查看: 3947|回复: 7
Linux2.6.36.2内核启动后卡住了
发表于 2011-10-28 17:42:25 | 显示全部楼层 |阅读模式
各位高手,请教下。我烧写完成linux2.6.36.2后,运行就发现串口打印卡住了,希望指点,代码我用的是飞凌给的烧写代码。输出如下:
U-Boot 1.1.6 (Feb 24 2011 - 14:27:19) for SMDK6410
CPU:     S3C6410 @532MHz
         Fclk = 532MHz, Hclk = 133MHz, Pclk = 66MHz, Serial = CLKUART (SYNC Mode
Board:   SMDK6410
DRAM:    256 MB
Flash:   0 kB
NAND:    select s3c_nand_oob_mlc_128
2048 MB
*** Warning - bad CRC or NAND, using default environment
In:      serial
Out:     serial
Err:     serial
NAND read: device 0 offset 0x100000, size 0x500000
s3c-nand: 1 bit(s) error detected, corrected successfully
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
Linux version 2.6.36.2 (root@czj) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-7
2) ) #5 Fri Oct 28 16:56:10 CST 2011
CPU: ARMv6-compatible processor [410fb766] revision 6 (ARMv7), cr=00c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: SMDK6410
CPU S3C6410 (id 0x36410101)
s3c64xx: 10485760 bytes SDRAM reserved for fimc at 0x5f5f9000
s3c64xx: 8388608 bytes SDRAM reserved for tv at 0x5edf9000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: root=/dev/mtdblock2 rootfstype=cramfs console=ttySAC0,11520
PID hash table entries: 1024 (order: 0, 4096 bytes)
Memory: 256MB = 256MB total
Memory: 235584k/235584k available, 26560k reserved, 0K highmem
Virtual kernel memory layout:
    vmalloc : 0xd0800000 - 0xe0000000   ( 248 MB)
    lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
      .init : 0xc0008000 - 0xc003c000   ( 208 kB)
      .text : 0xc003c000 - 0xc04c4000   (4640 kB)
      .data : 0xc0506000 - 0xc0546560   ( 258 kB)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
        RCU-based detection of stalled CPUs is disabled.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:246
console [ttySAC0] enabled
Calibrating delay loop... 530.84 BogoMIPS (lpj=2654208)
devtmpfs: initialized
s3c64xx_dma_init1: registering DMA 0 (d0808100)
s3c64xx_dma_init1: registering DMA 1 (d0808120)
s3c64xx_dma_init1: registering DMA 2 (d0808140)
s3c64xx_dma_init1: registering DMA 3 (d0808160)
s3c64xx_dma_init1: registering DMA 4 (d0808180)
s3c64xx_dma_init1: registering DMA 5 (d08081a0)
s3c64xx_dma_init1: registering DMA 6 (d08081c0)
s3c64xx_dma_init1: registering DMA 7 (d08081e0)
PL080: IRQ 73, at d0808000
s3c64xx_dma_init1: registering DMA 8 (d080c100)
s3c64xx_dma_init1: registering DMA 9 (d080c120)
s3c64xx_dma_init1: registering DMA 10 (d080c140)
s3c64xx_dma_init1: registering DMA 11 (d080c160)
s3c64xx_dma_init1: registering DMA 12 (d080c180)
s3c64xx_dma_init1: registering DMA 13 (d080c1a0)
s3c64xx_dma_init1: registering DMA 14 (d080c1c0)
s3c64xx_dma_init1: registering DMA 15 (d080c1e0)
PL080: IRQ 74, at d080c000
S3C6410: Initialising architecture
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
Advanced Linux Sound Architecture Driver Version 1.0.23.
msgmni has been set to 460
io scheduler noop registered
S3C_LCD clock got enabled :: 133.000 Mhz
LCD TYPE :: LTE480WV will be initialized
Window[0] - FB1: map_video_memory: clear ff600000:0007f800
            FB1: map_video_memory: dma=5e900000 cpu=ff600000 size=0007f800
Window[0] - FB2: map_video_memory: clear ff63fc00:0003fc00
            FB2: map_video_memory: dma=5e93fc00 cpu=ff63fc00 size=0003fc00
Console: switching to colour frame buffer device 60x34
Window[1] - FB1: map_video_memory: clear ff700000:0007f800
            FB1: map_video_memory: dma=5e980000 cpu=ff700000 size=0007f800
Window[1] - FB2: map_video_memory: clear ff73fc00:0003fc00
            FB2: map_video_memory: dma=5e9bfc00 cpu=ff73fc00 size=0003fc00
Window[2] - FB1: map_video_memory: clear ff680000:0003fc00
            FB1: map_video_memory: dma=5ea00000 cpu=ff680000 size=0003fc00
Window[3] - FB1: map_video_memory: clear ff780000:0003fc00
            FB1: map_video_memory: dma=5ea40000 cpu=ff780000 size=0003fc00
jkq debug VIDCON0 is 353
leds    initialized
pwm     initialized
s3c6400-uart.0: s3c2410_serial0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: s3c2410_serial1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: s3c2410_serial2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: s3c2410_serial3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
S3C NAND Driver, (c) 2008 Samsung Electronics
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
sdhci: Secure Digital Host Controller Interface driver
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (24000000 Hz)
enter s3c64xx_setup_sdhci1_cfg_gpio
s3c6400_setup_sdhci_cfg_card: CTRL 2=c0004120, 3=80808080
usbhid: USB HID core driver
asoc: AC97 HiFi <-> s3c-ac97 mapping ok
s3c6400_setup_sdhci_cfg_card: CTRL 2=c0004120, 3=00008080
mmc0: new SD card at address aaaa
mmcblk0: mmc0:aaaa SD02G 1.84 GiB
mmcblk0: p1
Failed to reset WM9713: AC97 link error
ALSA device list:
  No soundcards found.
s3c-rtc s3c64xx-rtc: hctosys: invalid date/time
mtd->size = 80000 blocks = 7800000
cheaking bad block...............
