadm;mmc dev 2; if mmc rescan; then if run loadbootscript; then run bootscript; elif test mmc2 = mmc1 && run loadupdate; then run mmcupdate; else if run loadimage; then run mmcboot; else run netboot; fi; fi; fi;"
saveenv
reset
报错信息:
[    2.474704] Workqueue: events_unbound deferred_probe_work_func
[    2.474713] Call trace:
[    2.474716]  dump_backtrace.part.0+0xe0/0xf0
[    2.474727]  show_stack+0x18/0x30
[    2.474737]  dump_stack_lvl+0x64/0x80
[    2.474745]  dump_stack+0x18/0x34
[    2.474752]  panic+0x188/0x340
[    2.474763]  nmi_panic+0xac/0xb0
[    2.474771]  arm64_serror_panic+0x6c/0x7c
[    2.474779]  do_serror+0x58/0x5c
[    2.474788]  el1h_64_error_handler+0x30/0x4c
[    2.474795]  el1h_64_error+0x64/0x68
[    2.474802]  of_match_node+0x2c/0xb0
[    2.474813]  i2c_imx_probe+0x348/0x910
[    2.474822]  platform_probe+0x68/0xc0
[    2.474829]  really_probe+0xbc/0x2dc
[    2.474837]  __driver_probe_device+0x78/0x114
[    2.474847]  driver_probe_device+0xd8/0x15c
[    2.474858]  __device_attach_driver+0xb8/0x134
[    2.474867]  bus_for_each_drv+0x7c/0xd4
[    2.474876]  __device_attach+0x9c/0x1a0
[    2.474886]  device_initial_probe+0x14/0x20
[    2.474897]  bus_probe_device+0x98/0xa0
[    2.474906]  deferred_probe_work_func+0x80/0xc0
[    2.474916]  process_one_work+0x1d4/0x330
[    2.474927]  worker_thread+0x220/0x430
[    2.474935]  kthread+0x108/0x10c
[    2.474945]  ret_from_fork+0x10/0x20
[    2.474954] SMP: stopping secondary CPUs
[    2.475265] Kernel Offset: disabled
[    2.475267] CPU features: 0x00000,00800084,0000421b
[    2.475271] Memory Limit: none
我看论坛里还有其他人也有这个问题,但是没有人回答。
GMT+8, 2026-10-4 09:24
