8mp uboot阶段通过网络更新镜像
2022-11-18 15:37| 发布者: Q_Y_X| 查看: 746| 评论: 0
类目: 知识库  >  i.MX8MP系列产品     文档编号: 821
实际操作如下:
root@OK8MP:/# uname -a
Linux OK8MP 5.4.70-2.3.0 #2 SMP PREEMPT Fri Aug 5 22:38:53 PDT 2022 aarch64 aarch64 aarch64 GNU/Linux
首先在uboot阶段通过TFTPImageOK8MP-C.dtb文件下载到内存中。
forlinx=> setenv ipaddr 172.16.0.207
forlinx=> setenv serverip 172.16.0.206
forlinx=> setenv image Image
forlinx=> setenv fdt_file OK8MP-C.dtb
forlinx=> setenv netargs setenv bootargs console=ttymxc0,115200 root=/dev/nfs rw ip=172.16.0.207:172.16.0.206:172.16.0.1:255.255.255.0::eth0:off nfsroot=172.16.0.206:/nfs_rootfs,v3,tcp
forlinx=> run netargs; tftpboot ${loadaddr} ${image}; tftpboot ${fdt_addr} ${fdt_file}
Using ethernet@30be0000 device
TFTP from server 172.16.0.217; our IP address is 172.16.0.207
Filename 'Image'.
Load address: 0x40480000
Loading: #################################################################
        3.2 MiB/s
done
Bytes transferred = 28150272 (1ad8a00 hex)
Filename 'OK8MP-C.dtb'.
Load address: 0x43000000
Loading: #####
        4.3 MiB/s
done
Bytes transferred = 67111 (10627 hex)
forlinx=> mmc part
Partition Map for MMC device 2  --   Partition Type: DOS
Part Start Sector   Num Sectors UUID             Type
  1  16384        170368      036f1e8a-01 0c
  2  186752      15728640    036f1e8a-02 83
forlinx=> fatwrite mmc 2:1 0x40480000 Image 0x1ad8a00
28150272 bytes written
forlinx=> fatwrite mmc 2:1 0x43000000 OK8MP-C.dtb 10627
67111 bytes written
forlinx=>saveen
Saving Environment to MMC... Writing to MMC(2)... OK
forlinx=>reset
root@OK8MP:~# uname -a
Linux OK8MP 5.4.70-2.3.0 #1 SMP PREEMPT Tue Jun 21 20:09:50 PDT 2022 aarch64 aarch64 aarch64 GNU/Linux
上一篇:8mp移植驱动下一篇:8mp屏幕旋转
GMT+8, 2026-9-10 17:06