VFS: Mounted root (cramfs filesystem) readonly on device 31:2.
devtmpfs: mounted
Freeing init memory: 208K
       停在这个地方就不动了的,好像是死机了的。请问是什么原因呢?
chenzlnankai 该用户已被删除
发表于 2011-10-29 13:48:50 | 显示全部楼层
 楼主| 发表于 2011-10-29 16:09:14 | 显示全部楼层
不是的,全部打印输出粘贴进来放不下的,现在分两个部分打印输出:
Board:   SMDK6410
DRAM:    256 MB
Flash:   0 kB
2048 MB
In:      serial
Out:     serial
Err:     serial
Boot with zImage
Starting kernel ...
Machine: SMDK6410
NR_IRQS:246
 楼主| 发表于 2011-10-29 16:40:56 | 显示全部楼层
leds    initialized
pwm     initialized
S3C NAND Driver is using hardware ECC.
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd5 (Samsung NAND 2GiB 3,3V 8-bit)
Creating 4 MTD partitions on "NAND 2GiB 3,3V 8-bit":
0x000000000000-0x000000100000 : "Bootloader"
0x000000100000-0x000000600000 : "Kernel"
0x000000600000-0x000007e00000 : "User"
0x000007e00000-0x000080000000 : "File System"
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 2.6.36.2 ohci_hcd
usb usb1: SerialNumber: s3c24xx
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver pl2303
mice: PS/2 mouse device common for all mice
input: gpio-keys as /class/input/input0
S3C Touchscreen driver, (c) 2008 Samsung Electronics
S3C TouchScreen got loaded successfully : 12 bits
input: S3C TouchScreen as /class/input/input1
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
i2c /dev entries driver
lirc_dev: IR Remote Control driver registered, major 253
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR LIRC bridge handler initialized
Linux video capture interface: v2.00
usbcore: registered new interface driver em28xx
em28xx driver loaded
Em28xx: Initialized (Em28xx Audio Extension) extension
cx231xx v4l2 driver loaded.
usbcore: registered new interface driver cx231xx
cx231xx: Cx231xx Audio Extension initialized
usbcore: registered new interface driver usbvision
USBVision USB Video Device Driver for Linux : 0.9.10
usbcore: registered new interface driver pvrusb2
pvrusb2: V4L in-tree version:Hauppauge WinTV-PVR-USB2 MPEG2 Encoder/Tuner
pvrusb2: Debug mask is 31 (0x1f)
SE401 usb camera driver version 0.24 registering
usbcore: registered new interface driver se401
usbcore: registered new interface driver zr364xx
zr364xx: Zoran 364xx
usbcore: registered new interface driver stkwebcam
sn9c102: V4L2 driver for SN9C1xx PC Camera Controllers v1:1.47pre49
usbcore: registered new interface driver sn9c102
pwc: Philips webcam module version 10.0.13 loaded.
pwc: Supports Philips PCA645/646, PCVC675/680/690, PCVC720[40]/730/740/750 & PCV
C830/840.
pwc: Also supports the Askey VC010, various Logitech Quickcams, Samsung MPC-C10
and MPC-C30,
pwc: the Creative WebCam 5 & Pro Ex, SOTEC Afina Eye and Visionite VCS-UC300 and
VCS-UM100.
usbcore: registered new interface driver Philips webcam
gspca: main v2.10.0 registered
usbcore: registered new interface driver hdpvr
usbcore: registered new interface driver ibmcam
usbcore: registered new interface driver ultracam
konicawc: v1.4:Konica Webcam driver
usbcore: registered new interface driver konicawc
usbcore: registered new interface driver vicam
usbcore: registered new interface driver s2255
[CAM]s3c_fimc_register_controller.id=0
s3c_fimc_init_global s3c_fimc.cam_clock=-1068449380
[CAM]s3c_fimc_register_controller.id=1
s3c-fimc: info ov965x_init
[CAM]s3c_fimc_register_camera,cam->id=0
s3c_fimc.cam_clock = c050c19c
parent clock for camera: 266.000 MHz, divisor: 11
[CAM]RESET CAM.[CAM]Reset and init reg!1cam->client=ce84d700
[CAM]Reset and init reg!2
[CAM]s3c_fimc_init_camera[CAM]I2C_CAM_INIT.
[CAM]s3c_fimc_init_camera[CAM]s3c_fimc_init_camera[CAM]Reset and init reg!3
mmcblk0: p1
AC97: Unable to activate!
AC97: Unable to read!
ALSA device list:
devtmpfs: mounted
一直停在这里,为什么?
发表于 2011-10-31 08:25:27 | 显示全部楼层
编译的时候有报错么?编译的环境介绍一下吧,方便大家帮你看看。
 楼主| 发表于 2011-10-31 11:10:31 | 显示全部楼层
没用到编译环境的,我直接用的是你们光盘里面的下载代码和根文件系统。
 楼主| 发表于 2011-10-31 14:19:31 | 显示全部楼层
请问是我硬件坏了么?
发表于 2011-10-31 16:43:12 | 显示全部楼层
楼主是自己编译的内核吧
如果是,请说明代码来源、编译方面的信息。
GMT+8, 2026-10-6 09:50
