查看: 8005|回复: 4
Qt4.7.1 交叉编译环境配置
发表于 2014-2-28 15:14:23 | 显示全部楼层 |阅读模式
 楼主| 发表于 2014-2-28 16:03:50 | 显示全部楼层
1.5用 configure 生成 Makefile
生成警告
configure: WARNING: unrecognized options: --enable-inputapi
root@localhost:~/arm/tslib#
 楼主| 发表于 2014-2-28 16:07:59 | 显示全部楼层
1.6 编译安装
make 2>&1 | tee make_log
错误:
font_8x16.c:4629: warning: pointer targets in initialization differ in signedness
mv -f .deps/font_8x16.Tpo .deps/font_8x16.Po
make: *** No rule to make target `../src/libts.la', needed by `ts_test'.  Stop.
root@localhost:~/arm/tslib/tests#
 楼主| 发表于 2014-2-28 17:45:25 | 显示全部楼层
configure: WARNING: if you wanted to set the --build type, don't use --host.
    If a cross compiler is detected then cross compile mode will be used
configure: loading cache arm-linux.cache
checking for a BSD-compatible install... (cached) /usr/bin/install -c
checking whether build environment is sane... yes
checking for arm-linux-strip... (cached) arm-linux-strip
checking for a thread-safe mkdir -p... (cached) /bin/mkdir -p
checking for gawk... (cached) mawk
checking whether make sets $(MAKE)... (cached) yes
checking for arm-linux-g++... (cached) arm-linux-g++
checking whether the C++ compiler works... no
configure: error: in `/home/huang/arm/tslib':
configure: error: C++ compiler cannot create executables
See `config.log' for more details
发表于 2014-3-4 16:42:27 | 显示全部楼层
楼主,您的问题是出在什么地方啊?
GMT+8, 2026-10-4 20:22
